Old Apr 30, 2013, 01:59 PM
hot wings is offline
Find More Posts by hot wings
hot wings's Avatar
Joined Jul 2010
Is TGY-306G-HV servo reliable?
Hi guys,
simple question..
is TGY-306G-HV servo reliable enough?
I mean can I use in for tail control on my Tarot 450 pro v2 fbl with sufficient duration?
hot wings is offline Find More Posts by hot wings
Old Apr 30, 2013, 02:44 PM
ryane67 is offline
Find More Posts by ryane67
I'll fly (and crash) anything!
ryane67's Avatar
United States, MI, Orion Charter Township
Joined Mar 2013
Just installed one on my HK450, at first use it's a very nice servo for the price.
by duration do you mean how many flights will it last? how many crashes it will survive?
ryane67 is offline Find More Posts by ryane67
Old Apr 30, 2013, 03:32 PM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
Would be interesting to hear peoples thoughts on these as thinking of buying some soon.
peter24 is offline Find More Posts by peter24
Old Apr 30, 2013, 05:49 PM
Adge82 is offline
Find More Posts by Adge82
Bugger, i broke it again!
Australia, VIC, Shepparton
Joined Jun 2011
In my search for a decent tail servo over the last couple of weeks i came across these.
Reviews around the net say there not much chop. Some people have some success but i found more negative than positive reviews.
Enough that i have steered clear.
I think that if you happen to get a good one, theyre good. But QC is an issue and a lot of them are sub-par.
Adge82 is offline Find More Posts by Adge82
Old May 02, 2013, 04:03 PM
hot wings's Avatar
Joined Jul 2010
yes, I mean how many flights it will last.
and also I'd like to know if somebody experimented any unusual response during flight.
Old May 02, 2013, 04:16 PM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
I installed four of them in my AS350. I don't really have much time on them. They run really smooth. The tail servo was running a little warm but I think I got that sorted out, time will tell. So far I like them really well Ed
prop bender is offline Find More Posts by prop bender
Old May 04, 2013, 04:16 AM
hot wings's Avatar
Joined Jul 2010
tks, but
I'd like to know also if it is good for 3D flights...
Old May 05, 2013, 12:57 AM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
always see it to believe it. check out youtube there's a lot of videos of it
Tarot 3axis Gyro Ver 3.5 Trex450pro TGY-306G servo (4 min 30 sec)
4 : Tarot 450 Pro V2 Build : Turnigy S306G-HV Servos (13 min 55 sec)
MSH MINI PROTOS (4 min 33 sec)
ALZRC DEVIL 480 FAST pilot mitsos3d (2 min 11 sec)
It's just like the MKS don't do any hard landings and avoid a crash as much as possible, the fate will be the same as the mks only cheaper. good luck!
Unsubscribe!
pitchp is offline Find More Posts by pitchp
Old May 05, 2013, 02:13 AM
fishfiend is online now
Find More Posts by fishfiend
Joined Jun 2008
I don't worry about damage in a crash, after wrecking one, and having trouble finding a replacement gear set in stock that wouldn't take 2 weeks to get to the UK, I remembered I had these http://www.hobbyking.com/hobbyking/s...4925&aff=94757 Fitted them, redid my set up had two bad crashes since and haven't damaged a servo...these arms just break and they fly just like the old ones. They have to go on the last hole though
fishfiend is online now Find More Posts by fishfiend
Old May 08, 2013, 12:46 PM
hot wings's Avatar
Joined Jul 2010
Any circuit boad failure report?
Old Jun 30, 2015, 01:37 AM
utrinque is offline
Find More Posts by utrinque
Joined Aug 2011
I love TGY 306G servos. They are much tougher than MKS DS92 which can strip in flight (not recommended for FBL by MKS and discontinued). If you want MKS get DS95.
One of 306G became silent yesterday. I did not check if it is related to broken cable yet. Anyway those servos survive crashes. I was not able to strip gears.
Any servo can fail. I use them in three 450 PRO and in some planks.
This is rebranded KST servo.
Finally we have good and relatively cheap servos for 450.
I use 335mm blades and plan to stretch to 360mm and/or 380mm.
utrinque is offline Find More Posts by utrinque
Old Jun 30, 2015, 03:08 PM
2Doggs is online now
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Don't read too much into the reviews on the HK product pages. There are clearly many
idiots who buy heli stuff, use it improperly and then write (usually dyslexic) negative reviews.
2Doggs is online now Find More Posts by 2Doggs
Old Jul 02, 2015, 05:30 AM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
I have 306's mounted on three 450's, both tail and cyclic and am VERY happy with them. As stated in a previous post, put the breakaway arms on them. In a bad crash without the breakaway arms you will break teeth on the aluminum main gear. That does save the rest of the gear train from damage though.
Pa flyer is offline Find More Posts by Pa flyer
Old Jul 02, 2015, 01:16 PM
Steve Joblin is offline
Find More Posts by Steve Joblin
Steve Joblin's Avatar
Blue Bell, PA USA
Joined Sep 2008
I just replaced my Savox SH0257MG servos with the TGY 306G due to failing pots on the Savox. I am quite satisfied thus far with the TGY 306G's and would recommend them as a good, reasonably priced servo.
Steve Joblin is offline Find More Posts by Steve Joblin
Discussion Gear slop in TGY 306G servo neosunrise Electric Heli Talk 12 Jul 24, 2014 08:26 PM
Discussion Tgy 306g-hv turnigy servo, anyone using it? salrica Electric Heli Talk 2 Mar 30, 2013 02:45 PM
Help! TGY-S306G servo malfunction psychlic Electric Heli Talk 1 Mar 30, 2013 02:29 PM
Discussion GY-306G Ultra Fast servo for 450 heli hot wings Mini Helis 3 Oct 15, 2012 01:05 PM
