Old Aug 28, 2015, 05:31 PM
Chris20 is offline
Find More Posts by Chris20
United States, MI, Rockwood
Joined Jan 2013
Help!
Need help with aileron hinge.
Well I did a dumb thing and didn't pay attention to my gyro initialize. I launched my f16 and it plummeted straight to earth because I had no controls. My left wing broke off and it also broke the hinge apart. I don't have hinge tape. Does anything else work to hold this together?
Chris20 is offline Find More Posts by Chris20
Old Aug 28, 2015, 05:34 PM
Chris20 is offline
Joined Jan 2013
Description:
This is the damage
Old Aug 28, 2015, 05:50 PM
HellHathNoFury is online now
Find More Posts by HellHathNoFury
Joined Dec 2013
Pin hinges or CA hinges?? Both easy to put on .. Maybe 10mins..
HellHathNoFury is online now Find More Posts by HellHathNoFury
Old Aug 28, 2015, 05:54 PM
Chris20 is offline
Joined Jan 2013
I have CA and epoxy. Epoxy holds well just don't know if it will be too stiff. I heard dap instant cement works too. I could try CA first seems the easiest
Old Aug 28, 2015, 06:09 PM
Joined Dec 2013
Just go to a hobby store & buy CA hinge .. Without hinges the aileron will come apart easily again
Old Aug 28, 2015, 06:16 PM
Chris20 is offline
Joined Jan 2013
There are no hinges. It's part of the wing. There's no pins or anything. It just tore apart
Old Aug 28, 2015, 06:36 PM
natiho2 is offline
Find More Posts by natiho2
Joined Apr 2012
Here you go
Installing CA Hinges (3 min 9 sec)
natiho2 is offline Find More Posts by natiho2
Old Aug 28, 2015, 08:44 PM
Joined Dec 2013
Bingo...
Old Aug 28, 2015, 09:05 PM
Chris20 is offline
Joined Jan 2013
I'll give it a shot. The wings and flaps are so thin I don't know if I can get a hinge in there
Old Aug 28, 2015, 09:14 PM
fishface5 is online now
Find More Posts by fishface5
United States, NE, Lincoln
Joined Oct 2014
foam tac on a qtip
fishface5 is online now Find More Posts by fishface5
Old Aug 28, 2015, 09:17 PM
Joined Dec 2013
Hinges are very thin & you use a sharp blade to cut the slots... I used them on 64mm Panther , T-45, F-18 ,etc to strengthen the elevators,ailerons,rudders.. Don't trust foam hinges much..
Old Aug 29, 2015, 08:49 AM
Chris20 is offline
Joined Jan 2013
Ok. I'll try the zip tie hinges. The foam looks thick enough to pierce with a razor blade then slide the zip tie in. Thanks for the ideas guys. I tried gorilla glue foam glue but it's too stiff it won't let it pivot anymore.
Old Aug 30, 2015, 07:44 PM
Chris20 is offline
Joined Jan 2013
Worked perfectly. 3 small zip tie ends ca'd in. Flew great today.
Description:
Help! Need help repairing a torn flap hinge wdwimbish Multi Task F3X 4 Aug 04, 2015 12:50 PM
Discussion Recovering a plane and need help with hinges mudbugnla The Builders Workshop 17 Dec 29, 2014 10:18 AM
Discussion Adding Ailerons to an Elevon'd F22 -need help with 9303 mix programming DesignGeek Radios 14 May 18, 2014 03:01 PM
Found Need help fixing aileron hinge whirl10 Aircraft - Electric - Airplanes (FS/W) 2 Nov 23, 2012 12:33 AM
Need help with Fokker DVII aileron hinge line E_ferret Scale Fuel Planes 0 Oct 31, 2004 04:21 PM
