Espritmodel.com Heli Air
Old Jun 05, 2013, 05:48 PM
Joined May 2008
Fake XT60 and XT90 connector? How do you tell?
I buy all mine from Hobbyking usually, but I need some XT90s as soon as possible, so that means ebay or some other lesser know online shop in the US. The problem is, I don't know how to distinguish the real ones from the fake ones. I've done a few google searches, but it keeps leaving out the "fake" and "clone" in my searches. So what are things to look for to spot the fakes?
metoo is offline Find More Posts by metoo
Old Jun 06, 2013, 04:58 PM
Call me Clyde Crashcopter
Powerdyne's Avatar
United States, IN, Muncie
Joined Mar 2013
REAL XT60 are made by Amass for HXT.
The TGY Connectors are made in the same factory. All others are knockoffs.
Any of the three will have a registered trademark next to the identifier.
HXT®
AMASS®
TGY®
Some older connectors will not have this however.
Here is a link to the Amass website's guide on spotting a fake. It includes their Patent file scans.
http://www.china-amass.com/newproduct1.asp
An easy way to spot a knockoff is the ribbing under the "XT-60" stamp on the connector. It is very well defined and crisp and will look like a stair-stepped washboard pattern. Knockoffs have blobby looking ribs or none at all.
The "+" and "-" terminal indicators on the side of the plug are crisp and defined on the real XT60, they are blooby and less defined on a fake.
The Solder terminals on a real connector are recessed into the nylon housing so that heat shrink can sit inside the housing further. Fakes have little to no recess.
The Nylon on real connectors feels heavier. The fakes will be very light and will feel more brittle. The fakes also melt faster.
Another giveaway is the thickness of the housing on the male connector. (Side with the plugs in the shroud). Real ones should be thicker, and when connected should be tight. Fakes will come apart easier.
The molding on a Real XT60 or XT90 will have a well defined molding flash line around the entire connector. Fakes do not have this because the plastic used is lower melting point, and low temp injected.
Powerdyne is offline Find More Posts by Powerdyne
Old Jun 09, 2013, 02:45 AM
scanner62's Avatar
Joined May 2013
Google Search
metoo;...just a tip for specific searches on google....when typing in your field, just add the "s to the front and rear of your text, ie; " spotting a fake XT connector ", this will refine the search engine specifically to that wording, but, you may have to try different ways of wording your search sometimes to get results.
Such as "how to tell the difference between real and fake XT connectors"...etc
Hope this helps for future searches...
Regards
scanner62 is offline Find More Posts by scanner62
Old Jun 09, 2013, 04:56 AM
Philippines
Joined Jul 2012
@Powerdyne
That's funny, coz the XT60 connectors on the hobbyking turnigy batteries don't fit all the way into the xt60 connectors I also bought from hobbyking. They only go two thirds of the way in. You can push it a bit further (Really can't go all the way in), but then you'd have a heck of a time pulling them apart.
I did what you posted, the connectors I soldered myself are XT60 on one side and TGY on the other, the ridges are so well defined, they've got dirt on them.
The XT60 that came with the turnigy batteries don't fit properly, have XT60 on both sides, and the ridges are clean (No sharp corners for dirt to collect), the flat areas of the turnigy connectors are also concave. So if anything, the hobbyking batteries are using knockoffs
Hajile is offline Find More Posts by Hajile
Old Jun 09, 2013, 05:09 AM
Powerdyne's Avatar
Joined Mar 2013
And this is surprising to you how?
We are talking about the knockoff capitol of the universe...
Don't get me wrong, just like anything else that has been cloned, there are some REALLY good fakes out there. I'm just going by what I read.
Old Jun 09, 2013, 10:45 AM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
So, you have to buy it before you can tell if you've been ripped off with a fake?
jasmine2501 is offline Find More Posts by jasmine2501
Old Jun 10, 2013, 08:46 AM
FPV Noob KD0VMK
United States, MO, Platte City
Joined Jun 2012
I probably have 50 or 60 XT60 connectors laying around, on batteries, and on ESCs. They have ALL come from HK. some fit tightly, and some are easy to pull apart, some are heavier than others, some have slightly different soldering connections, some are a different color of yellow, and some are even slightly different lengths. I'd say with near certainty, that HK occasionally ships "clones" of their own connectors.
The good news: despite the differences, they all work together. Some are tight, but they all plug in, and they all use the same 3.5mm banana plugs on the inside. Since they all have the same gold connectors, I would assume they all carry roughly the same current, and isn't that all we care about? Clone or not, as long as they work and they cost $2 for 10 of them (or whatever cheap price they are), I don't really care where they come from or who makes them. HK clones everything anyways, so It's not like they can get all high-and-mighty about people cloning their stuff. Talk about the pot calling the kettle black....
Chubbs is offline Find More Posts by Chubbs
Old Jun 10, 2013, 07:09 PM
United States, MD, Baltimore
Joined Dec 2012
I think the variations in fit are due to different production batches.
TheKingPhisher is offline Find More Posts by TheKingPhisher
Old Jun 11, 2013, 02:39 AM
Executing Maneuvers
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
There is a little trick I had learned from the connectors being so tight that I would rip the wire right out of the connector when disconnecting them. All you have to do is grab some needlenose and squeeze the prongs until you get the desired force you want. Makes connecting and disconnecting a lot easier so you don't have to struggle with them
Very simple mod and they will slide like butta afterwards.
ASTREA1 is offline Find More Posts by ASTREA1
Old Jun 11, 2013, 02:51 AM
Philippines
Joined Jul 2012
Already did that and it helped with the battery charger. But the issue with the turnigy batteries seems to be the plug itself being a hundredth of a millimeter too thick. The other batteries slide just fine so it isn't the prongs.
Old Jun 11, 2013, 03:23 AM
Executing Maneuvers
ASTREA1's Avatar
Joined Dec 2008
@Powerdyne
That is odd. I was able to pick up a pack of 6 I believe at the LHS (3 male and 3 female), and ran them with my two Turnigy 2.2's which had come with the XT's already on them, and they seemed to match up pretty well. Not sure what brand they were but I guess it is hit and miss with most of this stuff.
Old Jun 11, 2013, 01:27 PM
Powerdyne's Avatar
Joined Mar 2013
I use a little drop of silicone oil in my xt connectors if they are a little too tight, then clean out excess with a cotton swab dipped in 90% iso alcohol. Also, filing down the flashing on the female side helps a little. Electrical contact cleaner works well too.
Old Jun 11, 2013, 08:29 PM
Joined Dec 2011
HXT®
AMASS®
TGY®
"Your precious will be crashed, destroyed if you use an imitation!"
Am I the only one that heard that in Gollum's voice?
Atomic Skull is offline Find More Posts by Atomic Skull
Help! How do I tell which version s/w is installed? & should the 'Help button do anything? RogWarTheOAP Eagle Tree Systems 7 Jun 09, 2013 10:59 PM
Help! How do I tell what firmware my beastx has? CobraKiller Electric Heli Talk 0 Apr 04, 2013 09:50 PM
Discussion Quick question xt60 or xt90? timo123451 Batteries and Chargers 1 Jan 19, 2013 06:02 PM
Discussion So how many people switched to XT60 connectors? BD Flyer Electric Plane Talk 32 Oct 18, 2010 07:39 PM
Discussion How to convert my battery's XT60 connector to JST? tomx Parkflyers 10 Jan 18, 2010 11:35 PM
