Old Jul 04, 2015, 06:11 AM
Smyk is offline
Find More Posts by Smyk
Smyk's Avatar
Queens, NY
Joined Mar 2004
KK 2.1.5 flight controller and other gadgets
I would swear that I saw Jim mentioned using the KK 2.1 flight controller on airplane on one the thread here. I can not find it.
I do not fly multi-rotors yet. I do fly large scale gliders and towing planes
I am looking for combination of Flight controller/autopilot/OSD system that would flawlessly work with XPS bits and pieces (system) for safe return home in case of loosing the site the glider . It happens and I am getting older. On board monitoring system in these beasts is a must as well
I will appreciate any suggestions
Smyk is offline Find More Posts by Smyk
Old Jul 04, 2015, 09:40 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Look for "OpenAero2" and "OpenAeroSerial" here on RCGroups. I worked with David to implement the Xtreme protocol and the servo outputs to be like what I use for our products.
JimDrew is offline Find More Posts by JimDrew
Old Jul 08, 2015, 09:44 AM
twang is offline
Find More Posts by twang
twang's Avatar
Australia, QLD, King Scrub
Joined Jun 2005
KK board won't give you Return To Land. You need to look at APM2.x or Pixhawk for that. GPS is required for position info. there's even a range of mini APM boards if you're short of room. The learning curve is steep but worthwhile. The best value would probably be a Nano feeding CPPM to a mini APM2.x board with a Neo7 GPS embedded outside somewhere.
twang is offline Find More Posts by twang
Sold 1x KK 2.1.5 LCD Flight Controller w/Steveis 1.19s upupupandaway Aircraft - Electric - Multirotor (FS/W) 0 Jun 17, 2015 01:25 PM
Sold KK 2.1.5 flight control board plus avr programmer xoaster Aircraft - Electric - Multirotor (FS/W) 1 May 28, 2015 10:34 PM
New Product Flight Controller Case Multiwii SE 2.5 KK 2.0 & 2.1 psxdever Multirotor Electronics 0 Nov 07, 2014 02:11 AM
New Product Flight Controller Case Multiwii SE 2.5 KK 2.0 & 2.1 psxdever Multirotor Talk 0 Nov 06, 2014 11:58 PM
Sold KK 2.1.5 LCD Flight Controller + Buzzer w/ v1.17s2Pro firmware! *Pid's Tuned* upupupandaway Aircraft - Electric - Multirotor (FS/W) 2 Aug 12, 2014 02:19 PM
