Old Aug 17, 2014, 11:42 AM
Joined Aug 2014
Question
Mounting gimbal on F450
Hi,
I have a stock DJI F450 with standard DJI landing legs and a goodluckbuy 2 axis gimbal for gopro currently mounted with zip ties to the base plate overhang at the front.
I've also ordered a DYS 3 axis gimbal for gopro.
I would like to tidy up the gimbal mounting when I put the DYS on, preferably using screws to attach to the base plate rather than zip ties as it looks like a bit of a bodge job at the moment.
Is there any standard mounting plates out there that will allow me to mount the DYS?
I saw this for the zenmuse but not sure it will work with the DYS:
http://www.goodluckbuy.com/3d-printi...f550-f450.html
JohnnyNegativity is online now Find More Posts by JohnnyNegativity
Old Aug 18, 2014, 10:44 PM
better in aerial
erikj180's Avatar
United States, WA, Everett
Joined Jul 2014
if it's in your budget, retracts?
These will be arriving at my home tomorrow: https://www.hobbyking.com/hobbyking/...dProduct=61703
Shipping from China was fast. I'll report back.
erikj180 is offline Find More Posts by erikj180
Old Aug 19, 2014, 01:16 AM
Joined Aug 2014
That looks perfect!
Keep me posted
Old Aug 20, 2014, 10:46 AM
Joined Aug 2014
How are you getting on with it erik?
Do the screws on the dys gimbal fit the holes on the landing gear base plate?
Old Sep 21, 2014, 01:25 PM
better in aerial
erikj180's Avatar
Joined Jul 2014
HobbyKing Quanam 450 class retracts
Sorry folks, have been too busy flying and building my new craft. They were relatively easy to install. I have a DJI 450 so I did not want to drill through the plate so I used 20# double stick tape and wire ties. I now have 45+ takeoff and landings on the gear. You do need to keep up with maintenance and inspect the wire ties, tape and set screws, I recommend at every battery change because they do loosen up, even with locktite.
Help! GoPro/Gimbal too close to rx on F450? jwk72 Multirotor Electronics 0 Dec 04, 2013 04:44 PM
Discussion brushless gimbal mounted on flip fpv pics inside bigemike Multirotor Electronics 5 Oct 26, 2013 07:18 AM
Discussion Mounted KK2 on Top Deck of DJI F450 - Protective Cover Available? boiko Multirotor Talk 2 Apr 27, 2013 06:46 AM
Discussion Did anyone ever use a gimbal mounted on a gimbal?! neavissa Multirotor Electronics 9 Mar 14, 2013 06:11 PM
