Old Jan 09, 2016, 02:20 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Originally Posted by kodak_jack View Post
Yes, BUT, the polarity is opposite, so, watch how you plug them in.
There are clear instructions on the MMW web site
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Jan 12, 2016, 04:34 PM
John63 is offline
Find More Posts by John63
Vancouver, Canada
Joined Jan 2010
On manual my NQX is pretty uncontrollable. I can hover around but as soon as it gets tilted bit it just goes off. I use and DX8 and have tried different amounts of expo but it is still wild.
My Night Hawk is so calm on manual with a CC3D.
It is the nature of the little beast or do I just have to get used to it?
Thanks for ideas in advance.
John63 is offline Find More Posts by John63
Old Jan 12, 2016, 06:10 PM
George1234 is offline
Find More Posts by George1234
Hamilton Ont.Canada
Joined Feb 2007
Are you flying it in red mode or blue mode? Mine is crazy in red mode, but quite docile in blue mode.
George
George1234 is offline Find More Posts by George1234
Old Jan 12, 2016, 06:32 PM
donsinger1 is offline
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
Nature of the beast in red mode.
donsinger1 is offline Find More Posts by donsinger1
Old Jan 12, 2016, 06:56 PM
John63 is offline
Vancouver, Canada
Joined Jan 2010
Yes, it is crazy in red. Blue is pretty docile. I wanted to practice flips and rolls but it may take some time and perfectly still air before I can get it to fly in a straight line to do that.
The other thing I have notice is that it sure flies better with my DX8. I had never flown one with the RTF Tx. The batteries have lots of charge but it wanders, goes up and down like a yoyo, like it is heavily drugged.
Thanks guys.
Old Jan 14, 2016, 03:52 PM
CraigHB is offline
Find More Posts by CraigHB
it wasn't me
CraigHB's Avatar
United States, NV, Reno
Joined Dec 2014
The Nano QX is in rate mode when the LED is red, Blade calls that agility mode. It feels similar to my CP helis that traditionally fly in rate mode. When the LED is blue it's in attitude mode which self levels. Blade calls that stability mode Your CC3D has the option of rate mode, attitude mode or rattitude mode (a hybrid of the two). When running your CC3D in rate mode it should feel similar to the Nano QX in agility mode.
That said, the Nano QX does have a lot of control authority in rate mode. It's capable of pretty high rates which makes it sensitive at the controls. Assuming a fully programmable transmitter, you should to drop the rates and use a lot of expo to get it to feel less twitchy and more manageable. Personally I run 60% on the aileron and elevator rates with 50% expo. That's a low rate compared to my helis which I usually run 70 to 100%. I run 50% expo typically, but it depends on the transmitter since expo scales vary with the make of transmitter. I use a Spektrum DX6 which would not necessarily be the same as 50% expo with another make.
In any case, rate mode is a lot harder to fly than attitude mode as the mode does not self level. It will remain in whatever attitude you put it until you provide a control input. It normally feels like trying to balance a marble on a tray. If the controls are too sensitive it becomes an impossible task.
CraigHB is offline Find More Posts by CraigHB
Old Jan 14, 2016, 09:01 PM
Dennis S is offline
Find More Posts by Dennis S
Orlando FL
Dennis S's Avatar
United States, FL, Ocoee
Joined Jul 2013
I have been practicing in agility mode ( red mode) , with lot of space I can do flips, well they are not really flips more like big loops, is it possible to do tight flips like you get with quads that have a flip button. The challenge of agility mode is what separates this quad from cheaper toy grade quads
Dennis S is offline Find More Posts by Dennis S
Old Jan 15, 2016, 02:22 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by Djob View Post
If u want 5 mins of hard sports flying with juice to spare..get the mylipos 205mah from mmw. You wont be disappointed
Toda I finally got these batts you recommended - and tried them out. They are great. Breathes new life into my Nanos. Thx again.
