Old Mar 27, 2015, 10:23 AM
CoolKidDenim is offline
Find More Posts by CoolKidDenim
United States, SD, Faith
Joined Sep 2014
Idea
Rc Rocket Plane
I want to build a rocket plane with a estes rocket engine. This is for a school project. I have no idea what to use I have a 25-30amp brushless esc, a 3000 kv bluewonder, cheap 9g servos, 640 amp rhino batteries, a 4 channel receiver and transmitter, and adapters. I would prefer a glider for simplicity or a stream line design. If any one has ideas or links to designs that would work comment. Thank you.
P.S-I would like it to be depron, 1/2 pink foam or adams foamboard.
CoolKidDenim is offline Find More Posts by CoolKidDenim
Old Mar 27, 2015, 11:08 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Confused...if it's a plane powered by a rocket motor what do you need the electric motor/ESC for ? What is it you really intend to build ?
BTW I guess 640 amp really means 640mAh ? A 640A battery is likely to weigh a 100lb or more.
Steve
slipstick is online now Find More Posts by slipstick
Old Mar 27, 2015, 11:12 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The best place to look is probably the -- Rocketry forum
There is a big thread in there called -- Anyone else love RC rocket Gliders?
eflightray is offline Find More Posts by eflightray
Old Mar 27, 2015, 11:22 AM
mmattock is offline
Find More Posts by mmattock
Canada, AB, Airdrie
Joined Oct 2014
Another option, but not foam:
http://www.rcgroups.com/forums/showp...postcount=3296
Mark
mmattock is offline Find More Posts by mmattock
Old Mar 27, 2015, 02:13 PM
chaoticrobot is offline
Find More Posts by chaoticrobot
United States, CA, Walnut
Joined Jul 2014
What is the goal of the school project you are working on? How do want to utilize the rocket? take off assist?
chaoticrobot is offline Find More Posts by chaoticrobot
Old Mar 27, 2015, 02:47 PM
Joined Sep 2014
The point is to do something you are interested in that will teach the class and yourself. Take off assist or booster for in flight.
Old Mar 27, 2015, 06:05 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
In this video they launch a folded wing glider with a rocket motor , then the wings open and it glides down . The glider is free flight , but it probably could be done RC .
Flite Test | Rocket Glider & Free Flight (11 min 31 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old Mar 27, 2015, 08:02 PM
Joined Sep 2014
I watch Flite Test a lot, i have seen this.
Old Mar 27, 2015, 08:47 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
What is the thrust of the proposed rocket motor?
What is the burn time?
Whiskers is offline Find More Posts by Whiskers
Old Mar 28, 2015, 08:13 PM
Joined Sep 2014
IDK yet
Old Mar 30, 2015, 03:58 PM
Decroxx is offline
Find More Posts by Decroxx
Free Sarcasm!
United States, OH, Worthington
Joined Nov 2014
What experience do you have with rc planes?
Decroxx is offline Find More Posts by Decroxx
Old Mar 30, 2015, 04:24 PM
Joined Sep 2014
Little, I thought this would speed up the learning process.
Old Mar 30, 2015, 05:34 PM
Decroxx is offline
Free Sarcasm!
Joined Nov 2014
Have you built one before?
Old Mar 30, 2015, 06:08 PM
Decroxx is offline
Free Sarcasm!
Joined Nov 2014
I mean, to fly this with no rc flying experience would be pretty hard. You would probably be flying a small, nimble, and possibly nose-heavy rc planes with a high wing loading, which isn't at all optimum for beginners. Granted, it is possible. If, however you do have some flying experience you would be better off.
Old Mar 30, 2015, 06:13 PM
Decroxx is offline
Free Sarcasm!
Joined Nov 2014
Do you want to fire the motor in the air or on the ground? If you want to fire it in the air, then you need an ignite wired to a channel in your rc transmitter, possibly like this:
http://rcexplorer.se/blog/2012/03/ne...tle/#more-2397
Nevertheless, this is probably a bad idea.
Discussion How to ignite Estes Rocket on RC plane? garmin810 Electric Plane Talk 45 Jun 09, 2013 10:07 PM
For Sale New Exceed RC Rocket 3020-600KV Brushless Motor for RC Plane Bonestockz06 Aircraft - Electric - Power Systems (FS/W) 2 Dec 04, 2011 04:01 AM
Discussion USB Machine Gun/Rocket Launcher mod shoots down RC Micro RTF Planes and Choppers Electronick Micro Ready-to-Fly 20 May 17, 2008 02:44 AM
Question rocket engine on RC plane jant123 Rocketry 4 Sep 01, 2007 09:31 PM
Discussion Rocket powered rc plane jrubenis Power Systems 11 May 14, 2006 11:05 PM
