Old Mar 10, 2014, 08:24 PM
Joined Dec 2005
Build Log
Hangar 9 30cc Spitfire Build log just got mine!
I just picked up my new H9 30cc spitfire, and the Eflite electric retracts made for the spitty. Over the plane looks awesome, printed covering,panel lines etc. The retracts come with a control board and spring suspension oleo struts! Will start snapping pics when the wifey is not around.
helifann is online now Find More Posts by helifann
Old Mar 10, 2014, 10:26 PM
checksix6's Avatar
United States, NC, New Bern
Joined Dec 2010
lucky guy ! Ill be looking forward to your build , ive got my eye on this one but dont know how friendly the engine bay is gonna be for optional powerplants
love the dull finish and panal lines they advertised , take some pics !
checksix6 is offline Find More Posts by checksix6
Old Mar 10, 2014, 11:33 PM
Joined Dec 2005
I will snap plenty of pictures! I plan on using a dle 30 or another 30cc engine. The looks of the kit so far is superb! I knew I just had to have this plane.
Old Mar 11, 2014, 01:47 AM
Joined Dec 2005
Here's a few pics of the plane, from my observations, so far looks very well constructed I have the h9 .60 razorback and was impressed with the printed covering and the ease if building. This spitfire is the same if not better quality. Included in the box is a painted aluminum spinner, painted radiators,gun mounts guns antennae mast etc. also is 2 different rudders and stickers for you to choose which plane you want to build! The fuse has a magnetic hatch just behind the cowel and cutouts inside for switches etc. knowing my past experiences with hangar 9 planes this one is sure to fly superb!
Old Mar 11, 2014, 04:10 AM
Joined Apr 2008
I was waiting for someone to post some picturers thanks went and ordered one Sat. Going to use a dle 35 ra , out of money to many planes
bladebender is offline Find More Posts by bladebender
Old Mar 12, 2014, 09:27 PM
Joined Jan 2014
Great looking plane. I am looking forward to seeing you put it together. Which powerplant are you planning on?
McCrazy is offline Find More Posts by McCrazy
Old Mar 13, 2014, 01:04 AM
Joined Dec 2005
DLE 35 ra, just ordered it today.
Old Mar 14, 2014, 11:18 PM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Sweet. Can you give some cowl measurements. Height by width where the engine sits
Can you verify if the LG is truly scale or slightly modified for easier handling?
Looks great & thanks
scootrb4 is online now Find More Posts by scootrb4
Old Mar 15, 2014, 10:05 PM
Joined Dec 2005
The cowel, around 7X6 where the engine sits. So far I have my wings done, installed my servos in the fuse. I am working on mounting the engine now. Ill tell you it ios a tight squeeze for the batteries etc, but its doable. The DLe 35 ra will require you to mount the throttle servo in a different location. took some thinking but I figured out where to put it. So far the build is going quick. I did take of the bottom piece of the firewall to get into the fuse to mount the firewall bolts. I do that to most of my planes anyway. Plus it allows me to get in there again if I have to. I might stuff the ignition module in there as there is room.
Old Mar 16, 2014, 12:37 AM
Joined Dec 2005
Here's a picture of the tank, I have two life batteries on the sides of the tank, one for ignition and one for rx. You can also see I'll have to mount my throttle servo in this area since the DLE 35ra throttle arm is on top.
Old Mar 16, 2014, 06:50 PM
scootrb4's Avatar
Joined Nov 2011
Dang Spitty looks tight.... 18 oz tank?
Keep posting - buddy of mine is looking hard at this model sitting in the hobby shop
Old Mar 16, 2014, 09:33 PM
Joined Dec 2005
550 cc tank, its a beauty this bird!!!
Old Mar 16, 2014, 09:36 PM
scootrb4's Avatar
Joined Nov 2011
We have a 35 EVO. It's rail mount with a front carb. I think it would be a great fit, heavy too
When u get the gear in I like to see a pic of them from the front - straight on. Thanks
Old Mar 25, 2014, 11:19 PM
Joined Dec 2005
Ok all done except for cg, at the firewall it needs 3lbs! Gonna see if I can find somewhere to move further.
Old Mar 26, 2014, 02:16 PM
scootrb4's Avatar
Joined Nov 2011
Ouch! 3 pounds..... spitfire always requires so much weight regardless of the maker. Can you move batteries forward?
News Hangar 9 Announces 30cc Sized Spitfire Jason Cole Giant Electric Planes 26 Mar 03, 2014 09:14 AM
For Sale NEW Cowl: Cirrus SR22T 30cc by Hangar 9 (HAN502006) teryn1 Aircraft - General - Miscellaneous (FS/W) 0 Nov 15, 2013 11:23 AM
Off Site *Hangar 9 Cirrus SR22T 30cc* olezippi Aircraft - Fuel - Airplanes (FS/W) 8 Nov 10, 2013 07:14 AM
For Sale Hangar 9 P-47D Razorback 150 RC Airplane 30cc Size Size gva1956 Aircraft - Fuel - Airplanes (FS/W) 10 Oct 15, 2013 05:00 AM
Build Log Hangar 9 Spitfire Build Log Airmaster23 Fuel Warbirds 72 Jul 29, 2012 08:13 PM
