Old Apr 14, 2014, 05:06 PM
Joined Nov 2013
12V Power Supply for Cam/TX
Hi there,
i'm building a FPV rig for my RClogger eye one xtreme quadcopter and i need an advice on which stepup module to use for power conversion (2s to "clean" 12V).
Cam is a CMQ1993X CCD and TX is a 250mw 5.8 gHz Fatshark.
The rig is as good as finished, but i never got to fly the quad because i toasted the rx before the first flight.
The quad runs on 2s (actually 2x 1s), the cam needs 12V.
I'm using this adapter cable to get 2s from the lipo http://www.rc-connectors.com/index.p...roducts_id=462
To get 12V out of this 2s system i bought this stepup module: http://www.ebay.at/itm/350385882425?...84.m1497.l2649
It is quiete heavy with 10 grams, and also pretty large, but it works.
If i plug in the lipo with everything wired up i get a nice and clean signal on my fatshark dominators.
Thats with the motors not running!
1.)
The question is, will the 12V stepup module i use give me a "clean" 12V even when the motors and everything is running?
Even without adding a ferrite ring or something like that?
I think before i bought the module i read that it kind of worked without anything else, but i could not try it myself since i'm still waiting for the new RX for the quad.
2.)
Another question would be if this would have been enough for my setup: http://www.readymaderc.com/store/ind...oducts_id=1554
This one only weights 0.5 grams and is very small.
I would save about 10 grams if i could just use the pololu module.
That would be great, but does the pololu put out "clean" 12V even when the motors are running and the lipo is getting stressed?
3.)
And while we're at it, can anybody tell me how much "mAh" and how many "A" or "mA" a typical 12V CCD cam and a 250mw 5.8ghz TX draw when running?
That would be interesting because i'm trying to figure out how long i will be able to stay in the air with that 80g FPV rig and a 1150 mAh lipo.
Thanks a lot for you input!
cheers,
Chris
Chris.Z is offline Find More Posts by Chris.Z
Old Apr 14, 2014, 05:50 PM
United States, MD, Stevensville
Joined Jun 2013
The RMRC Pololu step up works great and made for fpv applications. That being said you still have to use good or best practices with filtering and proper wiring as well as placement and antenna choice for best performance.
Waterbound is offline Find More Posts by Waterbound
Sold Power Supplies For Sale 12v-48v 500w-3000w $30-$137 icecube57 Aircraft - Electric - Batteries & Chargers (FS/W) 10 Feb 27, 2014 09:38 AM
For Sale 2-DC to DC buck step down power supply Voltage power converter 10-15V to0.9-12V 5A Chad2323 Aircraft - Electric - Multirotor (FS/W) 0 Feb 20, 2014 12:01 PM
For Sale Power Supplies For Sale 12v-48v 500w-3000w $36-$137 icecube57 Aircraft - Electric - Batteries & Chargers (FS/W) 53 Feb 18, 2014 09:06 AM
Sold OFNA Max Power 12v/10A Power Supply psnewman1 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Feb 09, 2014 09:47 AM
Discussion Converting a computer power supply to supply power for a charger and 12V equipment byrocat Power Systems 26 Jan 27, 2009 07:50 AM
