Possibly. I'll have to mess around with it more I guess.
My more recent problem today...now I can't figure out why my blade grips keep coming loose off the head. I use loctite. I've been working on my heli recently so I'm wondering if something is causing too much vibration. I've only had one short hover test since the work, and I haven't had a chance to track my blades yet. I'm wondering if the blade tracking is causing the vibration. But I'm not sure it would be enough to unscrew the blade grips... but maybe. Like I said, I only basically spooled up to test hover, my elevator servo gave me problems and I was able to land safely, but when I landed I noticed the blade grip coming off. |
USA, WA, Bremerton
Joined Feb 2007
There is also grease tolerant thread lock. It's not great for some things but if I have trouble getting it into a spot like a feathering shaft, that is a good place. I also use a toothpick and put the locker in the hole, not on the bolt. You don't want to have it come off in flight - don't ask me how I know.
Well, I'm testing it today again, we'll see what happens. I think there might have been to much old dry loctite on the bolt, so I'm using a new one anyway. And there did seem to be dirty grease on the bolt too, in what wiped off with a paper towel. We'll see what happens, I'm pretty confident, but then again I was confident last time too when the grip almost came off. I hope my grips don't come off, that would suck. Meanwhile, I just put an align main gear set (w/bearing & everything) on and I'm amazed at the performance vs the exi stock. It's smooth, the gears mesh better , and way less shakes starting up and everything. A lot quieter too! I think I'll be buying a trex 450 soon. |
The Netherlands
Joined Nov 2009
If you have a problem with main blade grips coming loose, even if you use threadlock and you use it correctly, big chance you have a bearing problem in that blade grip.
I am not particularly careful when applying threadlock, and my bottle is over 10 years old (took it back from work that time and no idea how long it was allready in use or how it was stored previously) but never had anything coming loose that was secured with that. And I fly a lot, and plenty different heli's, and work a lot on heli's, not only my own.... I feel comfortable with it, just because I know (and have tested and confirmed numerous times) that even that bottle still provides absolutely sufficient security, even in big gassers with their high vibration levels. I also work a lot on helicopters for other people, and I have seen more than one blade grip being not threadlocked (either from factory or from their own stupidity) and still not coming loose in flight. MIND: I am NOT saying that you don't need threadlock, nor that it is only of minor importance!!!!! What I am trying to say, is that threadlocking is neither extremely critical nor black magic, so if a blade grip is coming loose that normally pretty well stays put on its own, there is more to look for. I have seen blade grip bearings run smooth under static load, but completely freeze when subject to centrifugal force, because static the balls stay in place but under centrifugal force the balls move to the side of the races, for example. A Blade Grip retaining bolt, does NOT work loose from the centrifugal force, nor does it work loose from the leverage created by the lift of the blade. It can ONLY work loose from the oscillating movement due to cyclic control. So whatever might be wrong with the bearing, chances are the cyclic movements are transferred tot either the blade grip retaining bolt or the feathering shaft, and hammering it loose. The only threadlock that can withstand that, will at the same time make it impossible to remove that bolt without damage. So: check your bearings carefully.... As to thread locking: I have professionally never seen thread locking agent being applied to the hole, always to the bolt. This, because threadlock in a hole does not get spread as efficient through the threads, as threadlock applied to the bolt: you don't pour paint on your model, hold the brush still and move the model to and fro..... Brgds, Bert |
I have been checking it constantly now, and after about 7 flights both grips have stayed tight.
I'm also not running a washer between my inner blade grip bearing and the inner thrust bearing. It was ratcheting the grip when i had these washers in, and dont see how they are necessary. |
The Netherlands
Joined Nov 2009
Now whichever one is turning, there will be always one of the ball races rubbing to the thrustplate. That is what the washer usually is for, to give clearance to the moving ballrace. But if that washer was ratcheting your blade grip, than there's your answer as to why the grips came loose.... Most probably, it was either the wrong washer, or it was in the wrong location. Brgds, Bert |
| Thread Tools | |
| Question $8.99 heli belt (450 sport clone) question about tail gear/autorotation gear | js32257 | Mini Helis | 0 | Mar 30, 2012 07:16 PM |
| Discussion 90 degr angled pitot tube | aeropics | Flight Accessories | 0 | Jul 30, 2011 11:19 AM |
| For Sale 4#6 Complete 45 degr & 90 degree BELL rotor heads Main shaft NIP blades &training | blueindian | Aircraft - Electric - Helis (FS/W) | 1 | Feb 03, 2011 02:05 PM |
| Help! tail started to swing left and right | mark groves | Mini Helis | 11 | Oct 22, 2007 06:32 PM |
| Help! Tail Swinging Towards the Right | mikefaith | Electric Heli Talk | 7 | Apr 21, 2006 10:34 PM |
