Old Dec 25, 2013, 07:21 PM
Canada, QC, Montreal
Joined Nov 2008
Does this work with Naza M lite?
nguyen.tran is online now Find More Posts by nguyen.tran
Old Jan 01, 2014, 11:46 PM
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Happy New Year!
Here's a video, mostly captured with Mobius + SSG combo. Some are stabilized and slowed. Some raw...
Cali Road Trip (3 min 40 sec)
I just updated my KK2 to FW 1.6++ Rev 3, which should smooth out the jitters significantly. More to follow.
scrtsqrl is online now Find More Posts by scrtsqrl
Old Jan 02, 2014, 12:28 PM
scrtsqrl's Avatar
Joined Oct 2006
Recently updated my KK2's firmware with RC911's 1.6++ REV 3.
This reduced the SSG's servo jitter:
Improved Video with new RC911's KK2 FW 1.6++ REV 3 - Mobius + SSG (5 min 30 sec)
Compare:
Presidio Lawn - Youtube Edit (2 min 2 sec)
I need to reduce PI gains a bit...Overall, I'm really happy with the results.
Old Jan 03, 2014, 02:49 AM
Joined Jan 2014
I got SSG working with a crius aiop (v1.1), running mpng v3.0.1 r3. it's easy to mod the code of ArduCopter and MegaPirateNG to enable mixing.
The file you should change is:
Code:
AP_Mount.cpp
in
Code:
void AP_Mount::update_mount_position():
replace:
Code:
// write the results to the servos
    move_servo(_roll_idx, _roll_angle*10, _roll_angle_min*0.1, _roll_angle_max*0.1);
    move_servo(_tilt_idx, _tilt_angle*10, _tilt_angle_min*0.1, _tilt_angle_max*0.1);
    move_servo(_pan_idx,  _pan_angle*10,  _pan_angle_min*0.1,  _pan_angle_max*0.1);
with:
Code:
    move_servo(_roll_idx, (_tilt_angle+_roll_angle)*10, _roll_angle_min*0.1f, _roll_angle_max*0.1f);
    move_servo(_tilt_idx, (_tilt_angle-_roll_angle)*10, _tilt_angle_min*0.1f, _tilt_angle_max*0.1f);
    move_servo(_pan_idx,  _pan_angle*10,  _pan_angle_min*0.1f,  _pan_angle_max*0.1f);
(source: DIY drones from a user named: Rikard Andersson)
I got this code running now and works flawlessly!
homertje is offline Find More Posts by homertje
Old Jan 03, 2014, 05:10 AM
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
any chance to make this work on KK1?
asanovrus is offline Find More Posts by asanovrus
Old Jan 03, 2014, 09:21 AM
United Kingdom, England, Nottingham
Joined Aug 2012
motofox is offline Find More Posts by motofox
Old Jan 04, 2014, 06:03 AM
Keep Calm, and Carry On...
United States, UT
Joined Feb 2012
I have a KK2.0
Which FW is currently the best for Standalone Camstab??
seearestacey is offline Find More Posts by seearestacey
Old Jan 04, 2014, 03:55 PM
dexplorer
zidlov's Avatar
Hungary, Budapest
Joined Nov 2012
Code:
AP_Mount.cpp
in
Code:
replace:
Code:
with:
Code:
Thanks a lot!!! Just made a feature request for this to be included in the main code on apm forum, and now I stumbled upon your post. Will try this out on my apm, as soon as I have replaced the servo that I just (grrr) broke.
zidlov is online now Find More Posts by zidlov
Old Jan 05, 2014, 02:13 AM
Joined Mar 2010
http://www.youtube.com/watch?v=1CAle9A6OqY
Recorded in 720p ?
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Latest blog entry: Indoor 3d
Old Jan 13, 2014, 08:13 PM
surf monkey
changosurf's Avatar
United States, CA, San Diego
Joined Aug 2011
question: what, if any, protection are you guys using for your gopro on the SSG mount? I tried mounting the gopro with the skeleton case, but it was just too much weight for my SSG servos & design. I also don't really feel comfortable flying my GP naked on the SSG, so I'm looking for ideas on how to protect it well but as lightweight as possible.
changosurf is offline Find More Posts by changosurf
Old Jan 16, 2014, 02:27 AM
Expat
Japan
Joined Apr 2010
You could cover the lens with a strap. Then I used strong packing foam cut to shape. Zipties. Very light and customizable, but not waterproof.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Jan 16, 2014, 01:06 PM
Joined Aug 2012
got mine working in no time its awsome, its a bit jittery though somtimes so might have to look at the new servos im using which are turnigy metal gear cheapos from hk. ive suffered a lot from very bad vibrations which i narrowed down to the elastic bands i used to hold the mobius down. Now i have a tiewrap tightly holding the mobius onto a bed of hard foam stuff and its cured the bad vibes.
Old Jan 16, 2014, 06:40 PM
Scoot3r's Avatar
Canada, ON, Mississauga
Joined Jan 2014
Rapstraps might be better than just zip ties... I got mine from eBay shipped from the UK... search "rapstrap"
Scoot3r is online now Find More Posts by Scoot3r
Old Jan 20, 2014, 11:03 PM
Joined Jan 2014
Is there firmware for kk2.1?
Adan864 is offline Find More Posts by Adan864
Old Jan 24, 2014, 01:11 AM
Pilot In Command
Rtones's Avatar
United States, WA, College Place
Joined Jan 2014
I'm also curious about using the KK 2.1 board. I flashed mine with Steveis latest firmware and I noticed a camera stab menu item. Is it just plug in two servos and away you go? I don't have the equipment on hand to try it out at the moment.
Rtones is offline Find More Posts by Rtones
Discussion Lets build a DIY direct drive gimbal for the poor man hexa Multirotor Talk 155 May 14, 2013 08:01 AM
Discussion A simple poor mans vector thrust unit alfstan RC Kites 5 Oct 21, 2012 09:18 AM
Discussion Poor Man`s OSD problem GPS cabecinhas FPV Talk 4 Oct 12, 2012 12:00 AM
Discussion A poor man's Gimbal 450 /500/550 heli pirzol FPV Talk 5 Dec 26, 2011 04:58 AM
Poor man's Super Slow Stick fun flyer? uglyplane Parkflyers 1 Jul 03, 2003 11:54 AM
