Old Nov 19, 2014, 04:26 PM
Joined Nov 2014
Photo of three currently known version of SunRise slim 40A ESC
At the bottom on photo - my happiness "half-power" ESC.
Changes from previos version: return from 8012 to 8028 FETs, return inverted input signal circuit, return filtering capacitor for AREF pin.
Changes from first version: 6CW transistors instead of 6C.
akwa38 is offline Find More Posts by akwa38
Old Nov 20, 2014, 10:42 PM
RS2K's Avatar
United States, KS, Wichita
Joined Apr 2007
Quick check to make sure I'm doing this right.
Step 1. I buy this ESC:
Turnigy Plush 40A
http://www.hobbyking.com/hobbyking/s...ontroller.html
Step 2. I cut off the heatshrink to reveal this:
Step 3. I solder a servo lead to the red black and white marks on the image above
Step 4. I flash BLheli onto the ESC through the connector I soldered on with this:
http://www.hobbyking.com/hobbyking/s...opter_ESC.html
Step 5. I can then use the USB programmer to change BLheli settings in the future.
RS2K is online now Find More Posts by RS2K
Old Nov 21, 2014, 03:23 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Turnigy Plush 40A
I think, you should stop here and think about your requirements.
Think again... And again.
ABLomas is online now Find More Posts by ABLomas
Old Nov 21, 2014, 10:05 AM
RS2K's Avatar
Joined Apr 2007
I'm not sure what you mean. I'm looking for an ESC that can handle 6s and uses blheli and works with damped light mode. The plan is to use this ESC on a hex.
Old Nov 22, 2014, 05:15 AM
Joined Dec 2009
Should be a good choice. And the programming stick will work.
But maybe if you do not need the bec, there are lighter ESCs out there.
sskaug is online now Find More Posts by sskaug
Old Nov 22, 2014, 08:49 AM
RS2K's Avatar
Joined Apr 2007
Thanks. I did a search for 6s capable ESCs in the PDF that listed blheli compatible ESCs that support damped light and this is the lightest of the few I found. Can you give a recommendation?
Old Nov 22, 2014, 11:40 AM
Joined Dec 2009
What about the HW platinum pro 30A opto?
Old Nov 22, 2014, 11:53 AM
RS2K's Avatar
Joined Apr 2007
Oops, was mixing some things up. You're right on that ESC. Thanks for the info.
Old Yesterday, 05:01 AM
United States, CA, Citrus Heights
Joined Jun 2013
Anyone tried flashing hw xrotor series?
artemen is online now Find More Posts by artemen
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 03:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 10:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 10:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 03:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 03:31 PM
