Old Apr 22, 2015, 11:11 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Cathay Stray View Post
Interesting then what the ideal width would be given very thin and flat cross section...
Ad absurdum the biquad can be just pinholes in the middle of solid squares, on the opposite the width can be equal to the wire's diameter. Either way would perhaps not be the best...
It depends on the frequency, but my guess is that ~2-3mm thick on 1.3Ghz would do well. For 2.4GHz 1-2mm should work. Don't make the elements too thick or it won't work correctly.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 22, 2015, 11:36 PM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
Thickness is a constant value with copper laminated board
I can only take width as a variable.
Cathay Stray is offline Find More Posts by Cathay Stray
Old May 18, 2015, 06:33 PM
elewon is offline
Find More Posts by elewon
elewon's Avatar
United States, CA, Sacramento
Joined Feb 2013
Just saw this thread and going to build a BiQ for my 2.4GHz control Tx tonight!
One question - the cable I have is RG58 AU and the impedance is apparently 53.2ohm. Will I have a problem with mismatch and high SWR? I'm planning to use 16AWG copper wire for the driven and copper clad board for reflector.
elewon is offline Find More Posts by elewon
Old May 20, 2015, 08:27 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You should be ok. I used RG58/u for many 2.4GHz antennas.
-Alex
Old May 20, 2015, 11:29 PM
elewon is offline
elewon's Avatar
Joined Feb 2013
Alex, thanks. I went ahead and built it. Haven't had a chance to range test it yet but same range as the stock bazooka dipole has been confirmed.
Change of plans though and I bet this is the cheapest BiQ ever! The driven is two paper clips (~1mm thick) bent to shape and soldered. The reflector is aluminum foil taped over a piece of foam board. Used pieces of coffee stirrer hot glued for support. Will share the build pictures if I'm happy with the results.
Old May 28, 2015, 01:04 AM
elewon is offline
elewon's Avatar
Joined Feb 2013
So the Bi Quad seems to be working, don't know how well tuned it is though. Seems like Tx battery is draining faster but I'm definitely getting better range. Did a range check with the Tx on the ground and it's around 1100ft. Is that reasonable for LOS with 2.4G Tx, 17dbm power?
The other test was at the bluff where I go sloping. I'd get like 100ft with the stock antenna. Don't know if it was due to low power or multipaths but I was getting way short a range at that location. So right after take off, the control would get intermittent and really scary. Very happy that the receiver performs much better with BiQ on the Tx. Had a blast flying my wing for over 15mins with really smooth control.
Awesome and thanks again for sharing!
Old Jun 02, 2015, 04:46 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Sounds to me like it is tuned well enough. Great to see an ultra cheap DIY unit working well.
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
