Old Jan 01, 2015, 03:42 PM
clearchrome2 is offline
Find More Posts by clearchrome2
Joined Jan 2015
HELP Can't get my DX8 working with my SKYZONE Head Tracking
Hi there,
Im trying to setup my SKYZONE googles head tracking to work with my Spektrum DX8 Transmitter.
Ive watch everything solutions available on the web and nothing is helping me for my problem.
I basically want to plug the headtracking of my new SKYZONE googles into my DX8 so that when I press the trainer button, it (the googles) controls ch7 and 8 as a slave.
What I have done so far:
1- I modified the cable so that it can fit into a mono plug I had lying around. (could not find any Stereo->Mono plug)
2- I programmed the DX8 (as Programmable master) and SKYZONE to use CH 7 and CH 8 as slaves.
3- Im using an Oscilloscope to monitor the SkyZone signal PWM output port and its working fine as expected.
The problem is when I connect my head tracking cable to the DX8 trainer port, the signal gets distorted on my scope ...like a ramp and instead of using a 0v -5v logic , i see 2v -> 3v logic.
I tried all combination for the connections.....nothing works.
When I press the trainer button, I get WARNING NO SLAVE error message because the signal is not detected correctly on the trainer port! Must be because of the distorted signal in my opinion...
NOTES:
- I do press the TRAINER button when I test the connection in Master mode , I get the " NO SLAVE" warning message.
-The DX8 trainer port is correctly connected to the skyzone port.
-The DX8 is set in master mode (button is ON to accept PPM data from trainer port)
-I also use the the monitor in my DX8 to see if any changes occurs when I move my googles around.
What else am I missing here?.
clearchrome2 is offline Find More Posts by clearchrome2
Old Jan 01, 2015, 04:09 PM
Joined Jan 2015
Here are some pictures of what im talking out.
Cable coming out of the skyzone head tracking has 3 leads, black / red / yellow.
I don't use the yellow.
Black is the PPM , Red is the Ground.
Scope shot of the output of the SkyZ HeadT output
Is the mono cable going to the trainer port of the DX8
Slave mode, will output data on the trainer port (We don't want that for Head Tracking as we want it to be an input data)
Is the scope shot of the trainer port when in Slave mode (used for simulators) and works fine in my case.
DX8 in Master mode but with the programmable master turned on.
Connection between Head tracking and trainer port.
Dx8 in master mode, and head tracking on ...I get this distored signal!
Is that correct?
Error message when pressing the Trainer button on the DX8.
Voila
Old Jan 01, 2015, 04:15 PM
Joined Jan 2015
My DX8 setup
This is what my setup as programmable master setting looks like in the DX8 for the head tracking.
Old Jan 12, 2015, 01:56 PM
Joined Jan 2015
Here are 3 videos done on the actual problem:
http://youtu.be/
http://youtu.be/
Old Jan 17, 2015, 09:23 AM
Joined Jan 2015
I managed to make it work! Finally
Old Jan 22, 2015, 06:32 PM
Joined Jan 2015
My Solution
Yeah ...Thats the tester I used for debugging the timings the DX8 receives.
Actually Skyzone is using a frame of 22.5ms ....my Dx8 Specktrum need between 22ms or 11ms to synchronize and detect (process) the signal.
You basically need to convert it using digital form ...I use a Arduino Nano v3.0.
Old Feb 06, 2016, 09:48 PM
clearchrome is offline
Joined Dec 2014
Crappy support here!
Thanks guys for offering me NO support at all!
The karma will be returned! Don't you worry
clearchrome is offline Find More Posts by clearchrome
Old Mar 13, 2016, 11:35 AM
Psychosix is offline
Find More Posts by Psychosix
Blue skies!
United Kingdom, Clacton-on-Sea
Joined Sep 2015
Hey man. Shame you didn't get any responses to this. Thank for doing the decent thing and posting your resolution though
I'm looking at getting my DX6i working with SkyZones head tracking, but am not sure it's worth the hassle. May finally be time to buy a Taranis!
Psychosix is offline Find More Posts by Psychosix
Old Mar 13, 2016, 04:59 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
dx6i never worked with any head tracker. extremely limited item that Tx.
DX6 will though
Taranis yes!
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Mar 19, 2016, 08:00 PM
Blue skies!
Joined Sep 2015
DX6 will though
Taranis yes!
Thanks man. I've discovered the DX6i is useless for this stuff, as you said. I'll order a Taranis.
In the meantime, using a mates DX18 stealth for some fpv mustang tests. We had a load of trouble with the adapted mono cable. Assume it's the same problem clearchrome2 had.. need 22.5ms and can only set 11-22ms on tx.
Discussion Can't get my Castle Creations 25A ESCs to work. Made in Austria Multirotor Electronics 5 Jan 26, 2015 11:25 PM
Discussion Easiest radio to use with Skyzone head tracking peteinoz2 FPV Equipment 1 Nov 02, 2014 05:15 PM
Discussion I can't get my fpv system to work! themoonkity FPV Equipment 4 Jan 17, 2014 04:01 PM
Help! I can't get FPV working with my Sony Nex-5N - help! RandysWay FPV Talk 1 Oct 26, 2013 12:04 AM
Discussion Can't get my Transmitter working with PPJoy and PICJoy, though it was working before neu Simulators 0 Jul 13, 2007 06:18 PM
