Old Aug 15, 2014, 01:54 AM
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
1/5 scale CMP cub converted to electric?
Hey just picked up one of the CMP Cubs from Hobbyking. 90 inch wingspan, for $220, so why not? https://www.hobbyking.com/hobbyking/...dProduct=52316 arrived in 3 days from when I ordered it - nice.
Flying buddies keep telling me how much better big models are, so here we go. I mainly do FPV with a mix of foamies and some built-up balsa planes too. I like how it will be easier to get very detailed scale cockpit for flying FPV from the cockpit, as I do. And I likehow it can carry my Benedini sound system with 4 inch speaker for synth'd Cub sounds.
I don't want aerobatic power. Just floatiness and endurance. I have a couple 5000mah 6S zippy compacts I hope to use, even though I know it is easier to go to 10S or so.
ordered up this 5055 turnigy motor. Rated to max of 1400 Watts. OK I realize that might be hard to achieve with 6S. Sounds like it needs 16x8 or 17 incher to get 8-9 lbs thrust which should be not too much less than flying weight. HK says 3.6Kg flying weight but they are confused what that means I think - maybe airframe alone without engine is 3.6Kg, we will see. https://www.hobbyking.com/hobbyking/...dProduct=19616 If not good, I might go to a Power90 by Eflite or similar. Ecalc doesn't have the motor listed but similar spec Turnigy Sk motor puts our 5.5Kg thrust ~1100W on 6S and 16x8 prop
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old Aug 15, 2014, 09:40 AM
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
What kv is your SK3? I have used the 5055-320 with great success with 16 x 8 x3 blade EMP props. This motor will easily turn an 18/10 2 blade on 6s.
I too suspect 3.6kg /8lbs is the plane weight without a power system. So 10-11 lbs, 1100 watts would be ample for flight. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Aug 15, 2014, 10:17 AM
fly by night
Joined Sep 2011
it's not the SK3. It's a Turnigy L5055A 400kv. I have the motor and 16x8 props just arrived this aft.
For Sale Scale Cub Landing Gear 1/6, 1/5, 1/4 1/3 scale porterfield pop Aircraft - Electric - Airplanes (FS/W) 7 Jan 20, 2014 10:52 PM
For Sale Sig J-3 Cub, 1/5 scale ready for power system jmatusic Aircraft - Fuel - Airplanes (FS/W) 14 Nov 15, 2013 10:10 AM
Sold Vintage Hegi Burda 1/5 scale Super Cub kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 4 Oct 17, 2013 06:51 PM
Discussion 1/4 scale SE-5 converted from Gas to electric tenacious101010 Glow to Electric Conversions 4 Nov 15, 2012 08:59 PM
For Sale 1/4 scale cub converted to electric john howard Aircraft - Electric - Airplanes (FS/W) 4 Dec 09, 2011 06:05 AM
