Old Jan 14, 2016, 02:38 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
This version was made by Woody Bartelt
Reginald is offline Find More Posts by Reginald
Old Jan 14, 2016, 06:37 AM
krafty is offline
Find More Posts by krafty
krafty's Avatar
France, Aquitaine, Duras
Joined Jan 2006
Originally Posted by lordofthewings04 View Post
Over the years I have had various Elfs, originals and Arne Hende replicas (the best runners are the originals). I currently have two Corncob replicas from the series of 20 made by Czech engineer Ladislav Davidovic. They look to me to be closer to the original “fairly crude castings”, rather than the somewhat sanitised Arne Hende repros. There are differences: one looks to have gaskets, the other not. One has a tank/carb like I’ve seen pics of, the other is different (without a float). The timer arms are in different positions. Any ideas as to what goes with what ? I will be selling one as I don’t need both, and I’m reluctant to run them to find out, as I want to move it on to the new owner “as is”.
I have looked through Brown's book on the Elfs and no mention is made of an Elf 1 with a float chanber but no float. There was a carb variety without a float chamber and just a plastic tank suspended under the inlet tube. The carb on the left in your pictures looks like the revised design introduced in 1938 after about engine number 100. Brown's book makes no reference to any carb like the one on the right of your picture. Since both your engines are repros, I guess which carb goes on which engine is not important. As for the angle of the timer arm, the original engine had its timer cam shrunk onto the crankshaft and the same timer was used for all versions of the engine we know as the Corn Cob. Unless the maker of your two engines deliberately shrunk the timer cam in different positions on the two engines, the timer arms should be in the same position on both engines.
For those who do not already know of it, my reference is the book "Dan Calkin and his Elfs" byJohn J Brown, ISBN 0-9673666-0-7
A question Paul, do your engines have ringed pistons as per the originals, or are they ferrous and unringed.
krafty is offline Find More Posts by krafty
Old Jan 14, 2016, 06:44 AM
lordofthewings04 is offline
Find More Posts by lordofthewings04
South coast of England
Joined Nov 2006
Originally Posted by krafty View Post
......do your engines have ringed pistons as per the originals, or are they ferrous and unringed.
Thanks chaps for the pics and helpful observations. The engines have shiny alloy pistons and twin rings.
lordofthewings04 is offline Find More Posts by lordofthewings04
Old Jan 15, 2016, 03:07 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Did any of you ever run a Hetherington sparkie ? any good ?
Old Jan 15, 2016, 04:04 AM
krafty is offline
krafty's Avatar
Joined Jan 2006
Drome Demon bones on eBay
http://www.ebay.co.uk/itm/3516277838...84.m1555.l2649
Old Jan 15, 2016, 04:17 AM
krafty is offline
krafty's Avatar
Joined Jan 2006
Just for interest, the Thor 29.
As part of my on going clear out I came across this Thor 29. It is of course a "slag" engine with the cast alloy piston running directly in the alloy case, with no cylinder liner. Many experts will tell you that these engines simply do not run, but this one ran nicely and flew one of my F/F vintage models.
The fun part is to run these in the dark, because the wipe-and-swipe timer produces a shower of sparks just like a catherine wheel. The secret of running these is to use a very high oil content in the fuel, and I always made a last static run of the day by stopping the engine with a direct squirt of neat Slick 50 into the carb. This was a tip from my late buddy Mike Beach, who also flew Thors quite successfully.
Old Jan 17, 2016, 12:40 PM
Joined Nov 2006
Elfs - sorted
Thanks for the various helpful suggestions. Here's the result. Now all I need is for the weather to warm-up a bit so I can get out and test run them.
Old Jan 22, 2016, 08:22 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Ken's Brown did arrive well from la douce France... compression does feel fine but only running will tell but I am confident in his rebuilding work...made a quick adaptation to the old ignition running-in bench but it is rather freezing outside so that will be done later perhaps next week when I have finished my Cri-Cri... I never seem to have enough time for all the things I want to do...
Old Jan 23, 2016, 07:06 AM
ukengineman is offline
Find More Posts by ukengineman
United Kingdom, England, Richmond
Joined Apr 2011
Brown Jr's are my favourite spark ignition motors, they have a character all of their own. Attached photo shows one of my Brown's in the nose of a Kayo which I acquired from the late Mike Beach.
ukengineman is offline Find More Posts by ukengineman
Old Jan 23, 2016, 09:40 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
The Brown is now ready for some running-in since Ken told me that he did not fully did that with this engine... most 14 inch props have a far too large center so I quickly made an alu adaptor...some Fluke testing and Houston we have a spark... I am using the good Champion plugs since I do have about 12 NIB ones... and I am using Coleman's Fuel since Clarence Lee did advise me long ago to use that stuff... but with that heavy rain outside the running will be postphoned to some later date. It has been many many years since I did run an old sparkie
Old Jan 29, 2016, 07:03 AM
nernst is offline
Find More Posts by nernst
Italy, Sicily, Messina
Joined Sep 2011
Orr 65
Hi All!! Yesterday I have got this Orr 65 I think unrun, very nice. The engine has not serial number, only a "K" letter and a "9" number in the two parts of crank case. What do you think about this engine? Why it is without serial number? Thank you, ciao from Sicily!!
Ernesto
nernst is offline Find More Posts by nernst
Sold CRRC-PRO Ignition NIB never used 45.00 anwalker Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 07, 2010 07:32 PM
Sold OS Max FS-61 Four Stroke W/Electronic Ignition Conversion stevster Aircraft - Fuel - Engines and Accessories (FS/W) 0 Nov 07, 2010 12:44 AM
Sold Saito G60 Marine, vintage gas ignition, NIB Kmot Aircraft - Fuel - Engines and Accessories (FS/W) 4 Oct 29, 2010 08:47 PM
Cool Early Slope History Treasures Unearthed Paul Naton Slope 7 Jun 11, 2008 10:30 PM
