Old Yesterday, 04:51 PM
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
Originally Posted by onthemark40 View Post
Interesting way in checking thrust. I have seen some people attach a fish scale to tail of plane to measure the amount of pull. Either way you want the maximum amount of thrust but stay within your current limits.
Exactly, re scales yea that is maybe more accurate but too much hassle IMO my method is good enough for me
ckleanth is offline Find More Posts by ckleanth
Old Yesterday, 07:24 PM
Love the Cub
onthemark40's Avatar
Canada, ON, Orangeville
Joined Sep 2012
Originally Posted by Nukiwi View Post
BTW, once you have tried wood props (good ones anyway) you won't want to go back to plastic!
I noticed that Xoar props have been mentioned. Any good wooden props from Hobby King or should I stay away from them. Do the wooden props require balancing like the plastic ones. I would think the higher end props would almost be perfect requiring no balancing.
onthemark40 is offline Find More Posts by onthemark40
Old Yesterday, 07:34 PM
Love the Cub
Joined Sep 2012
The a/c is rather "nose heavy" out of the box, (Alloy spinner, probably does not help mine either) much more so than the HK Slick.
Options were to either put the rudder servo in the tail area, like the Slick, or to extend the battery tray.
Why do you think for the Hobby King Edge they decided to use a pull-pull configuration instead of putting servo in the tail? Are there benefits to the pull-pull, maybe faster or stronger? This is the first plane I have that uses this configuration.
This is also the first plane I have that uses a small tab with a screw to fasten wing to fuselage. Normally I use plastic bolts that go through fuselage into the wing. The way it is setup now you would think it would not be as forgiving in a crash.
Now, what does this button do?
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
I have not seen any good "woodies" on HK, but there are loads of stockists of other quality props in the U.S.
Balance wise, I have yet to need to balance an Xoar prop.
Nukiwi is offline Find More Posts by Nukiwi
Old Yesterday, 07:45 PM
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
No Idea. My 3DHS Slick has the same pull, pull rudder. That is tail heavy, so I follow the reason there was to keep the mass as far forward as possible.
"Stronger, faster", well, can be more of a fiddle to set up!
All the stress is on the wing tube. The other pins stop the wing rotating. So the small screw just stops the wing from moving out.
Forgiving? well , no. If you cartwheel one of these, they usually break the fuselage behind the wing....
Old Yesterday, 08:36 PM
Love the Cub
Joined Sep 2012
I will give the Xoar props a try. I will have my Edge 540 tuned for 3D in no time. I just need to keep it 3 mistakes high so I have time to recover
Old Yesterday, 09:04 PM
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
You could also try VOX props. Also very good.
New Product Hobbyking Domin-8-Trix 3D 1200mm (ARF) groovejet 3D Flying 267 Jun 02, 2013 08:55 AM
Discussion Hobbyking Edge 540 EP/0.25 1200mm (ARF) sihinch 3D Flying 115 Oct 23, 2012 03:19 AM
New Product HobbyKing - Mini Racers Edge 540 V3 & Sbach Mikemynameis Parkflyers 13 Jun 24, 2012 10:55 PM
Discussion Mico Durafly Edge 540 V3 hobbyking RUBNorris 3D Flying 5 Nov 17, 2011 10:15 AM
New Product HobbyKing Mini Racers Edge 540 V3 & Sbach... micromantis Foamies (Kits) 6 Oct 31, 2011 02:25 PM
