Old Nov 15, 2012, 05:18 PM
Alexandre Lopes is offline
Find More Posts by Alexandre Lopes
Thermal Fisherman.
Alexandre Lopes's Avatar
Brazil, São Paulo, São José do Rio Preto
Joined Jan 2012
Build Log
Terminator HLG - Videos: Javelin launch => Thermal Flying
Hello,
This week started building a terminator, and would like to share the building.
In my country, there is little interest in constructions of HLG gliders, for this reason, I am trying to learn English to communicate with the users of Rc Groups.
I have a real fascination for hand launch gliders, and thermal flight, for some time I've been practicing releases javellin and discus.
Some of my flights thermal, can be seen in this channel >> http://www.youtube.com/user/AlexandreBassPlayer
I'll post what do I have so far, and as the construction is progressing update the topic.
All information required for construction of the terminator, see the link below: http://www.charlesriverrc.org/articl...torhlgsite.pdf
Photos by charlesriver rc
For the used pod balsa1 / 8 and the V-tail 3/32.
The fuselage ready and without electronics, was 72 grams, I hope to get in 250g RTF.
I tried using the airfoil Zone-V2-60, but the wing was very thin, would not achieve adequate reinforcement put the covers with tape.
I cut a second wing using the airfoil S4083, this way I can properly reinforced with tape.
Comments and suggestions are welcome.
Alexandre Lopes is offline Find More Posts by Alexandre Lopes
Old Nov 15, 2012, 05:33 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Ya know, despite the fact that modern DLGs are so advanced compared to older javelin launch gliders like the Terminator, I still kinda want to build something old school. Your project looks like it's coming along well. Best of luck with it!
E cara, seu ingles é muito bom. Onde fica São José do Rio Preto? Morei dois anos em São Paulo e Sorocaba.
bwill6 is offline Find More Posts by bwill6
Old Nov 15, 2012, 06:15 PM
Thermal Fisherman.
Joined Jan 2012
I'ma big fan of old school HLG, long time to find specifications of models Feather XL and Encore to build . These two are my favorites, climbed too high.
Thanks for following the topic, I hope to finish construction in the coming days.
Ainda estou escrevendo com ajuda de tradutor, mas espero conseguir aprender a escrever em inglês.
São José do Rio Preto fica próximo a Catanduva, dá uns 450km de São Paulo, fica bem no interior de mesmo. Para se ter uma ideia, não existe planadoristas na região, apenas eu e outra pessoa.
Old Nov 15, 2012, 07:02 PM
glidermang is offline
Find More Posts by glidermang
Alexandre:
Takes me back. I sure built my share of Terminators. Five, altogether.
I could no more throw one today than I could jump to the moon.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Nov 15, 2012, 07:26 PM
Thermal Fisherman.
Joined Jan 2012
Originally Posted by glidermang View Post
Alexandre:
Yours, Greg
Greg, your visit will be of great help.
Having built several terminator, what the ideal weight to get a good launch javellin?
The standard boom is 19 ", you got to build some 16" (short boom)?
Today you could fly the Eagle class.
Old Nov 16, 2012, 06:29 AM
Alexandre:
The ideal weight for a javelin launch is.... as light as possible!
I built Terminators (5), Chrysalis (7!), Leafs (2), one Monarch, one Sunbird (the heaviest ever built) and one Viltius. The Viltius (maybe about 9 ounces) was a composite design briefly offered by NESail, now defunct. It lasted the longest and I still have the fuselage. The Leafs were the lightest (pod-and-boom, unique built-up wing fabricated from balsa and thin, carbon spars) but too light to survive long. They flew the best.
No kidding at all, though: build as light as possible for best performance.
Yours, Greg
Old Nov 16, 2012, 08:09 AM
Thermal Fisherman.
Joined Jan 2012
Alexandre:
Yours, Greg
Thanks for the feedback, I will take the utmost care to complete construction in 250g rtf. (9oz)
I've read a lot about the Monarch, a glider is very good and beautiful lines.
It is very good to talk, with someone who has lived the pure HLG. In the javelin launch, everything is very fast, has to drop the bubble to rise. If you can not read thermal, you make the turn, bring in hand and toss again.
Leveraging his experience, what better way to have good support at launch?
- Making a hole at the bottom of the fuselage, behind the CG?
- Installing a horizontal pin peg in the fuselage, forward of the CG?
If you can help me, thank you.
A.L
Old Nov 16, 2012, 08:47 PM
Thermal Fisherman.
Joined Jan 2012
Continuing to build ...
I glued the ribs on the wing, and cover with tape, now need to install the electronics.
The glider is weighing 197g, I believe it will stay in 250g, with the cg in place, and ready to fly.
My Hlg's
Terminator almost ready.
Old Nov 16, 2012, 09:52 PM
Alexandre:
For the Terminator, I built the pod with a bit of a flat portion at the end of the pod. I pushed the airplane away with my index finger. The trick for me was to develop a long, accelerating throw, and maintain contact with the airplane for as long as possible.
