Old Mar 10, 2015, 09:50 AM
karlosvontrapp is offline
Find More Posts by karlosvontrapp
multiwiicopter team pilot
karlosvontrapp's Avatar
Australia, TAS, Hobart
Joined Aug 2009
Build Log
MWC FPV Wing Kit - Paris v5r3 autoPilot OSD GPS RTH - CarbonBird 1111kv motor
Recently I have been given the opportunity to build up a wing incorporating the paris v5r3 board fom multiwiicopter.com that offers RTH via the patrick E wing code and osd that runs the multiwiiosd firmware. There are plenty of guides out there on building this kind of wing but i felt i could give it a go with my own flavour plus i'll be looking to add some extra saucy bits in the future.
First things first is the parts list
Zii Zephyr obtained from MultiWiiCopter.com AU
Paris v5r3 autoPilot OSD with GPS & RTH board
80amp esc
1111kv carbonbird motor
10x6 apc/graupner prop or 11x5 hqprop
carbonbird 8amp ubec
chainlink uhf
5.8ghz vid tx and 1.3ghz later on
2x4200mah 4s carbonbird lipos
1500mah 3s carbonbird lipo for video tx and cam
bluebird bms 821dmg+hs servos
turnstile uhf antenna
The first things to do in the build are to cut off any of the dags from the moulding process and sand back the foam cores.
Description: Name: IMG_0015.jpg
Description:
After that its time to mark the slot for the motor mount which should end up with the mount sitting just above where the main spar lies.
Description: Name: IMG_0017.jpg
Description:
Once the marking out has been done cut out the slot using either a hacksaw blade or a sawzall/reciprocating sawblade.
Description:
When the slot has been cut and everything lines up nice glue up the two wing halves in the centre using you glue of choice. Some use 3m77, I chose to use foam glue from HK.
Description:
When the glue for the wing halves has dried, spritz the main spar slot with water from a spray bottle and run a bead of polyurethane glue in it and place the carbon spars in with a bead of glue in between finishing with another spritz of water over the top. Secure into place using pins to hold the spars in place till the glue dries. Run some masking tape along the sides of the spar slots to prevent the excess glue sticking to the outside of the wing.
Description: Name: IMG_0021.jpg
Description:
After a while the glue should foam up out of the slot. Make sure to slice off the excess before the glue has hardened too much.
Description:
Continue on to glueing the remaining spars in place.
Description: Name: IMG_0029.jpg
Description:
When all spars are glued into place, glue the motor mount in with polyurethane glue taking care to make sure that the motor mount is centered in the slot. Use tape to secure it from moving while the glue cures.
Description: Name: IMG_0035.jpg
Description: Name: IMG_0031.jpg
Description:
After the glue has cured on all the spars and motor mount. Trim off any excess glue with a sharp blade. Continue on to glueing in servos, cutting out recesses for the gps, mag, reciever, video tx, ubec and slots for wiring to the central bay.
Description: Name: IMG_0049.jpg
Description: Name: IMG_0047.jpg
Description: Name: IMG_0046.jpg
Description: Name: CAM00480.jpg
Description:
I have chosen to use a turnstile UHF antenna with my setup so the next step is embed it into the wing and feed it through to the reciever. here is a great tutorial on how to make your own turnstile uhf antenna
Build IBCrazy's 433MHz Turnstile antenna for FPV (6 min 5 sec)
Description: Name: CAM00477.jpg
Description: Name: CAM00478.jpg
Description: Name: CAM00479.jpg
Description:
then proceed to filling any voids with spakfilla/spackle filler.
Description: Name: IMG_0040.jpg
Description: Name: IMG_0042.jpg
Description:
After all voids are filled and filler is sanded back with fine sandpaper clean off any loose dust with a damp cloth. Proceed to covering the wing with the laminate supplied in the kit. Set your iron to a high heat approximately 100 degress celsius/225 degrees farenheight. Work methodically in sections to ensure there are no wrinkles in the finish and work the laminate into all the equipment bays. Here is a vid that demonstrates how to go about applying the laminate film
EPP TBRC Wing Build - By Yuvski - Laminate FPV Part 7/8 (9 min 47 sec)
Apply wing tape and decals
Description:
The winglets are next. Start by marking out the centreline and mark out the profile of the wing airfoil and apply glue. Attach the winglet and temporarily pin the winglet on using pins till the glue sets. Make sure that the winglet is set at 90 degrees to the wing. When the glue has set, run a bead of hot glue as a fillet around where the winglet attaches.
Description: Name: CAM00570.jpg
Description: Name: CAM00569.jpg
Description:
When the winglets are done, the front skids can be glued on. Prepare them first by gluing the pieces together. Fill in the corrugations with hotglue and run some electrical tape along the outside edge. Glue them onto the wing and run a fillet of hot glue where the skids join the wing.
