Old Jan 26, 2016, 08:49 AM
DJI27 is offline
Find More Posts by DJI27
Open the bay doors... HAL
United States, OH, Mentor
Joined Jun 2013
Originally Posted by wkf94025 View Post
It's been a couple years since I married my 14SG to my P2, but I'm wondering if you need to run the Assistant software on the P2, after binding it with the radio, and calibrating the sticks. If you don't get full range of both sticks, the motor start sequence will never be reached.
Kelly
Looking for advice on where to start the binding process you mention above...
I've got a P1.1.1 and will replacing the DJI Rx with a Futaba R7008SB Rx.
Any good YouTube videos or online threads that you can recommend?
DJI27 is offline Find More Posts by DJI27
Old Jan 26, 2016, 09:22 AM
Witterings is offline
Find More Posts by Witterings
Beware Of The Shills !!!
Chichester Sussex
Joined Aug 2007
Originally Posted by DJI27 View Post
I'll be trying something similar on an old Phantom P1.1.1 that's uses a Naza M V2 f/c.
What Rx are you using on the hex?
Did you run into any problems when binding the 14SG to the hex?
It's the one that came with the TX and the same as mentioned in your next post.
You'll need to decide what mode you want to use the TX in 1st and if you're setting it up for S-Bus or not, it's 1 1/2 yrs since I've done it so can't give you any pointers I'm afraid but just worked through the manual to do it.
Witterings is offline Find More Posts by Witterings
Old Jan 27, 2016, 07:53 AM
DJI27 is offline
Joined Jun 2013
Ok.... thanks
After my last post to you, I tried Google and found some links/posts that might help me.
During my search I also found this Futaba video that touches on some of the Dual Rate/Expo settings that might help you.
Futaba 14SG Radio Programming Tips (22 min 41 sec)
P.S. The Dual Rate/Expo tip is somewhere near the 13 minute point of the video.
Old Jan 27, 2016, 11:17 AM
Chichester Sussex
Joined Aug 2007
Ok.... thanks
Cheers for that, I'll have a look through later although I'm 95% sure it's because the Naza needs to see 100% input with both sticks before it fires up the motors.
It's also made me realise on an estate agents job i went to do recently with my quad it just wouldn't start and I ended up coming home and it worked the second I'd driven all the way back ..... I think it was for the exact same reason
Old Today, 12:27 AM
dpilot007 is offline
Find More Posts by dpilot007
A buddy system for my wallet??
dpilot007's Avatar
Idaho Falls
Joined Apr 2009
Updating Firmware
Originally Posted by MalcolmHolt View Post
I appreciate your comments but my intention is to keep things simple. By updating the reference section I ensure that anyone referring to it will be presented with screen-shots and descriptions that reflect the current state of the radio. Those wishing to identify the changes to the radio’s software introduced at each update can easily refer to Futaba’s documentation.
The overwhelming feedback I receive from readers is that they are delighted that, unlike Futaba’s official manual, the book is kept up to date. That this is provided at no additional cost is seen as a bonus.
Malcom, do you cover in your book how to update the software on our radios?
~Don
dpilot007 is offline Find More Posts by dpilot007
Old Today, 03:58 AM
MalcolmHolt is online now
Find More Posts by MalcolmHolt
Brighton UK
Joined Dec 2010
~Don
No, the book is concerned solely with programming. In the introduction I refer the reader to Futaba's own documentation for all matters relating to installation and maintenance.
All you need to do is follow the instructions provided by Futaba with the update. One thing that seems to confuse people is that the downloaded files are not visible on the SD card. Your PC cannot read them without a File Utility. This doesn't matter. You don't need the File Utility or to see the files. Just put the SD card in the transmitter and follow Futaba's instructions. The transmitter will recognise the files and do the upgrade.
MalcolmHolt is online now Find More Posts by MalcolmHolt
Wanted Futaba 9cap\JRXP9303 Airplane\FUTABA 10C tx wanted Defacto Aircraft - General - Radio Equipment (FS/W) 8 Mar 26, 2013 07:54 PM
Whoops! The Futaba 8J S-FHSS is better than Futaba 18MZ S-FHSS! The 8J may get Telemetry... SimonChambers Radios 1 Jul 09, 2012 05:54 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - Electric - Helis (FS/W) 1 Jul 01, 2012 11:33 PM
Sold Genuine Futaba GY401 gyro with Futaba S9650 servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 3 Jun 27, 2012 10:47 PM
Sold Futaba S9650 Digital Servo + Futaba Gryo GY401 / Futaba 2.4GHz 8Ch R608FS wefao Aircraft - General - Radio Equipment (FS/W) 4 Mar 10, 2012 09:45 PM
