Old Yesterday, 06:27 PM
cubcrafter60 is online now
Find More Posts by cubcrafter60
Wada ya mean, over engineered?
cubcrafter60's Avatar
United States, NV, Fallon
Joined Jul 2011
dpowellmeii Thanks! I went to apc's webpage and all they list is a speed400 6x4 pusher prop (no thin electric or slow fly props). Am I making an assumption that most folk's are using apc prop's on these parkjets? If so any recommendations?
Thanks again!
Robin
cubcrafter60 is online now Find More Posts by cubcrafter60
Latest blog entry: de Havilland DH.60 Gipsy Moth
Old Yesterday, 07:00 PM
dpowellmeii is offline
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
If you're running high rpms I'd go with the thin e props.
They sell a 6x4e and 6x4ep.
http://www.apcprop.com/pindex.asp?Page=2
http://www3.towerhobbies.com/cgi-bin...&I=LXZK90&P=ML
dpowellmeii is offline Find More Posts by dpowellmeii
Old Today, 01:36 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
You said you are going to use a Suppo 2212-06. I've used several of those motors and the the setup that I like best is using a collet adaptor, APC 6x4E prop on a 3S 2200 mah battery. This is the light speed setup. For more vertical and less speed use a 1500 kv motor with an APC 7x5E prop.
Kevin
Originally Posted by cubcrafter60 View Post
Can I (or should I) run a prop saver type prop adapter with the APC 6x4 thin electric prop rather than a collet type prop adapter?
RCDad is offline Find More Posts by RCDad
Old Today, 03:03 AM
Joined Jul 2011
dpowellmeii,
Sorry, I don't mean to be dense but this is a new area of the hobby for me, the Tower link is for an APC 6x4e (tractor) prop that they call a 'thin electric', are you running (or can you run) a tractor prop (facing forward)? To further confuse things the only 6x4 props I see on APC's website are the 6x4 sport (glow), a 6x4e, and 6x4ep both in the speed 400 series The thin electric series jump from 5x3 to 6x5.5 (tractor) and 5x3 to 7x5 (pusher), I don't mean to get all wrapped around the axles on the nomenclature but I just want to make sure I order the right prop and I'm getting a bit confused.
Old Today, 04:05 AM
Joined Jul 2011
Thanks Kevin,
I typed the last post before before I saw yours (dosed off while typing)! Yes I do have the 2212-06 on the way and will try that set up first but may very well try your other recommendation on the second (especially if it's any quieter). The only thing I was confused about is if you guy's are using the 6x4e as a pusher or do I need to get the 6x4ep?
Thanks again, Robin
New Product Park Pilots Foam F-18 Hornet 44"WS carl rich Electric Ducted Fan Jet Talk 2 Jun 25, 2006 01:43 PM
F/A-18 Hornet Foam Parkflyer jetset44 Pusher Prop Jet Models 3262 Apr 14, 2005 02:38 PM
2 Seater F-18 Hornet Canopies... gbruce Electric Ducted Fan Jet Talk 8 Oct 06, 2003 01:39 AM
F/A-18 Hornet Plan Built daladiesman Electric Ducted Fan Jet Talk 1 Oct 29, 2002 10:40 PM
Hornet CP .... finally ... part 2 cyhyam Electric Heli Talk 90 Aug 05, 2001 09:40 PM