Description: Name: CAM00563.jpg
Description: Name: CAM00565.jpg
Description:
The next stage is cutting and shaping of the elevons. When they placed on a flat surface the edge that attaches to the wing should be 90 degrees vertical from the benchtop. Mark out the elevon with a straight line coming from 1/3 the way along trailing edge tapering in towards inner edge approximately 25mm out. Round off the thicker end and de arris all the edges except the edge that attaches to the wing and sand all surfaces with sandpaper.
Description: Name: CAM00443.jpg
Description: Name: CAM00446.jpg
Description:
Wing tape or paint is applied next to the elevons then laminate is applied as well.
Description: Name: CAM00468.jpg
Description: Name: CAM00475.jpg
Description:
Attach the elevons to the wing using tape, first on the top the flip the elevon over and tape the bottom side.
Description:
Linkages are attached using sullivan clevisis and hollow carbon tube with threaded rod through the middle. I have attached the the linkage to the inner most hole of the servo arm and the other end is attached to the control horn 25mm above the elevon.
Description:
Prepare the equipment bay covers by slicing through the corrugated plastic on one side where it would act as a hinge. Cut out some slots to for magnets to be glued in then tape and hotglue the covers onto the wing.
Description: Name: CAM00529.jpg
Description:
Paris v5r3 autoPilot OSD with GPS & RTH board installed into wing equipment bay along with current sensor. Motor and esc mounted. For the Paris v5r3 multiwiicopter board installed in the wing i am using the Patrick E 2.3 wing code availiable from here http://fotoflygarn.blogspot.com.au/2...-airplane.html
This site gives lots of good detail on how to setup an airplane using a multiwii based board. For more good info on the paris v5r3 board and info on how to setup the osd go to the multiwiicopter page for it at http://www.multiwiicopter.com/produc...-gps-autopilot
On the Paris v5r3 board the Esc connects to pin e3, the left elevon to pin s11 and the right elevon to s12.
I like to calibrate the paris v5r3 board accelerometer on the ground beforehand with the nose of the wing sitting up about 4-5degrees to simulate the wings attitude in flight.
Description: Name: CAM00617.jpg
Description:
Here is some screenshots of my initial PID setup for the wing
Name: zephyr pid screenshot.jpg
Description: Name: zephyr servo tab.jpg
Description:
The finished wing.
Description: Name: CAM00610.jpg
Description:
Once everything has been finished balance out the wing at the correct CG. The CG is located on the bottom of the wing 23.9mm - 9 3/8‘’ to 24.15mm - 9 1/2’’ from the nose back.
To trim out the elevons for its first flight lay a ruler across the elevon and wing top surface. Adjust the elevon upwards so that there is about a 2-3mm gap between where the elevon and the wing meet. The throws for the elevons work out to be 15mm in either direction.
When it comes time for the first flight you can either have the wing set to passthru mode for full manual control of the wing or horizon mode to keep it level for take off. Once up in the air set the wing into passthru mode to trim the wing properly in the transmitter. Here is a great vid to show some of the ways to launch the wing.
How To Properly Launch A Ritewing Zephyr and ZII (4 min 5 sec)
To be continued.............
karlosvontrapp is offline Find More Posts by karlosvontrapp
Old Mar 27, 2015, 09:32 AM
Joined Aug 2009
Got some nice LOS footage from the maiden with some help from a good mate, more video to come.
multiwiicopter paris v5r3 wing maiden (1 min 39 sec)
Old Jun 29, 2015, 09:23 PM
Joined Aug 2009
Here is some footage of the RTH in action plus the Osd display with mwosd 1.4
Paris v5r3 multiwiicopter wing RTH+OSD demo (1 min 53 sec)
For Sale Paris v5r3 Mega Iosd + GPS appitri Aircraft - Electric - Multirotor (FS/W) 0 Feb 10, 2015 03:07 PM
Link Paris v5r3 Mega iOSD + GPS ebay appitri Multirotor Electronics 0 Feb 10, 2015 02:56 PM
Discussion Naza GPS, APM2 and MWC GPS behavior when RTH is engaged. WiseDuck Multirotor Electronics 1 Dec 10, 2012 03:00 PM
Sold Dragon OSD+ V2 GPS (RTH, Autopilot, Waypoints) NEW crd FPV Equipment (FS/W) 1 Mar 16, 2012 09:17 AM
Sold Dragon OSD+ V2 GPS (RTH, Autopilot, Waypoints) NEW crd FPV Equipment (FS/W) 0 Mar 11, 2012 09:55 AM
