Old Jul 13, 2005, 11:07 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
group order: 40mm dia,18slot laminations. Turned parts can now be ordered.
Ralph Okon (a.k.a. www.powerditto.de) is putting together a group order for 40mm. diameter, 18pole statorlaminations. A minimum order of 5000 laminations is needed to start a production run. Minimum order per person is 50. One 0.20mm lamination (NO20 iron quality) will cost 0.5. Flux ring and frontplates will probably also be available by then. Keep in mind, this is not a business for Ralph, he's in the business of curing people
More info, drawings:
http://www.powercroco.de/crocogrund.html
You can place your order here:
www.neodyme-magneten.de
-> shop
-> English flag
David Theunissen's Crocodile pages, lots of info:
http://www.flyelectric.ukgateway.net/
-> diy brushless motors
-> Crocodile motors
Ralp Okon's Crocodile pages (English & German)
www.powercroco.de
Wolfgang Mrotzek's Crocodile pages:
http://goldeneye.ethz.ch/motoren/electric/index_EN
-> Motore
-> electric engines
-> Krokodil
Infrared camera video from Wolfgang's site, 1.7MByte
http://goldeneye.ethz.ch/motoren/ele...ermokroko.mpeg
Original German thread:
http://www.rclineforum.de/forum/thre...threadid=88112
'Crocodile' subforum, in German but they don't mind posts in English:
www.rclineforum.de
-> E-Motoren, Regler & Steller
-> Projekt Crocodile
edit: added www.neodyme-magneten.de and several homepages
Vriendelijke groeten Ron van Sommeren
diy motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, August 28th, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 13, 2005, 12:17 PM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
If people right click on the link and select translate it works ok.
olmod is offline Find More Posts by olmod
Old Jul 13, 2005, 12:22 PM
Former User
powerditto is offline Find More Posts by powerditto
Old Jul 13, 2005, 05:44 PM
foamforce pilot
dicker's Avatar
Deutschland, Schleswig-Holstein, Braak
Joined Jan 2004
heya - I'm registered here
just found out
well, I tried my best to translate the page, the english version is linked on top of the german site.
yours Julian
dicker is offline Find More Posts by dicker
Old Jul 13, 2005, 08:36 PM
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Are they really only .2 mm thick?
I'm tempted to order some. Would you be able to ship some to the US?
-Hans
flybike is offline Find More Posts by flybike
Old Jul 14, 2005, 12:38 AM
Former User
Old Jul 14, 2005, 08:53 AM
Joined Feb 2001
@Hans/Flybike
The thinner the better: less (parasetic) eddy current losses, higher efficiency.
Old Jul 14, 2005, 07:31 PM
Joined Jul 2005
Wow.
So all 50 (not counting wrapping and maybe whatever separates them) add up to 1cm?
eternauta3k is offline Find More Posts by eternauta3k
Old Jul 15, 2005, 01:38 AM
Former User
Old Jul 16, 2005, 01:28 PM
UK
Joined Aug 2000
I may have missed it but what is the size of the inside hole? (for the bearing).
David T is offline Find More Posts by David T
Old Jul 16, 2005, 02:56 PM
Former User
Old Jul 16, 2005, 05:16 PM
UK
Joined Aug 2000
Ralph, have you considered a larger bore to take more robust bearings? I'm interested in swinging larger props (20-24 inches) in scale planes and it appears to me that I would have to use an 8x12mm bearing on the 'bell' end. These are at the bottom of the load range. A 16 or 18mm bore would allow 7x14 or 8x16mm bearings which can handle significantly greater loads.
Your views? Regards, David.
Old Jul 17, 2005, 04:06 AM
Former User
Old Jul 17, 2005, 05:14 PM
Former User
Old Jul 18, 2005, 09:35 PM
San Antonio, Texas
Joined Sep 2003
Ok, I just ordered the minimum number because I just don't want
to be left out. This looks like a truly exciting project. Do I need to order more?
Can you give some more details about the motor you have in mind?
I'm not really technical so I'm looking for Power converted in a way
I can understand. Will swing XX x XX prop. Is equivalent to X spec. motor
Will fly X helicopter. What kind of maximum Watts?
When will cans be available? Will there be a tutorial for this specific motor?
Thanks for the info.
Oz
ozzie111 is offline Find More Posts by ozzie111
high-torque diy motor, 40mm dia. 18slot stator Ron van Sommeren Scale Kit/Scratch Built 0 Jul 21, 2005 06:59 PM
turned parts for 40mm dia,18slot diy motor Ron van Sommeren Power Systems 0 Jul 21, 2005 06:39 PM
