Old Sep 14, 2010, 09:48 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
TriCopter Yaw control setups..
Lots of threads around here with lots and lots of posts..
I am currently working on a T tricopter and am pretty sure I've got 95% of my yaw device thought out..
I'm planning on using left over T-Rex 450 parts - since I have quite a few from the occasional oops..
I thought since the threads have gotten so big, it might be nice to have a thread full of yaw ideas..
I'll post up my concept when I get a little further into it..
Right now I'm trying to work how how to mount the "other" side of the blade grip on to the tail boom. Mounting it permanently would be easy. Mounting it so that I could change out the spindle if I should bend it is the part that is slowing me down.
As just a start here are some pretty interesting designs..
A CNC-ed support by Ulix, quite pro-looking
http://www.rcgroups.com/forums/showp...&postcount=237
The Shrediquette, showing that the servo can also be mounted on the moving part of the arm
http://shrediquette.blogspot.com/p/s...uette-dlx.html
http://www.rcgroups.com/forums/showthread.php?t=1089221
The Delta-copter, with an interesting thrust deviation solution (very good "out of the box" thinking)
http://www.rcgroups.com/forums/showthread.php?t=1297596
Tram is offline Find More Posts by Tram
Old Sep 15, 2010, 05:20 AM
anspe is offline
Find More Posts by anspe
anspe's Avatar
Linköping, Sweden
Joined Dec 2002
Here´s how I did it on my first tricopter. It´s a blade holder from a Raptor that sits on an aluminium tube glued into the boom. The aluminium tube has a threaded inside for a screw that holds the blade holder in place. (Did that sentence make sense?)
Best regards,
Anders
anspe is offline Find More Posts by anspe
Old Sep 15, 2010, 05:26 AM
anspe is offline
anspe's Avatar
Linköping, Sweden
Joined Dec 2002
And here´s the yaw mechanism I'm building right now. Check the aerial photography forum for my T-copter build.
Anders
Old Sep 15, 2010, 08:11 AM
Bisso is offline
Find More Posts by Bisso
Bisso's Avatar
France
Joined Jun 2007
Nice idea to have all yaw control setups idea in one thread, I had to search amongst numerous threads when looking for inspiration for my design so this thread may be very helpful
Here's a concept plan of the tricopter I'm going to build in the coming weeks
Made from a 250 size tail boom cut in the middle with 8x3x3mm bearings (450 size tail bearing) inside and a threaded axis running through them.
The motor holder is made of horizontal tail fin holders (250 size)
The clamp on the body side is a tail boom holder (250 size)
The servo may be attached to the body by mean of adhesive and a collar, maybe I'll make something more sophisticated if needed
Section view:
Code:
          ____________________________               _____________________________
 - Nut - - - Bearing - /// - Bearing - - - Spacer - - - Bearing - /// - Bearing - - - Nut -
         |_____________________________|            |_____________________________|
Physics simulation:
Google Sketchup - Sketchyphysics - Tricopter Rudder (2) (0 min 44 sec)
I'll let you know how this system is coming along in the next few weeks
EDIT:
Some progress with a slightly modified design
Made from a 450 size spindle shaft with 450 size tail bearings glued by red threadlock on the shaft and the tube instead of being held in place by a nut or collar
It's a bit hard to glue bearings without putting glue into them but that works great if done patiently
The arm is moving totally freely so that's cool, I steel need to add the servo holders and servo, and the ball on the moving part
Now we have this:
Code:
EDIT 2:
parts received, here's the result:
Hk250 tricopter - rudder test (0 min 36 sec)
Complete build log: http://www.rcgroups.com/forums/showthread.php?t=1321027
Bisso is offline Find More Posts by Bisso
Old Sep 15, 2010, 10:38 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Some good ideas here...
I'll take some pics of mine one I get it started, I'm still in the "planning stages."
Latest blog entry: Wow.. 3 years..
Old Sep 15, 2010, 11:03 AM
Bisso is offline
Bisso's Avatar
France
Joined Jun 2007
Here are some interesting systems:
NB: if the thread tends to get some activity, maybe it would be a good idea to reference posts containing a design in the first message
Old Sep 15, 2010, 05:35 PM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
This is mine Two ball bearings and a piece of plastic.
elossam is offline Find More Posts by elossam
Old Sep 16, 2010, 11:38 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, I'll definitely do that..
That's a pretty good idea!
Old Sep 16, 2010, 12:16 PM
potluck is offline
Find More Posts by potluck
Joined Jun 2010
Subscribed...Excellent idea!
Perhaps what may be included in the thread are "off-the-shelf" mechanisms and linkages or parts of mechanisms/linkages.
I do not have heli parts laying around or other heli's to cannibalize so I will need to shop for parts.
potluck is offline Find More Posts by potluck
Old Sep 16, 2010, 12:43 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Tram,
Nice thread. Let the ideas flow!
Added to the Quadrocopter and Tricopter Mega Link Index
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Old Sep 16, 2010, 05:21 PM
elossam is offline
Joined Feb 2006
As it seems to be interesting for some I´ve taken some more pics of the way I did it.
The cube is nylon made, a passing hole a bit larger in diameter than the CF tube plus two bearing emplacement on each site to acomodate the bearings and a plastic cap at the end of the tube to prevent the block to fall outside the tube. The engine directly screwed to the nylon cube as wel as the two servo ball linkages on each extreme of the front face finished the system.
The servo and fixed engines are attached to the CF tube using plastic clamps comonly used to secure small tubes and wires to a wall with a screw.
Nothing more.
Old Sep 17, 2010, 04:01 AM
X-Ilmar is offline
Find More Posts by X-Ilmar
X-Ilmar's Avatar
Estonia
Joined Sep 2005
My Yaw 1.0
Hei!
Here is my Yaw versions.
Servo is HD-1810MG
What materjal for pinch blocks, I don't know... 15mm thickness. It is slightly soft...
Second, belt-cp blade holder and feathering shaft.
I have new version with towerpro motormount and belt-cp mainshaft, pictures later...
Best regards,
-Ilmar-
X-Ilmar is offline Find More Posts by X-Ilmar
Old Sep 17, 2010, 09:37 PM
Tifani is offline
Find More Posts by Tifani
United States, IL, Park Ridge
Joined Apr 2010
Hi !
Aluminum body with brass tubing insert as bearing.
Servo Hextronic MG14.
So far no problems.
Tom
Tifani is offline Find More Posts by Tifani
Old Sep 18, 2010, 01:18 PM
Bisso is offline
Bisso's Avatar
France
Joined Jun 2007
Something I'd call "quick and dirty" way
from: http://www.rcgroups.com/forums/showthread.php?t=1309716
Good to see you can fly so well with a quite crude (but effective nevertheless) solution
Old Sep 18, 2010, 08:21 PM
Alexinparis is offline
Find More Posts by Alexinparis
Alexinparis's Avatar
Paris, France
Joined Jun 2009
another quick and dirty way.
Alexinparis is offline Find More Posts by Alexinparis
Discussion Adrenalin 400 control setups rhino600 High Performance 2 Jul 30, 2010 10:46 PM
Discussion do i need yaw control? bradleyK Beginner Training Area (Aircraft-Electric) 1 Jul 26, 2010 03:53 AM
Discussion Using control surfaces to counter motor torque/yaw? outsider787 Multirotor Talk 2 Apr 14, 2010 11:47 AM
Help! Gyro as a yaw control and also and ground run stability pinkburns Fuel Warbirds 5 Jan 24, 2010 09:34 PM
Discussion New tail fan/yaw control speed controller Majortomski Blimps 1 Jan 15, 2010 04:20 AM
