Old May 09, 2013, 05:12 PM
SoCal Flyer
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
Flight Matrix Generation
I'm in a position to bring back this discussion...
http://www.rcgroups.com/forums/showthread.php?t=1514164
To bring this conversation back to the forefront, has anyone come up with anything better?
It almost seems that there should be a permanent "reasonable" matrix for each of the combinations of number on a team and number of groups...
It seems like a lot of work to actually create a brand new draw for every event. For instance, if you pre-create a matrix for 5 teams of 4 for 10 rounds, then you can store that, and if the event you have has 5 teams of 4, your system just uses that matrix, filling in the blanks...Just do that a bunch of times for the different possible event types and permanently store the matrices.
That's essentially how they do most other tournament draws. They just pick the initial random order, and follow the lines...
And yes, I realize that gliderscore does it already, and does it pretty good. I'm in a similar situation as jim was in that I've created an on-line scoring system, and this is the last piece...
Any comment?
Tim
ttraver is offline Find More Posts by ttraver
Old May 09, 2013, 06:31 PM
Joined Jan 2003
This is also interesting as the J TS is coming up this year and my system may be used again. I have focused on scripts to load Gerry's MDB and get the data back out for my system. I think you are right that we could use his program to generate a complete set of matrix and reference them. This is for the simple assumptions that there are no frequency conflicts to deal with and we have team protection. In reality we never get more than 16 rounds in so a set of matrices for 16 rounds for teams of 4, 5, 6 pilots and numbers of teams between 3 and 14 would fill all of my possible needs.
It could take some work but I could use a script to create a set of inputs for gliderscore, run the matrix, export it and process it into a format suitable for storage to be used by another program to populate the matrix...
Hmmm brain churning - sounds like an exercise for the plane ride tonite...
Jim
jimsoars is offline Find More Posts by jimsoars
Old May 09, 2013, 06:39 PM
SoCal Flyer
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
Hey Jim,
Yeah, it kind of seems like a lot of extra programming cycles to be creating these matrices every time, for every event, no matter how small.
We should probably just develop a system to build out those matrices that become static for those permutations and then we can all just use those matrices when creating our events.
That way you can run 10,000 iterations if you want for one matrix, and once you're happy with the pilot to pilot distribution, you pick one and that becomes the defacto standard for that combination of teams and groups.
On a side note, I'm just about to launch my own scoring and database web site. I kind of developed it without really knowing about everyone else's existing stuff, so it does essentially the same thing as your site and gliderscore and f3kscore, etc...It just has them all in one place (i.e. it will do F3B, F3F, F3J, F3K and TD events)
Tim
Old May 09, 2013, 07:06 PM
Australia, VIC, Melbourne
Joined Aug 2010
GliderScore gives you evenly sized groups regardless of the number of pilots in each team and optimises the draw in all circumstances including taking into account team and frequency issues.
If all teams have the max pilots you will be fine with a default matrix.
But if, for example, you have a max team size of 6, and some of those teams have only 4 or 5 pilots then your idea of a fixed default matrix will end up with some groups full, and some short a few pilots. It won't be pretty and it certainly won't be optimised.
Gerry
Gerry.Carter is offline Find More Posts by Gerry.Carter
Old May 09, 2013, 07:38 PM
SoCal Flyer
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
Gerry,
How would that be different in the gliderscore case?
If you have say teams of 5, but occasionally a team has 4 or 3, won't you have groups that have one or two less pilots on occasion?
t
Old May 09, 2013, 07:59 PM
Joined Aug 2010
Originally Posted by ttraver View Post
Gerry,
t
No. GliderScore always has a maximum variation of 1 in group size. In any round, the earlier groups drawn are always the larger size, and if necessary to balance the numbers, one or more of the later groups drawn will be one less pilot in size.
Old May 09, 2013, 08:29 PM
SoCal Flyer
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
so, actually, the answer is yes...occasionally you will have groups with one less pilot in them. The difference appears that if you have a group with two less, that you spread it out over two groups with each only having one less...
I'm not trying to bash your program Gerry. Its certainly in wide spread use and is awesome...
