Old Nov 08, 2014, 09:34 AM
bbenner is online now
Find More Posts by bbenner
BOATBring Out Another Thousand
bbenner's Avatar
United States, ME, South Bristol
Joined Sep 2013
Build Log
29" Fiberglass Hardchine Lobster Boat Build
This will be the build on hull #3 out of my new mold of a 29" hardchine lobster boat. Ill be starting with getting the running gear in in hopes of getting a test before the water hardens up. It will be using the same 1600kv outrunner I used in my 31" model. No idea on what the top will be on this one maybe a standard lobster top.
Brent
bbenner is online now Find More Posts by bbenner
Old Nov 08, 2014, 11:45 AM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
Off and running I like the stamp in the hull .
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Nov 09, 2014, 02:06 AM
H.Lauer is offline
Find More Posts by H.Lauer
H.Lauer's Avatar
Camden Maine
Joined Feb 2005
Nice clean hull Brent. Looking forward to your build. Harry
H.Lauer is offline Find More Posts by H.Lauer
Old Nov 09, 2014, 06:14 AM
bbenner's Avatar
Joined Sep 2013
Ya the card looks awesome in the hull much nicer than the old way. After I get the running gear in this one Ill be starting my 48" and making you some top parts Louie.
Brent
Old Nov 09, 2014, 06:21 AM
Joined May 2010
Sounds good Brent .
Old Nov 09, 2014, 08:48 AM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Mark
the goon is offline Find More Posts by the goon
Old Nov 09, 2014, 09:18 AM
chum444 is online now
Find More Posts by chum444
...man wants his boat
chum444's Avatar
United States, MA, Woods Hole
Joined Aug 2012
Brent
Looks good Brent. Did you increase the amount of shear beyond that of the 31?
Have added outriggers, rocket launchers, and a few more details to mine. After a bit more work will get some pics up. Have to get into installing the right prop as I did not get quite the speed I was looking for. Definitely not the hull's problem given the speeds you and the other Bill's hulls have achieved. Need to remove the prop I'm using, take pitch and diameter measurements and decide how to proceed. Not looking for your speed; just want to get around 20kts scale speed.
Will be watching your build.
Bill
chum444 is online now Find More Posts by chum444
Old Nov 09, 2014, 10:11 AM
bbenner's Avatar
Joined Sep 2013
Bill
The sheer did get a little extra in the bow from taking some of the fwd rake out of it.
Didnt you use a geared motor, couldnt you gear up and gain some speed?
Im working on a static 31" and maybe taking a boat out for a run today so I probably wont make any progress on the hardchine today.
Brent
Old Nov 10, 2014, 08:30 AM
chum444's Avatar
Joined Aug 2012
From the vids of the 48" it looks like you had a spot of rain.
I am running a geared motor in the 36". Thought I would try the prop route first. Not looking to gain a lot more speed. You must have a some big storage space.
Bill
Old Nov 10, 2014, 08:35 AM
bbenner's Avatar
Joined Sep 2013
Bill
Its that snow we got all melted off. Im running out of places to put boats in my room, I started hanging them off the ceiling.
Brent
Old Nov 14, 2014, 07:42 AM
bbenner's Avatar
Joined Sep 2013
Been working on other things so I havent done as much with this one as Id like but I got the beds epoxied in for the motor mounts this morning.
Brent
Old Nov 14, 2014, 03:21 PM
Band1 is offline
Find More Posts by Band1
Band1's Avatar
United States, NY, Queens County
Joined Oct 2011
I never built a lobster boat , is there anyway that the motor can
be installed before the cabin ( outside the cabin) so that i could
Glue the cabin on for good ?
Band1 is offline Find More Posts by Band1
Old Nov 14, 2014, 03:31 PM
chum444's Avatar
Joined Aug 2012
Sure. You could install the motor under an engine box on the deck near the helm bulkhead. Issue may become how to get the stuffing box/shaft to pass under the deck within the confines of the motor box. Could result in a rather steep shaft angle. My build of one of Brent's 36" hulls has the motor under the cockpit floor. P&S parts of the floor are fixed; the center is removable for access to the motor, RX, and ESC. Take a look at Brent's other build logs to see how he did it. I think this is one of the first he's done with the removable house which btw affords much better access to running gear than my arrangement. Net, net, whatever works for you.
Bill
Old Nov 14, 2014, 03:39 PM
bbenner's Avatar
Joined Sep 2013
All my current lobster boat tops are glassed right on to the hulls, the biggest part of that is knowing where the main bulkhead is and have the motor under or behind it. The 48" and 31" builds are the best to look at to see it.
Brent
Old Nov 14, 2014, 05:11 PM
Band1 is offline
Band1's Avatar
Joined Oct 2011
Bill
That is what I was afraid , the steep angle of the shaft.
If I go with his 48" hull it shouldn't be as much of a problem.
Build Log 48 inch lobster boat build bbenner Scale Boats 295 Jun 24, 2015 01:35 PM
Build Log 36 inch lobster boat hull plug build bbenner Scale Boats 516 Dec 28, 2014 04:04 AM
Sold 30" Fiberglass Lobster boat hull Tollytime Boats (FS/W) 8 Aug 31, 2014 12:48 PM
Question Midwest Fiberglass Lobster Boat CaptCB Scale Boats 7 Feb 06, 2014 10:02 AM
