Old Jul 09, 2014, 09:26 AM
Blue Sky Mining
batballs's Avatar
Australia, VIC, Miners Rest
Joined Feb 2009
Originally Posted by RCTodd View Post
I lost two 40 size planes w/ i/c power using the 6chan. DSM2 receivers and never figured out why. I ordered a couple DSMX w/ sats to try out.
So im wondering if they are suitable for i/c planes.
I suspect the main issue is vibration and not having a satellite as Daedalus has posted above.
The early weak aerials could be a vibration weak spot.
The old school practice of wrapping the receiver in foam should be followed. Mounting any Rx directly to the fus of an ic plane is not a good idea.
batballs is online now Find More Posts by batballs
Old Jul 09, 2014, 10:33 AM
ukbren's Avatar
United Kingdom, Derbyshire
Joined Aug 2011
i fly a .53-powered Yak with Futaba S3152 digital servos all round (except throttle, which utilises an S3003), a 6V NiMH flight pack and a Lemon 8-channel + satellite. No problems at all. I did read up on the servo specifications beforehand to make sure they didn't overload the receiver. I also blobbed some hotmelt glue on the antenna attachment points (antenna base to airframe point below it).
I'm mid-build on a .91 FS P40 Warhawk, into which I'll be installing the same Lemon RX+Sat combo. Standard servos all round here, but I'll be a little more cautious with the four-stroke as vibrations do tend to be a bit higher (from what I understand, anyhow).
ukbren is online now Find More Posts by ukbren
Old Jul 09, 2014, 11:08 AM
United States, WI, Fond du Lac
Joined Sep 2008
Lemons are so cheap, why not just use multiple receivers to split the loads. You can bind as many DSM2 receivers to a model memory as you need.
pmullen503 is offline Find More Posts by pmullen503
Old Jul 09, 2014, 11:27 AM
Cheese5's Avatar
United States, CA
Joined Jul 2010
Check your mounting first. Make sure the antenna has clear line of sight with your transmitter antenna from all angles if possible (if not you may need a satellite receiver to cover that spot, while with other companies you just use your extended whisker antenna and place that in a better spot, that's why IMHO extended antennas are more flexible in their installation versus a satellite receiver, its cheaper and simpler). Also if possible the antennas on the airplane and transmitter should be vertically polarized (running up and down) to get the most range.
It could also be your noise floor issue (DSM2 had a few holes in it), do a range check before you fly and see if it passes, there could be a lot of 2.4ghz users around your area.
Cheese5 is offline Find More Posts by Cheese5
Old Jul 09, 2014, 12:37 PM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
One of the things that may merit more discussion, is the fact that most extended antennas have a fair amount of loss at 2.4. I've heard numbers as high as 3db.
Rich in ILM is offline Find More Posts by Rich in ILM
Discussion Hobby king LANCASTER LEMON Lord_Of_Fear HobbyKing 43 Mar 11, 2013 11:56 PM
Discussion When Life Hands You Lemons..... Real Ira Life, The Universe, and Politics 14 Nov 02, 2012 01:35 PM
Discussion Ever Buy A Lemon Car? A $1.7M Lemon? Big Foot 48 Life, The Universe, and Politics 15 Jun 24, 2006 03:41 PM
Lemon tree very pretty. But the fruit of the poor lemon is impossible to eat. gtstubbs Life, The Universe, and Politics 0 Jan 22, 2005 07:07 AM
Make the best lemonade with the lemons you have KDB@KAM Foamies (Kits) 0 Mar 21, 2003 07:54 PM
