Old Jul 08, 2013, 09:03 PM
Turbobearcat's Avatar
Joined Aug 2011
BlitzRCWorks F-117 64mm EDF
Has anybody done a review for the JET?
I have one on order and I wanted to see how much information is out there on this one but I seem to find limited information. Does Blitzrcworks make this kit or somebody else?
and can I use the the 2 axis Flight stabilizer with it? I would think it would be an ideal jet to use one. works great for my F-22!!
Turbobearcat is offline Find More Posts by Turbobearcat
Old Jul 09, 2013, 11:10 AM
Joined Aug 2011
I am really surprised that nobody owns one and can't share....
Old Jul 09, 2013, 12:39 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
Turbo, I bought the kit version, upgraded the motor and added a 45 amp esc. Sold it after two flights, just didn't like anything about it (other than its looks). That's just my opinion though.
JGuilty13 is offline Find More Posts by JGuilty13
Old Jul 09, 2013, 12:47 PM
Joined Aug 2011
Was it that boring to fly?
Old Jul 09, 2013, 08:30 PM
Joined May 2013
The Gyro will work well. I have the f-35 and have tossed it in my 800mm p51 mustang. I'm guessing the way the f-117 handles isn't that great. It looks cool but also looks like it handles like a shoebox.
Mulnik82 is offline Find More Posts by Mulnik82
Old Jul 09, 2013, 08:33 PM
Joined Aug 2011
F-117 is basically a Delta wing so you would think it flies well- like my XB-70 so I guess I will find out later this week. but I am thinking about adding the gyro to it the jet but I will fly it first and then go from there.
Old Jul 09, 2013, 08:42 PM
JGuilty13's Avatar
Joined Nov 2005
Turbo, I've had quite a few deltas and still fly a few on a regular basis (fms Rafale and mirage 4000) and they fly like an absolute dream. The F117 was a different bird and acted completely different in its flight characteristics,.....like I said, two flights and it was on Craigslist.
Old Jul 10, 2013, 07:34 PM
Joined Aug 2011
I wish you could go into details on the flight characteristic what was different...would love to know before this thing goes up in the air.
Old Jul 12, 2013, 08:51 AM
Joined Aug 2011
Well interesting on how this was built but they don't give you a lot of room to place the RX and the battery compartment is TIGHT - I have a 1800mah 25c 4 cell in there hoping this will work out in the power department. but if not I am sure I have a battery that will work somewhere
Old Jul 12, 2013, 08:51 PM
Joined Jul 2005
f117
I have had the 64mm sitting around for months from Nitroplanes. I hogged out foam with sand paper and installed a 70mm. For the battery compartment I cut that away and I had a old battery compartment from a recked Starmax 64 mm f18. I glued that in its place and can put a larger 4 cell in it. I put the compartment up against the hole where the wires go through for the servos. Just have to finish this when I get time.
shurlock1 is offline Find More Posts by shurlock1
Old Jul 25, 2013, 10:19 PM
Joined Aug 2011
Mine flew for the first time tonight before it got too dark.. I was surprised thinking it was going to be slow..not the case and it turned very nice. The only problem I had was turning while the airspeed dropped the tail (like a SAbre dance) but I recovered and landed but I have learned that the F-117 flies like a delta to a point...then you must figure out the rest from there..but I can't wait to fly it again..
Old Jul 25, 2013, 10:20 PM
Joined Aug 2011
Did I say I am using a 1800mah 25c 3 cell....I think this jet is a tad bit tail heavy as well..but for now I need to get it ready for the next flight!
Old Jul 26, 2013, 07:42 AM
Joined Aug 2011
Does anybody know what the CG should be for this jet? I think it says 460mm from the nose but that seems to make it tail heavy.. ideas?
Old Jul 29, 2013, 09:13 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
I've flown this jet for years. It's pretty draggy, takes lots of power to fly fast. Nice scale fly bys, gets a little Dutch roll if you don't land power on. Overall it is very forgiving, needs at least 4500 KV on 3s to get out of it's own way.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jul 31, 2013, 08:29 AM
Joined Aug 2011
I like the way it flies but I am not sure if I would want to upgrade it yet on power..
Does yours have the bomb bay doors that open?
Sold BlitzRcWorks F-117 Stealth whirl10 Aircraft - Electric - Jets (FS/W) 7 Jan 17, 2013 01:03 AM
Sold BlitzRcWorks F-117 Stealth whirl10 Aircraft - Fuel - Jets (FS/W) 2 Jan 11, 2013 11:47 PM
Question BlitzRCworks 64mm EDF Phanton F-4? KenSue Electric Plane Talk 7 Dec 08, 2011 01:12 PM
