Old Sep 15, 2014, 05:33 AM
asaak's Avatar
Joined Mar 2012
What Skywalker to buy?
Hi everybody!
I'm thinking of going back to skywalker planes. I used to have a 1900 wing. Now I am thinking on a smaller version because transporting was a pain in the ***.
To my surprise I've seen a lot of different models have been relased recently so I am starting to be a little bit lost.
I have motors, batteries and props for 4S setup, and a APM 2.6 so I am planning to use it for FPV.
According to my specs, I think I should probably go for 1680 2014 skywalker version with carbon fiber tail. What do you guys think? Should I buy it with the new tail design or with the old fashion T style?
Seems to me that the old fashion T elevator is not as strong as the 2013 version. Sometimes when I crashed it was to me the weakest part of the plane. What do you think?
Anyway, to sum up, I want a skywalker because I like it but I want something easy to fly : go to the field, not to much setup, through and fly!
Could you guys bring any light to this matter?
Thanks!
asaak is offline Find More Posts by asaak
Old Sep 15, 2014, 10:45 AM
USA: LakeGeorge, New York
USA
Joined May 2010
www.FPVmodel.com
SkyWalker 2014 "REVOLUTION" version
with CarbonBoom tail.
p.s.
the worst part of the SkyWalker line up are attaching the wings.
Rubber Bands....and
Plugging in all the wing servo connectors is a pain after 3yrs of SkyWalkers.
rclab1 is offline Find More Posts by rclab1
Old Sep 15, 2014, 01:54 PM
Joined Dec 2013
I have a 2013 CF boom 1900 and it takes a good bit of weight up front to get the right CG. Probably not an issue if you plan on having a good bit of gear/batteries but if for some reason you are looking for the lightest setup ever I suspect the foam model would be better? For reference with an almost bare plane it took a mobius, Qty 2 3S 4500s and an extra 3s 2200 up front to make it happy
astr0lite is offline Find More Posts by astr0lite
Discussion Where to buy Skywalker 2014? andrew_psch FPV Aircraft 8 Mar 10, 2014 04:08 PM
Question Where to buy a Skywalker?? k5nwz FPV Talk 13 Mar 06, 2014 08:13 PM
Wanted (Want to Buy) Mini skywalker Whoaty55 Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2013 01:44 PM
Question what else should i buy? cmdl Radios 2 Sep 26, 2013 04:59 PM
Discussion What would you buy/own Bev, Xen Skywalker or HK 168cm? bigo66 FPV Talk 5 May 25, 2011 06:47 PM
