Old Dec 02, 2014, 10:32 PM
Joined Nov 2014
File for HK DLG dual aileron - 4 channel AR400 rec
Here is the file I modified from Sherman Knight's original.
Regards,
Ballardmarc is offline Find More Posts by Ballardmarc
Old Dec 03, 2014, 01:49 PM
Sherman Knight
Kirkland Washington
Joined Feb 2002
SPM file for Handlaunch
I need some testing on this file. It is for hand launch gliders. Five flight modes with launch on the B switch. Landing mode turned on with the flap stick with elevator compensation. TE changes in each FM. Camber change on the left slider. Voices for FM changes. Timers with count down and count up.
This file will work on a DX6, DX9 and DX18G2. (Should work on a DX18)
Install the SPM file. Set radio to Cruise mode. Turn on the glider. Adjust all the clevises so control surfaces are neutral. Check for correct servo movement. Servo reverse if necessary. If it was, readjust clevis if necessary.
Everything should work. Different TE, Travel Rates, Differential, Ail > Rud for each flight mode. Adjust for your glider and personal preference.
Landing mode is activated by pulling down the Flap stick. Use Camber System to adjust flap settings. Use Mix 1 to adjust elevator compensation in landing mode.
For more information see the Guide here at post #168. It is for a six servo sailplane, but it WILLhelp. http://www.rcgroups.com/forums/showthread.php?t=1679092&highlight=dx18+sailplan
Sherman Knight
Team Horizon Hobby Sailplane.
duworm is offline Find More Posts by duworm
Old Dec 13, 2014, 03:32 AM
United States, CO, Lakewood
Joined Jan 2011
Sherman,
I get a "2373: ' ' Unknown field variable" error when I try to import the HLG spm file into my DX9.
--Jason
Jasong911 is online now Find More Posts by Jasong911
Old Dec 13, 2014, 01:06 PM
Sherman Knight
Kirkland Washington
Joined Feb 2002
Originally Posted by Jasong911 View Post
Sherman,
--Jason
Hi Jason, thanks for the information. This error occurs when versions of the spm file and the firmware in the radio don't align.
I will down load the file later today and check it out to make sure I mistakenly posted and old version. In the meantime, make sure your DX9 has the latest firmware update and try it again. If a firmware update works for you, please let me know.
Sherman Knight
Old Dec 13, 2014, 02:49 PM
Joined Jan 2011
I think I am one minor update back on the firmware. I will update radio and try again
EDIT--I updated the radio to 1.06 and tried again. Same error...
--Jason
BTW-you the Man! Thanks for all the work on this stuff...
New Product Spektrum DX18 Victory Pete Radios 10017 Dec 12, 2014 11:03 PM
Discussion Spektrum DX18 Hoot Multi Task F3X 126 Dec 11, 2014 12:13 PM
Sold New in Box Spektrum DX18 PatternFlyer Aircraft - General - Radio Equipment (FS/W) 10 Jun 25, 2012 09:32 PM
Discussion Spektrum DX18 owners thread Minimog Radios 0 Jun 25, 2012 01:05 PM
