Old Today, 03:58 PM
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
that glacier 1100amh life 2s is holding up...gonna swicht to that!
fred
thanks again.
Flazo is offline Find More Posts by Flazo
Old Today, 04:16 PM
Canada, ON, London
Joined May 2011
Originally Posted by voxel View Post
No problems with the Talon 90 myself on other planes. It's been rock solid.
On the Beast, I also run a 2s 1300mah setup (CC100 but not using BEC)with telemetry. Yes the voltage sags, but we are not talking anything near brownout levels (3.6? 3.3?)
Interesting... yeah, nowhere near brownouts for me on my 2S lipo; however, I've calculated that a perfect storm of all 6 servos stalling would probably mean ~ 12 to 14 Amps of current!! This is based on specs of my servos - aileron stall @ 1.3A and tail servos @ 3.2A.
So... I'm definitely going to DIY a power bus of sorts just so that I'm not ever running all those amps over the circuit board trace in the AR8000 Rx.
I may also go to a bigger Rx pack... not sure yet. I'd go Life, but their a lower voltage than the 2S lipo and I want the HV if for no other reason than my servos support it and it'll get me the most speed out of them
Cheers,
J
uberjay is online now Find More Posts by uberjay
Old Today, 04:23 PM
United States, FL, Altamonte Springs
Joined Jun 2012
The major limit of these 2s receiver lipos is the gauge of the wires. That's why they usually come with 2 or 3 connectors that's different from a regular lipo. You are supposed to connect as many as possible since a regular servo wire only can push through 4-5 amps.
I.e
http://www.valuehobby.com/5c-2100mah-2s-rx.html
The beauty of power distribution boards is that they use deans and thicker wire to power all the servos. The negative is that they are usually a hundred or more and add weight.
voxel is offline Find More Posts by voxel
Old Today, 05:38 PM
Canada, ON, London
Joined May 2011
I.e
Yeah, thanks. My lipo is 20C. So it should pump the current; however, you make an interesting point about using more than one of it's leads.
J
Cool New E-flite Cessna 150 Aerobat ARF dee-grose Scale ARF/RTF 594 Aug 29, 2014 06:23 AM
Sold E-flite hawker hurricane rc airplane plane kit no electronics new $80 3drcparts Aircraft - Electric - Airplanes (FS/W) 8 Feb 21, 2013 12:35 PM
For Sale Misc Arf parts, Hangar 9, E-flite, 3dhs, Great Planes dakotanovass Non R/C Items (FS/W) 0 Jan 12, 2013 07:56 AM
Sold E-flite L4 Grasshopper ARF and Cessna 150 Aerobat ARF ton2di Aircraft - Electric - Airplanes (FS/W) 0 Nov 23, 2012 05:50 PM
Discussion e-flite cessna 150 aerobat 250 arf? rcguy1234 Electric Plane Talk 3 Aug 20, 2011 01:38 PM
