Old Nov 08, 2010, 03:27 PM
Joined Nov 2010
Minimizing multi-copter noise
Hi, long time lurker, first-time poster.
I've been considering a multi-copter build for a while, but the biggest turn-off for me is the amount of noise that they put out.
What can be done to minimize the noise?
Do you have any links to builds that did a good job of this? (preferably with vids with unedited audio)
Thanks in advance!
immacoolguy is offline Find More Posts by immacoolguy
Old Nov 08, 2010, 04:06 PM
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hmmm...most multicopters are relatively quiet compared to helis that can lift the same weight. I suppose using the largest props you can and turning them the slowest you can to hover your AUW would get the quietest multicopter. What do you want use it for? Aerobatics? AVP?
Her are some links related to all things multicopter for you to read:Quadrocopter and Tricopter Mega Link Index
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Nov 08, 2010, 05:20 PM
13brv3's Avatar
Navarre, FL
Joined Mar 2002
Building a very quiet quad has always interested me as well, but so far, I haven't attempted it.
All the noise is from the props, so that's where you'd have to do the most work. First, keep the weight (disc loading) as low as possible, since there's that much less air to move.
In general (as Jim mentioned) larger props turning slower would be best. The most efficient, and quietest prop would likely not be something we typically use.
It would be important to minimize turbulence above, and particularly below the prop. Airfoil shaped arms would be the way to go, and probably with the props as far below the arms as possible.
One of these days, I'm going to get around to working on this...
Rusty
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Nov 08, 2010, 07:04 PM
Ireland
Joined Apr 2001
and ballance the props too
cmulder is offline Find More Posts by cmulder
Old Nov 08, 2010, 09:11 PM
Long Island, New York
Joined Jun 2008
Thanks in advance!
Have you heard an Octo in person or just in videos? I ask because my octo is so quiet for what it is doing, no one has ever said it was load.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Nov 09, 2010, 09:55 AM
Joined Nov 2010
Cheers,
Jim
I'd like to use it mostly for logistics.
On-board video, stability/position hold and a larger carrying capacity to experiment with other components (thermal camera, radio-based triangulation, sonar/etc. for tight space navigation, spotlight)
But first I'd just like to get something off the ground But ideally the build would be able to support future experimentation without having to upgrade too many components.
I haven't heard or seen any multi-copter outside of videos. Any idea what kind of dB your copter puts out with a reasonable load?
Old Nov 09, 2010, 10:07 AM
Denmark, Capital Region of Denmark, Copenhagen
Joined May 2010
To give you an idea, with my quad 12x3.8 props on it and 4 meters, i could speak to and hear what two people 5 meters from me were saying.
wizprod is offline Find More Posts by wizprod
Old Nov 09, 2010, 10:32 AM
Joined Jun 2008
They sound loud in the inflight videos because the mic is on the camera. I videoed an out doors wedding ceremony and did not bother anyone there.
Old Nov 09, 2010, 10:49 AM
Joined Nov 2010
They sound load in the inflight videos because the mic is on the camera. I videoed an out doors wedding ceremony and did not bother anyone there.
Wow! That's really impressive. I guess it's time to start ordering parts then
(just kidding, there's a whole lot of planning that comes before that)
Old Nov 09, 2010, 10:54 AM
Joined Jun 2008
Do you really think so?
Old Nov 09, 2010, 12:00 PM
Joined Nov 2010
You mean this isn't a one-weekend project?
Nevermind
Old Feb 11, 2014, 02:59 PM
Palm Harbor, FL, USA
Joined Mar 2001
Stiff props are also quieter. My Gemfan 10x4.5's are significantly louder than my APC 10x4.5MR's and HQ Prop carbon composite 10x5E's.
The flexy props deform under load and sound...flappy.
AdrianM is offline Find More Posts by AdrianM
Old Feb 11, 2014, 04:51 PM
United States, NH, Fitzwilliam
Joined Jan 2014
lunacy
i was trying to think up a method of active noise cancelation being broadcast from the quad to completely cancel constant prop sound.?!. who knows. mike it and pipe it at the source? not going to rip appart a 300$ set of seinhausers to figure it out though.
mokermeister is offline Find More Posts by mokermeister
Old Feb 12, 2014, 09:04 AM
Joined Mar 2001
You could do a lot of good before going to that length.
Precision balancing your props will reduce noise
Stiff props reduce noise
Good motors with quality bearings reduce noise
Lower PID values reduce noise
Stiff frames with no long unsupported areas resonating are quieter.
Old Feb 12, 2014, 09:18 AM
gyro, simonk n call it a day
lockwood's Avatar
United States, NJ, Hamilton Township
Joined Jan 2013
I once built a 450 clone with 800kv 2212's 10/4.5 SF APC's I meticulously balanced the motors and props and measured CG, well lubed bearings. Ran a Naza no GPS. It was completely silent at about 8' away, 6-8' high. It was an efficient machine and to describe it here really does no justice. Haven't been able to replicate it with any other setup. Got about 13 min from a 2200-20c bat I think it was 1100g AUW , ill post exact setup here in a little
lockwood is offline Find More Posts by lockwood
Build Log Variable pitch multi-rotor copter :: Development Stage outsider787 Multirotor Talk 267 Jan 29, 2013 12:10 PM
Discussion Easy Copter Colibri V4 vibration and noise problem Tom Lauten Coaxial Helicopters 3 Nov 02, 2010 08:54 AM
Question What battery to my Multi copter? godislamm Multirotor Talk 1 Oct 27, 2010 04:49 PM
Discussion What's the smallest Multi-copter you've seen tonkajeep34 Multirotor Talk 17 Sep 23, 2010 11:25 PM
Discussion Multi copter question crashcam Multirotor Talk 1 Jul 31, 2010 04:19 PM