Tim Green is online now Find More Posts by Tim Green
Old Jan 20, 2016, 12:13 PM
fasteddie123 is offline
Find More Posts by fasteddie123
FastEddie123
United States, MN, Lake Elmo
Joined Nov 2013
When I tried to order those they were out. So I got some nanotech 200ma 35-70c .. I get 7 mins with a smd light kit - very happy with them. ( just another option ) - eddie
fasteddie123 is offline Find More Posts by fasteddie123
Old Jan 26, 2016, 02:04 PM
FastEddie123
Joined Nov 2013
Thanks guys.
Adjust your throttle curve - step 1 about 30% or so - the others semi flat up to 100% (or maybe less for indoors) . makes it less twitchy in the sweet spot.
Old Feb 12, 2016, 09:09 PM
Dennis S is offline
Orlando FL
Dennis S's Avatar
Joined Jul 2013
Nano QX auto flips
I just found out how to make the Nano QX do automated flips ( 360 degree loops and rolls) While in stability mode give the quad full right stick and hit the agility mode button, release the right stick to it's center position and the QX will do multiple flips ( loops or rolls) No other input is needed , here is a short video
Note; in the video I said left stick , I meant right stick
This might be old news for some but I had always thought the QX could only be flipped manually
Blade Nano QX auto loops (1 min 7 sec)
Old Feb 15, 2016, 07:46 PM
Djob is offline
Find More Posts by Djob
Joined Jun 2015
So did i, good find. Will try it
Djob is offline Find More Posts by Djob
Old Feb 17, 2016, 02:00 PM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
FYI: If you have the FPV model put some hot glue or silicone on the camera wires, where they attach to the board. . There is already silicone on the FC. My red (+) came loose and shorted to the pad or black (-) in mid flight. It burned through the insulation of the battery wire and Y harness in about 10 places, causing more shorts.
Fried my camera. When I pulled off the double sided tape, from the back of the camera unit 1/2 of a IC came with it (the little black square right next to the wire terminals) = $75.
You can be sure I hot glued my new one.
glmccready is offline Find More Posts by glmccready
Old Feb 17, 2016, 07:10 PM
Dennis S is offline
Orlando FL
Dennis S's Avatar
Joined Jul 2013
Here is some more video doing auto flips with my Blade Nano QX, I kept it a little lower so you can see it better. What I am doing here is taking it up about 30 ft. in stability mode, apply full right stick ( any direction is fine even diagonal) and hold it , then in one quick movement engage agility mode, move right stick all the way in the opposite direction, hold it and apply full throttle. This will give you a series of tight flips, I then go back to stability mode to keep from hitting the ground.
Blade Nano QX Auto Flips (1 min 19 sec)
Old Feb 18, 2016, 03:32 PM
Gary
glmccready's Avatar
Joined Mar 2011
Nano QX just one week old and already the LVC is at 4.05v. Had a similar problem with my other one, but only after 3 months or so. My other Nano doesn't shut down till 3.7v (now). Sure wish I could bypass the LVC. Don't need it on the Blade CPX, ans sure don't need it on this esp. at 3.7v. 3.3V I could see???
Discussion Ares Ethos QX 75 Nano-Micro RTF Quadcopter Jason M Mini Multirotors 270 Oct 15, 2015 10:19 AM
For Sale Ethos QX 75 Nano-Micro RTF Quadcopter, Red - $100+ worth of extra parts included vcantrell Aircraft - Electric - Multirotor (FS/W) 3 Dec 20, 2014 06:46 PM
For Sale New Unopened Blade Nano GeicoGecko Aircraft - Electric - Helis (FS/W) 4 Dec 16, 2014 07:23 PM
Sold Getting out sale.. Blade Nano CPX Brushless + Extras and 10 Brand New Batteries UGT10 Aircraft - Electric - Helis (FS/W) 1 Apr 08, 2013 02:25 AM
Brand new Great Planes F86 Sabre EDF mini jet for Blade Nano Cpx or Tricopter aviator422 Non R/C Items (FS/W) 0 Mar 29, 2013 02:37 AM
