Old Sep 10, 2014, 07:07 PM
United States, LA, St Francisville
Joined Apr 2014
I called Horizon, and they suggested oiling my motor. Would WD-40 work?
Eagle2Nitro is online now Find More Posts by Eagle2Nitro
Old Sep 10, 2014, 07:31 PM
Canada, ON, Mississauga
Joined Oct 2011
WD-40 is a perfume that evaporates quickly. Use a real oil.
I use SAE20 oil made for electric motors.
If you remove the motor (one screw on the back of the motor mount) then put one drop of oil in the rear hole.
Oil the front bearing with a drop of oil on a toothpick.
Audioguru is online now Find More Posts by Audioguru
Old Sep 10, 2014, 07:48 PM
Just a whisper in the wind
Birds of Prey's Avatar
United States, OH, Chillicothe
Joined Jul 2012
You should get this http://www.hobbyking.com/hobbyking/s...aring_oil.html I use it on all of my BL motors, its awesome and it doesn't turn to gunk. Very high grade oil, you'll be happy as a pig in siht.
Birds of Prey is offline Find More Posts by Birds of Prey
Old Sep 10, 2014, 11:48 PM
Gopher huntin' stick jockey
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
No. Don't use it in this app. Also, conventional electric motor oils such as 3-IN-ONE will simply fly out of the bearings within a few flights, due to the high centrifugal force that's generated at the RPM these motors spin. It's best to choose a lubricant that forms a molecular bond with the metal & is specifically intended to be used on high-speed motor ball-bearings - such as Hyperion's brushless motor bearing oil or Scorpion's brushless motor bearing oil. There are others, as well.
Joel
turboparker is online now Find More Posts by turboparker
Old Sep 11, 2014, 11:15 AM
Joined Apr 2014
But isn't 3-in-1 designed for brushless motors?
http://www.walmart.com/ip/WD-40-3-IN...-lube/21377719
I want to fix the Yak's motor before I go the the Flying Field on Saturday, so I need something that I can get locally. I called the LHS and they said that they don't carry any lubricants.
Old Sep 11, 2014, 12:10 PM
Joined Apr 2014
Can someone give me some input? Today is the only available time to get into town to buy any motor oil.
Old Sep 11, 2014, 12:23 PM
East Bethel, MN USA
Joined Jul 2009
3-IN-ONE is primarily intended for 1/4 HP & larger electric motors such as the ones that power industrial equipment, washing machines, table saws, drill-presses, grinders, furnace blowers, etc. Most of those operate at relatively low RPM, and many of them use Oilite bushings instead of ball or roller bearings. Oil slinging is rarely a concern in those apps.
If that's all you can find locally, definitely use it. It will do the job in a pinch, but it will probably get thrown out of the bearings relatively quickly. BTW - be sure to rotate the motor by hand & carefully check for roughness. Depending upon the plane's history, it's possible that a speck of debris made its way into one of the bearings.
Joel
Old Sep 12, 2014, 09:15 PM
Joined Oct 2011
I have an E-Flite 2500kv BL motor from a UMX Carbon Cub that the front magnet ring can pull out of the rear coils part (maybe a c-clip is missing?) . I do not see ball bearing bushings anywhere, it looks like metal on metal. If it ever had a c-clip then it was the thrust bearing when it is pulling.
Old Sep 14, 2014, 09:46 AM
USA, NY, Poughkeepsie
Joined Mar 2010
Can anyone tell me what adapter I need to charge these 2 cells with my Thunder power charger ?
rcguy1958 is offline Find More Posts by rcguy1958
Old Sep 14, 2014, 08:27 PM
United States, TN, Smyrna
Joined Feb 2014
http://www.hobbyking.com/hobbyking/s...2S_Lipoly.html
You can charge six at one time with these
moteasa is online now Find More Posts by moteasa
Old Yesterday, 03:24 AM
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Does the Thunder Power charger come with an XH plug?
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Parkzone Ka8 telemetry install
New Product E-flite UMX MiG 15 Ducted Fan Jet with AS3X Bowerz Micro Ready-to-Fly 138 Jul 19, 2014 03:58 PM
Sold E-Flite UMX Sbach 342 3D (AS3X) with spares kellymacdaddio Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2013 10:36 PM
Article Horizon Hobby E-flite UMX Gee Bee R2 BNF With AS3X Technology Review Michael Heer Micro Ready-to-Fly 3 Jan 26, 2013 07:37 AM
New Product E-Flite UMX Mig 15 EDF with AS3X Diesel6401 Foamy EDFs 5 Jan 17, 2012 01:36 PM
New Product E-Flite UMX Mig 15 with AS3X! Bowerz Scratchbuilt Indoor and Micro Models 4 Jan 16, 2012 07:02 PM