Also, for javelin launch, be sure to warm up before throwing seriously. Move your arm around, get lots of motion in the shoulder. You can hurt yourself - which is another reason I really like DLG.
Good luck!
Yours, Greg
Old Nov 17, 2012, 05:46 AM
Thermal Fisherman.
Joined Jan 2012
Alexandre:
Good luck!
Yours, Greg
Grerg,
Thank you, one more time.
I'll install a pin peg hoorizontal the fuselage, behind the CG, will support for the fingers, index and middle. This way you extra support with your thumb and ring finger.
I'll do the heating, not to injure their arms or shoulders, really javellin releases can be very dangerous. I have seen it.
I liked the tip about speed and keep up as long as possible with the glider, try this.
Later, beginning the installation of electronics.
Old Nov 17, 2012, 08:18 AM
I can see I didn't fully answer your question about throwing.
I came to prefer the flat spot at the back of the pod, but several of my various airplanes had horizontal pegs through the fuselage. Those designed by DJ Aerotek (Chrysalis and Monarch) had the peg near or perhaps slightly forward of the CG. The Viltius had it slightly aft. Both worked fine. Pegs were sometimes a flat piece of spruce (which could be airfoil shaped to reduce weight and drag), sometimes a light piece of carbon tube. A popsicle stick (if you have those in your country) would work fine. The total load is actually quite small. Just make sure that it is secure to the structure.
An alternative is a hole in the bottom - insert your index finger and push.
The goal is always the same: don't use force, instead concentrate on acceleration. Keep contact as long as possible.
Yours, Greg
Old Nov 17, 2012, 09:11 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
That's nice that you are building and flying your own glider's. A couple week's ago after a contest I bought one of Doug Montgomery's Orion DLG's and it's the best overall DLG I've ever had. Doug is one of the few people I know that compete's with his own design. I like to build as well and my CR Climaxx that I scratch built from plan's has a S-4083 airfoil and is a great flyer both at the field and the slope and I love the full flying rudder. I'm very glad Chip Greley has bought the right's to manufacture the CR line of glider's. I used to fly a Maple Leaf Encore and I have the complete book of instruction's. It's sad that it is no longer manufactured. And mine is no longer flyable. I like the Orion so much I may have to buy Doug's 8.5oz one as well. Next week he should be getting his CNC mold's for his one piece pod and boom, can't wait to see the first example. Dave
prodjx is offline Find More Posts by prodjx
Old Nov 17, 2012, 09:12 AM
bwill6 is offline
Joined Jun 2011
I would be willing to bet that a 3mm dowel will have lower drag than a hole large enough for your finger. I guess both have been done successfully, though, so do whatever is more comfortable to you.
Old Nov 17, 2012, 07:52 PM
Thermal Fisherman.
Joined Jan 2012
Yours, Greg
Greg,
I got a lesson on HLG. I'm owe you a beer.
In ihlg dvd 2000, noticed some models with pin peg in front of the CG.
I'll trying to find the best location for my ergonomics. But I will follow your tip and put a pin lightweight carbon.
Finalized the glider in the late afternoon and went to do a field test. I thought the 4 inch tips, just for a polyhedral wing. I tried to turn tight and saw that it would not succeed.
I had two small field, the surface of the v-tail (elevator / rudder) broke on one of the landings, sanded too, were fragile and ended up flying with surfaces of different sizes. Problems easily solved at home.
The wing lacked reinforcements, after heating, a release made ​​stronger, and due to compression fatigue had a little to one side.
Will I be able to fly tomorrow to repair with more time, and in the open, today was flying behind a bush surrounded, and no chances of detecting any bubbles.
Let's see if I record a video tomorrow better, preferably with thermal flight.
Old Nov 17, 2012, 08:18 PM
Thermal Fisherman.
Joined Jan 2012
Hello Doug,
I always liked to build my own planes, satisfaction duty flying something you built is too large.
Projects of Doug Montgomery, are very good, very simple and functional, directly or indirectly, influenced many people in Brazil, with its dlg's kfm.
Good luck with your new aircraft, if you have a topic so I can follow the assembly, send me.
These days I got one. Pdf on the various versions of Maple Leaf Encore, do not know if this article, I think you'll like. It's inspiring.
ftp://ftp.blarg.net/users/red/RCSDEncorePearson.pdf
If you know where I can find specifications Feather XL, let me know. I would like to build a clone or something very similar.
Wanted Javelin Launch HLGs Buddy Roos Aircraft - Sailplanes (FS/W) 5 Jun 26, 2012 07:22 AM
Sold Javelin styled Hlg... soarsimon Aircraft - Sailplanes (FS/W) 5 Jun 24, 2012 02:54 PM
Best position for the throwing peg on a "javelin launch" HLG Masterpiece Hand Launch 4 Jun 14, 2004 12:49 AM
Terminator Hlg For Sale mothflyer Aircraft - Sailplanes (FS/W) 22 Feb 19, 2004 01:54 PM
Better boom alignment for Terminator HLG claymeyer Hand Launch 1 Oct 15, 2003 10:52 PM
