Old Jul 29, 2015, 11:06 AM
Jack_K is offline
Find More Posts by Jack_K
Joined Mar 2015
HELP! Can't get plans off the foam.
I used 3M spray adhesive, but I guess I put it on too heavy. Now I can't get the paper plans unstuck from the foam.
Any ideas on how do it?
Jack
Jack_K is offline Find More Posts by Jack_K
Old Jul 29, 2015, 11:11 AM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Just redo it, not worth the effort. I use school glue on the spots that are waste. Or I just trace over
lightly and it leaves a mark on the foam.
3M spray is just about as permanent as you can get.
BHOFM is offline Find More Posts by BHOFM
Old Jul 29, 2015, 11:12 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
I think I did read that light heat will soften it??
Old Jul 29, 2015, 03:12 PM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
Acetone will save the plans.
dayhead is offline Find More Posts by dayhead
Old Jul 29, 2015, 04:27 PM
Jack_K is offline
Joined Mar 2015
Won't it destroy the foam?
I tried using the heat gun. I was not very successful. Then I mixed a batch of 50-50 water/alcohol in a spray bottle. The Staples paper seems to have 2 layers. The top layer came right off, but the 2nd layer was royal PITA. Lots of rubbing and scrubbing and I got most of the paper off.
Old Jul 29, 2015, 08:47 PM
slow and low is online now
Find More Posts by slow and low
Larry........... parkflyer
slow and low's Avatar
United States, IL, Eureka
Joined Dec 2014
Next time, spray a VERY light mist on the plans, it doesn't take much. Let it dry and then apply plans to the foam. It should come off pretty easy after cutting out the parts.
I have heard of people putting the foam under a warm shower and soak the foam overnight for the paper to come off.
slow and low is online now Find More Posts by slow and low
Old Jul 30, 2015, 04:59 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
Try a bit of scrap foam and isopropyl alcohol, not thinned down. You might need to sand the paper surface to make it easier for the alcohol to penetrate. Leave it to soak and soften the glue. It would be worth doing to check whether it does work.
Mac50L is offline Find More Posts by Mac50L
Old Jul 31, 2015, 05:23 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
I use accellerator, it will desolve the 3m-77 without harming the foam...get a little under the edge, and just spray and work your way....
Frank
burkefj is offline Find More Posts by burkefj
Help! motors spin at different speeds. Can't even get off the ground satimoto Multirotor Electronics 18 Jun 15, 2015 05:11 PM
Help! Help! Can't Get Motor Mount Off! chalmrast Power Systems 5 May 25, 2007 11:55 AM
Discussion Help!!!!! I can't get it off the ground flying_moe Micro Helis 1 May 19, 2007 05:14 PM
HELP!! Can't get this smile off my face! Mike C Life, The Universe, and Politics 31 Dec 07, 2003 08:39 AM
Can't get full throttle, esc seems to cut off motor, please help! Newbie1 Power Systems 10 Dec 08, 2002 02:39 PM