I see your point about a default matrix though, because depending on the team sizes, there might be a group that has 2 less pilots...
t
Old May 09, 2013, 09:04 PM
Joined Aug 2010
t
The point really is that with a default matrix and teams that are incomplete, you will have groups with gaps in them. That is, no pilot where a pilot should or could be.
GliderScore does not do this. It fills every group as best it can.
You can't always have the same number of pilots in every group because the numbers don't allow it. So you get groups that are different is size by one pilot. That's not the same as having a gap. It just happens to be as close as you can get to having the same number of pilots in each group.
Old May 09, 2013, 10:59 PM
Joined Jan 2003
I think what we are saying here is that the unfilled slots in a team are considered BYE pilots. You do not want a bunch of the BYEs to line up in a group - shorting the pilot count for the group. It is a good point. The static matrix only works well for events that are mostly full.
I knew that seemed to easy...
Jim
Old May 09, 2013, 11:05 PM
SoCal Flyer
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
couldn't you then even have statics for unfilled slots as well?
For instance, you could have a static matrix for 4 teams of 4 and 1 team of 3, or 3 teams of 4 and one team of 3, etc...
t
Old May 10, 2013, 07:58 AM
Joined Jan 2003
I think this is not really worth it. Assuming that you need a separate matrix based on the number of teams you have to get the statistics right then for an event with 4 pilots per team and 14 teams and never less than 4 teams, you have 396 permutations of the matrix. Add in matrixes for 5 and 6 member teams and you have 1485 permutations.
If the number of rounds affects the actual matrix generation then this number jumps dramatically higher. For me it is easier to use Jerry's program by exporting my pilot data in a format that is usable in his DB, then running the matrix and then exporting the data in a format I can import back into my system.
I also don't agonize over this too much. For club events with less than 20 pilots I just do an easy random selection. You don't get that much flexibility in the matrix with smaller numbers so it does not seem to me to make a lot of difference. I just do this for the bigger events.
Jim
Last edited by jimsoars; May 10, 2013 at 08:00 AM. Reason: bad wording in the first line
Old May 10, 2013, 09:00 AM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Would have to agree with you, Jim, after running so many matrices over the years ... sometimes the random draw, even picking golf balls from a bucket works as well or better than the coded solution
tkallev is offline Find More Posts by tkallev
Old May 10, 2013, 05:51 PM
Joined Aug 2010
If that is true then the coded solution is particularly poor.
A structured draw produced by GliderScore will always be superior to a random draw regardless of contest size.
And random draws can produce awful results. For small contests it is better to manually attempt to replicate a coded structured draw than to use a random draw.
Old May 10, 2013, 09:36 PM
JW
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
This needs a large ROFLMAO smiley to go with it.
TK, I'd be firing your code writer...
We have found Gerrys program to be really quite nice in running contests here. A laptop and a printer that runs on a 12V inverter, and one can show up on the field, sort out the contest entries, make a rational non-random draw, print out score sheets, and run the comp.
BTW, I hate flying against one guy 90% of the comp and not flying against another guy for the full comp! This tends to occur repeatedly with the random draw concept.
BTW#2 4 Gerry I think that the NZ soaring SIG may have a small token to deliver to you at the upcoming Jerilderie comp...
Joe W is offline Find More Posts by Joe W
Old May 11, 2013, 02:22 AM
Life is a big, fat mortgage
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
A Hobbit?
DrFragnasty is offline Find More Posts by DrFragnasty
Discussion Witespy Pro 2.0 Flight Controller for MegaPirate Next Generation (MPNG) Greg Covey Multirotor Electronics 102 Today 08:27 AM
For Sale Custom Airstar Super Mongoose 3 hour flights, landing Pad, generator, Fuel Jug, logs rjhpilot91 Aircraft - Fuel - Helis (FS/W) 1 Apr 19, 2013 05:59 AM
Sold HK Matrix and Piaget EPP 3D kits Tony Twoskids Aircraft - Electric - Airplanes (FS/W) 6 Apr 17, 2013 06:47 AM
Discussion F3J Flight Matrix Generation jimsoars Multi Task F3X 27 Oct 06, 2011 08:26 AM
Build Log 90mm Matrix Video Added! Test flight complete. fh64_lucky Electric Ducted Fan Jet Talk 224 Nov 01, 2010 10:24 AM
