Old Oct 30, 2014, 06:08 PM
Will work for JR/Spektrum
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
nah, i'm talking about the as3x nanolite rx
Sabin is online now Find More Posts by Sabin
Old Oct 30, 2014, 08:11 PM
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
I'm looking forward to seeing some of those. Thinking of using one in an upcoming revival project.
JSS4 is online now Find More Posts by JSS4
Old Oct 31, 2014, 11:47 AM
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
JSS4
Wow... What talent!
We all bow to you sir. Love the floats with amphib' wheel setup.
ducatirdr is offline Find More Posts by ducatirdr
Old Oct 31, 2014, 03:52 PM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by JSS4 View Post
Micro Cessna and Beaver,
I didn't see where you got the Beaver plans - could you post a link, please?
Gene K
speedy01 is offline Find More Posts by speedy01
Old Oct 31, 2014, 03:59 PM
Exodus 4:13
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
The beaver is amazingly well detailed... love the floats with wheels. With its size, I bet the 2S UMX guts would have been a really good match for the airframe.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Oct 31, 2014, 06:57 PM
I'm BIG on micros
Joined Mar 2011
Originally Posted by ducatirdr View Post
JSS4
Wow... What talent!
Thanks! The floats look great on the model, but I need to rebuild the mounting system because it wasn't done well enough in the first place. The Beaver was my first scratchbuilt model, and so were the floats. My initial construction of the floats wasn't very precise, and it ground looped alot. The lack of either free swiveling or steerable gear was also a point of issue. I need to redo the main gear mounts though, because the wires holding the wheels came loose and dug into the wheel, effectively acting as a brake. I posted a thread about the float modification and construction here, and I will redo the floats sometime soon and add more to said link.
"Amphibious" floats for micro floatplanes
Gene K
Hi Gene
I got the plans off Small Flying Arts. They were originally designed for rubber FF but I converted it. An old build thread, not counting the overhaul and weight savings, is here:
22" micro DHC-2 Beaver
I continued progress as the Stick and Tissue Cook-up progressed.
After an attempt at flight 2 years ago, where I had to push it to reach flying speed, and it took off only to gain about 3 inches of altitude before failing to clear the grass, I overhauled the plane. I installed depron tail surfaces and wing skins. I also nixed the removable wing and disabled the lights.
I am, however, thinking of doing a Beaver V2 along with a Cessna V2.
Plans for the Beaver are attached. I printed them on standard letter paper.
Thanks! I considered that, but I figured it would add too much weight to the plane, and while it would have the thrust to get airborne, it would be too fast to fly indoors. As a result with the Beaver V2 redesign I will try to build lighter, and using a better battery and motor. Who knows - maybe I will use the 2s setup. Great suggestion!
Old Oct 31, 2014, 07:50 PM
Gulf Breeze, FL
Joined Jul 2006
Thanks - looking forward to your V2.
Gene K
Old Nov 01, 2014, 03:27 AM
Joined Aug 2012
Originally Posted by UNGN View Post
Here is a comparison of AR6400's
which one below is the original ar6400 and where is it avialable
romanxdsouza is offline Find More Posts by romanxdsouza
Old Nov 01, 2014, 06:46 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
I buy crashed airframes at swap meets for $20-40 as my source of AR6400 and 6400L.
Petefoss is online now Find More Posts by Petefoss
Old Nov 01, 2014, 10:15 AM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by Petefoss View Post
I buy crashed airframes ... as my source of AR6400 and 6400L.
I use my crashed airframes ... as my source for AR6400 and 6400L
(Thankfully I also have a stock of the discontinued inexpensive Target 1S brushed bricks)
Gene K
Old Nov 08, 2014, 12:50 AM
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
I guess I can post a kit plane here, it's for a friend of mine who asked me to detail it up a bit more. The builder took over two years to get it done, (after many Emails and phone calls) my friend gave up on it as a lost cause but I stuck on trying and finally got it this year. I was disappointed a bit on how it was finished so I asked him if I can "work on it" and so I did. This is a Maule Rocket and it's what my friend had as a real plane and wanted to get micro plane to look like it. Anyways it's finished
NEWBEFLYER is online now Find More Posts by NEWBEFLYER
Old Nov 09, 2014, 07:54 AM
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
More details on the Maule Rocket?
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Nov 09, 2014, 11:18 AM
Simple, Easy, Fun
Gabe_BigApple's Avatar
United States, NY, New York
Joined Jan 2013
New Champ OGFA DBF (design / build / fly) Contest !
Hi All,
I received permission from RCG to hold a contest for new planes (blimps, etc) built with Champ guts.
You can see it here:
http://www.rcgroups.com/forums/showthread.php?t=2281557
PRIZES, Fame and Joy await you !!!
(But mostly Joy)
Cheers,
Gabe
Gabe_BigApple is online now Find More Posts by Gabe_BigApple
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 07:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 07:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 12:05 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 08:11 PM
