Old Mar 26, 2011, 06:25 PM
Jim Hatch is offline
Find More Posts by Jim Hatch
MacBeth, SC
Joined Aug 2007
Hot wire wing cores
Hey folks,
Some mighty talented individuals here doing some neat stuff. But I'm
surprised I don't see any hot wire wings being used on any of these
works of art and aeronautical engineering. Anyone play with hot wire
cutters and come up with any neat wings for small planes? I think it
would be neat if I could carve a hotwire wing from 1/2 inch bluecore
for small planes. Warm regards, Jim
Jim Hatch is offline Find More Posts by Jim Hatch
Old Mar 26, 2011, 06:57 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
You'll catch someone here building a wing cut with hot wire from time to time. as for my own self, don't have a HWC yet but when I do get one together I'll be going for something like this, http://www.rcgroups.com/forums/attac...mentid=3697527 to experiment with.
Quick61 is offline Find More Posts by Quick61
Old Mar 26, 2011, 08:33 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Slope flyers, combat fliers make their own wings.
Make a bow
hook to
Brushed ESC
controlled by
Receiver, Transmitter
powered by
Battery, power supply
My favorite youtube on foam core cutting
Hotwire demonstration (3 min 30 sec)
catchy tune too!
rick.benjamin is offline Find More Posts by rick.benjamin
Old Mar 27, 2011, 02:51 PM
MacBeth, SC
Joined Aug 2007
Hi Rick,
OK, you have peaked my curiosity. Can you point me toward instructions or video on
cutting wings with lipo and esc? I don't want to fry any gear, but it would be neat if
I found I already had the necessary gear. Thanks! Warm regards, Jim
Old Mar 27, 2011, 04:11 PM
flyd7 is offline
Find More Posts by flyd7
flyd7
United States, OR, Eugene
Joined Feb 2008
Originally Posted by Jim Hatch View Post
Hi Rick,
you wont fry any thing. i still use my old fm radio ,Rx and 30 amp esc[brushed] just make a bow outta pvc or whatever,that has slight flex..
, thread in eyebolts to ends ,string your wire semi tuant, [i use E-strings] hook up your long leadwire [ electrical 6 ft or so] to the esc ,[like your hooking up a brushed motor],the other end of this wire will have small alligator clips fastened to the ends. clip these onto the furthest end of your wired bow!
now power up your tx like normal. making sure your throttle and trim are DOWN! plug in your batt. ...and experiment with the heat..
flyd7 is offline Find More Posts by flyd7
Old Mar 28, 2011, 06:41 AM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Just note if your ESC supports Lipos
You could use a wattmeter between the battery and esc to monitor battery drain.
Old Mar 28, 2011, 10:39 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
ive built about 8 hotwire planes with only 1 failing to fly the others were great fliers i use a car battery charger and a hot wire bow made from timber using fishing wire trace as the cutting wire im on the low end as far as heat goes i could use more but i dont have a better power supply yet heres a couple i have cut 23" and 44" i also cut a 30" all the same design just scaled up from the 23" flying wing i use profili and the zagi 12 airfoil in the last video at the end is full power off glide check it out bloody amazing how floaty this design is and it weighs over 700 grams i can supply u with dimensions if u like
23inch 73-80mph 3000kv 25g motor (2 min 1 sec)
30inch WS 3000kv motor 70mph - 112kph (1 min 53 sec)
PICT0006 (1 min 51 sec)
gazza2003au is offline Find More Posts by gazza2003au
Old Mar 28, 2011, 11:09 AM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Lipo brused esc and tx work very well , plus you probably already have them, just slap a bow together made out of old scrap and grab some element wire from an old bar heater or guitar string and practice.
scousethief is offline Find More Posts by scousethief
Old Mar 28, 2011, 01:41 PM
MacBeth, SC
Joined Aug 2007
Thanks for the info folks. I'm looking for the capability to make 15 to 24 inch flat
bottomed wing halves for a total of 30 to 48 inch wings. Generally more of the
smaller ones. Just straight cut, non-tapered with 6 to 10 inch root. Primarily looking
to make stable low speed wings, entirely capable of flying at less than the speed of
thought for an Olde Phart that just enjoys Cub and Taylor style flight. Thanks for the
input folks and please continue to share your thoughts. Warm regards, Jim
Old Mar 28, 2011, 02:11 PM
Sydney, Australia
Joined Jul 2003
cutting 48" wing cores is a lot harder than cutting smaller cores its easier to mess up i found the most easiest method cutting cores is to keep one side of the bow at one position and move the other end of the bow around the template
Old Mar 28, 2011, 04:09 PM
MacBeth, SC
Joined Aug 2007
Hi Gaza,
I want be cutting any 48 inch cores, but rather two 24 inch wings. However,
most would be in the 36 inch total wing range. Something Blue Wonder 1300 size. LOL! It's my "Go To" motor. Warm regards, Jim
Old Mar 28, 2011, 04:19 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I've dabbled in hotwire wings; I have a nice ~17" bow with a Nintendo GameCube power adapter and some Sig nichrome wire. Works great.
However, my favorite/most useful hotwire tool has to be the 'table saw' I made. It's a piece of painted plywood (from an old shelving unit) with a wire strung through a hole in its center. It makes cutting big pieces of foam (1.5" thick) really easy and quick; I originally made it so that I could cut blocky wing blanks for my bow cutter to turn into wings, but I've found many other uses for it. I use an alligator clip for power regulation (move it up and down the wire) so I can go from a solid black wire to a bright orange, flaming hot spruce-stock-cutting monster
Piece is offline Find More Posts by Piece
Old Mar 28, 2011, 04:50 PM
Sydney, Australia
Joined Jul 2003
Hi Gaza,
yeah i knew that if u feel confident u can steadily move both sides of the bow without stopping either side u could make a 26 inch bow to cut each 24 inch core but i find its hard to keep the steady movement of the bow if u stop one side it melts the foam and gives a horrible finish as the root moves quicker than the tip if u use the other method i mentions where one side of the bow stays in one position and the other side of the bow cuts the airfoil u need a much longer bow to cut the same size core but allows and easier cut
Old Mar 29, 2011, 07:42 AM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
http://www.rcgroups.com/forums/showthread.php?t=1290343
my first(with new bow) test wing flies
Prime_8 is offline Find More Posts by Prime_8
Old Mar 29, 2011, 12:03 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
I wouldn't Putz around with my Lipos' ESC and TX just to heat up a wire.
Look at this:
http://www.aircraftspruce.com/catalo...hotwirekit.php
Either buy the thing OR study it to DIY a clone.
Use Stainless Steel braided wire, either Control Line OR fishing leader as the cutting wire .. It's the V best.
Bare is offline Find More Posts by Bare
Discussion Foam Wing Cores MWCores Combat 6 Dec 15, 2010 07:58 PM
For Sale Feather Cut Foam wing machine (Hot wire foam cutter) thermalsurfer Aircraft - General - Miscellaneous (FS/W) 0 Oct 17, 2010 08:51 PM
Link Video here, manually cutting wing cores with positive templates and Hot wire dougmontgomery Slope 3 Dec 13, 2006 11:12 AM
Discussion Hot wire cutter for wing cores... cherokeepilot The Builders Workshop 11 Mar 18, 2006 05:17 PM
Question boaring wire holes in wing cores mlcleary Slope 2 Jan 31, 2003 11:33 AM
