Old Jul 27, 2015, 09:38 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by enrico0273 View Post
Sorry guys, should have been more specific. The shutter/chatter is after I take off. The tail moves up and down for no reason in flight to the point I almost crashed from about 8 ft off the ground. It seems to be worse at high speed but does it at slower speeds too.
Cool. so at least it is localized. As Joel said, check for slop in that elevator axis, then. Likely you will find something loose, bent, crushed or otherwise not up to scratch. I have found a tricky little problem is when the control horn gets loose at the foam interface (usually due to crash or hangar rash). That's one you have to both look at and wiggle with your fingers to check out. Should be no play there.
tracknoob is offline Find More Posts by tracknoob
Old Jul 27, 2015, 09:44 PM
enrico0273 is offline
Find More Posts by enrico0273
United States, CA, Lakeside
Joined Aug 2012
You guys called it! I took your advice and held the plane in my hand then slowly throttled up. Sure enough, the prop was off balance causing the As3x to compensate and make almost all the control surfaces shake violently. Turns out my prop adapter is off center? So I replaced it with a 3mm eflite prop adapter and drilled out teh prop hole to fit. Spooled everything up as before and its much smoother. Problem solved! thanks everyone
enrico0273 is offline Find More Posts by enrico0273
Old Jul 27, 2015, 10:44 PM
Blaze0021 is offline
Find More Posts by Blaze0021
Blaze0021's Avatar
United States, CO, Highlands Ranch
Joined Apr 2015
Glad it worked out for you and it was a relatively easy fix. Happy flying!
Blaze0021 is offline Find More Posts by Blaze0021
Old Jul 28, 2015, 01:26 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Woo Hoo!
Old Jul 29, 2015, 10:24 PM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
Originally Posted by MK View Post
OK, decided to be a cheap skate () and used a THIN layer of 30 mins. epoxy to glue it back down. Curing as we speak. Didn't use more than a drop fro the entire cradle. It looks like it will hold.
Thanks for the confirmation guys! Always appreciate the help around here.
(Can't remember the last time I used foam safe CA so I'm not going to pay $10 for a bottle and use it once.)
Just did 4 flights tonight with all 4 tipping over since I'm landing on grass and the repair is rock solid. No change in CG - didn't expect it to.
MK is offline Find More Posts by MK
Article Horizon Hobby UMX Habu 180 DF BNF Basic kevin Micro EDF Jets and Power Systems 13 Jul 11, 2015 03:12 PM
Sold New in Box UMX Used Habu 180 DF BNF Basic with AS3X Technology bruff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Nov 03, 2013 06:30 AM
Sold New in Box UMX Habu 180 DF BNF Basic with AS3X Technology Woody_99 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 31, 2013 07:32 PM
Sold UMX Carbon Cub SS BNF with AS3X Technology by E-flite (EFLU1180) NIB / 3 Batteries sst2000 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jul 19, 2012 06:06 PM
Sold UMX Carbon Cub SS BNF with AS3X Technology by E-flite (EFLU1180) NIB / 3 Batteries sst2000 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 9 Jul 12, 2012 04:03 PM
