Old Aug 02, 2015, 06:33 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Irun
the delight is supposed to be driven by a separate channel ( aboard a 133% Wayfarer - The RCM vintage plan ! - )
I had tried almost all the files posted in this thread, just for learning !
I see your file is different from the previous " cessna 400" ... so, I give it a try !
looks to work fine !
in yours no pattern lasts more than 2.50s ...
so, could it be the issue for my program, as Ch 3 and 4 last 3.8s ?
Thanks for your Help
Alain
Acetronics is offline Find More Posts by Acetronics
Old Aug 02, 2015, 09:52 AM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
great let me how how you make out
irun4fundotca is online now Find More Posts by irun4fundotca
Old Aug 02, 2015, 02:03 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Irun
Issue was solved more than a year ago by building my own 8 channels light controller around a PIC 16F1825 ... each output able to drive 4 Amps ( w/ IRLU 8256, TO 251 / IPak Case ) ....
one version also drives the electric gear for my Robbe twinair ( also called Aerosky B60 Duke ... ) : the gear switch has 3 pos :
1) parking : cabin lights ON other lights OFF - gear down
2) take off : cabin OFF, landing lights ON, other lights ON, gear Down
3) Flight : Landing Lights OFF, same as previous for other lights, but gear UP
BTW, in flight, if Receiver voltage goes low ... it lock gear down and switch Landing lights ON ...
the only drawback is .... components are all " thru hole " ...
but no issue with the 3 desync. strobes and 2 desync. Beacons ...
For the Delight ... Halas, the issue is confirmed, moreover, the problem also occurs with another light controller ...
I continue to try to find what's wrong in that kind of program ...
Alain
PS: mail sent to the DE support board ... wait and see if someone there ...
Old Aug 04, 2015, 03:18 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
The end of the story ...
from DE Technical :
That is indeed an issue with the older controllers- certain sequences can time-out after anything longer than about 10 minutes. We have a firmware fix available that should solve the issue you’re having. You will need to send the Controllers back to us for the update. If you want to do this, let me know and I will get you an RMA number for return.
I think I'll have to send my controllers overseas ... 25$ to add to the bill !!!
Alain
Old Sep 14, 2015, 11:44 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
The end of the story ... bis.
my four modules are back from the US ... working fine now,
the only point that has not being solved is a strange HUGE current spike ( some Ás @ power up ) that is able to reset my 16F628 signal generator ( Brownout enabled ) powered by a strong 3 Ah Nicad Pack ...
This " feature " must be seriously taken into account if the delight was to be powered on through the R/C system ...
a receiver resetting would be to happend with all the disasters one can imagine.
Alain
Old Oct 05, 2015, 07:08 PM
clonedkorl is offline
Find More Posts by clonedkorl
A&P Diddy
Midlothian, Tx
Joined Oct 2008
The documentation for this is lacking I think? Does the power for the unit come form the Rx wire? Where are you supposed to hook up the power?
clonedkorl is offline Find More Posts by clonedkorl
Old Oct 05, 2015, 07:49 PM
ramovan is offline
Find More Posts by ramovan
ramovan's Avatar
United States, NV, Mesquite
Joined Aug 2004
Yes, the DElight is powered from the servo lead on the controller that plugs into your receiver. Power is the first thing discussed in the manual here...
http://www.dimensionengineering.com/...ts/DELight.pdf
ramovan is offline Find More Posts by ramovan
Site Sponsor
Old Oct 05, 2015, 07:53 PM
A&P Diddy
Midlothian, Tx
Joined Oct 2008
I need to run a separate bec and that particular function is a little gray. It just states that I may need to. Do I just split the power and ground out of the connector and use the signal wire only to the rx?
Old Oct 05, 2015, 08:30 PM
ramovan is offline
ramovan's Avatar
Joined Aug 2004
Yes, that should work fine. You can use a servo Y-harness if you want to split that and modify the harness instead of altering the DElight servo lead.
Site Sponsor
Old Oct 06, 2015, 11:45 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
No problem for using a separate supply ; just make like for the controllers take the red wire connector out of the Rx plug and connect it to your separate supply "+"
of course, the GND wires have to be tied together
for this I used a small 1200 mAh 2S LiPO Batt and a small 2$ Ebay adjustable 2A Buck converter http://www.dx.com/p/mini-dc-dc-volta...ule-red-126106 to get 4 to 5v ( for DeLight and series resistors not to dissipate as much or more than the leds ... )
Alain
Old Oct 22, 2015, 08:17 PM
A&P Diddy
Midlothian, Tx
Joined Oct 2008
Ok, new question. I see that the max voltage for this is a little over 7v. What happens if I try to run 12v through it?
Old Oct 23, 2015, 01:53 AM
dainw is offline
Find More Posts by dainw
H2oSmokey
dainw's Avatar
Mill Creek, WA
Joined Jun 2009
Probably the same as if you tried to put 70% more gas in your car . . . . smoke and flames. . .
dainw is offline Find More Posts by dainw
Old Oct 24, 2015, 03:46 PM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
for 2$, you get a 12v > 5v @ 2-3A "LM 2596S" buck converter on Ebay ...
for 10$ ... you get the 10 Amps model !!!
but remember Delight shows limited current outputs ...
Ahhh yes ??? That was your next question : " may I use 12v 20 W Led chips with the Delight ??? "
the answer is NO !!!
Alain
Old Oct 25, 2015, 08:36 AM
A&P Diddy
Midlothian, Tx
Joined Oct 2008
No it wasn't. I have a variety of voltage options on board to feed this thing. Most of the leds I have don't light up worth a crap until they get around 12v though.
Old Oct 25, 2015, 11:03 AM
A&P Diddy
Midlothian, Tx
Joined Oct 2008
last question.... I have the Delink2 and it has 2 sets of connections. One has Tx and one has Rx by them. There are no clear instructions in the manual for the v2, only the v1 is seems. Any help on how this is supposed to be connected?
Model plane lighting system Joe Yap Modeling Science 23 Aug 06, 2007 02:47 PM
Looking for one beta tester for lighting system.. Nik-rc Parkflyers 9 Sep 12, 2004 07:50 PM
PIcture of MPI Micro Lighting System konaboy Parkflyers 7 Jan 21, 2003 03:16 AM
Lighting system for your Heli. Fred Bronk Electric Heli Talk 11 Jan 15, 2003 02:00 AM
Miniflash with a Curtek lighting system! Martin Hunter Parkflyers 15 Dec 24, 2002 04:06 PM
