The cam cover is the same part # bas my FA200Ti (FA170R3) All medium sized Saito singles now use that cam housing. You may have to file the gap wider between the the screws on the hall sensor holder just a little as this is a 2 web housing. Not a big deal. The other alternative is to remove one of the webs on the cam housing. (not a good idea IMO) Measure the outside width of the 2 webs between the screws of the cam housing & give that data to Adrian. The holes are slotted, the clearance for the housing webs is the most critical dimension here. My biggest concern would be the distance from the OD of the prop hub to the top edge of the cam housing @ the screw boss. This will determine the OD of the trigger magnet ring. Make sure Adrian has the dimension from the prop hub OD to the top of the cam housing screw boss. With these dimensions he should be able to make you a perfect fit. Prop hub exactly the same as FA91S. (determines ID & length of the magnet ring) Distance across the outside of the 2 cam housing webs. (determines the ID of the slot between the screw holes) Distance from the OD of the prop hub to the top of the cam housing screw boss. (determines the OD of the magnet ring) Your going to love this conversion. Experiment W/the timing. Run the minimum advance that gives you the maximum RPM. On my FA91S that was 35* BTDC. 200 more RPM than the 28* setting W/the same idle, starting & transition characteristics. DO NOT BE AFRAID OF MORE AGGESSIVE SPARK ADVANCE TIMING W/METHANOL FUEL Methanol has a slower burn rate than gasoline & it needs more ignition advance for top performance. See post #11 in the thread below for improvements W/CDI. http://www.rcgroups.com/forums/showthread.php?t=1774802 |
| Thread Tools | |
| Sold Nice Saito FA-45 Four Stroke Excellent Runner! $65.00 | stevster | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Jan 19, 2013 08:50 PM |
| Sold Saito FA-100 | spyder3g | Aircraft - Fuel - Engines and Accessories (FS/W) | 3 | Jan 12, 2013 07:35 PM |
| Discussion Aeroworks Exytra 300 .60 .90 With Saito FA 100 or Saito FA 115 ? | DjRedFoxx | Fuel Plane Talk | 13 | Sep 19, 2012 01:22 PM |
| Off Site Saito FA-91, FA-100, and FA270T on eBay now with no reserve! | muckemm | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Sep 11, 2012 11:58 AM |
| Question Saito FA-100GK/ FA-100 | t_predator90 | Engines | 0 | Apr 20, 2003 01:36 PM |
