Old Jul 04, 2016, 04:16 PM
Liamm is offline
Find More Posts by Liamm
Joined Dec 2014
Naze 32 throttle issue, Quad Flys off when past 50% throttle.
Hi guys,
I have a Gaui eclipse with a Naze 32 and Little bee pro 20a ESC's with Xnova motors, I am having a big issue with the throttle, when I go past 50% it flys off :-(
I set the quad up the same way I have done all my other ones, when I came to fly it it did not feel locked in at all and when I went past 50% throttle it has a mind of its own and then goes to full throttle and I have no control,
When I hit disarm it takes a few seconds to kick in. This does it in both Horizon and Acro mode.
I calibrated the esc's via Cleanfight and also tried to do it via BLheli by matching the low and max throttle points.
When I test this on the bench I get a linear throttle curve from 0-100% and it behaves normally.
All the PID's are stock
Have you any ideas what this could be as I am lost been trying to figure it out for a couple of weeks and can't find any info on the net.
Liam
Liamm is offline Find More Posts by Liamm
Old Jul 05, 2016, 11:41 AM
Pilotrob56 is online now
Find More Posts by Pilotrob56
Pensacola, Fl
Joined Aug 2009
Mine did something simular the other day. it would flip over when I would try and do pitch pumps. I had some crashes previously so I hooked it up to Cleanflight and everything was normal with the PID`s and motor settings. Got to looking at the props and some looked bent, so I changed out all the props with new ones and it flew normal again. Hope this helps.
Pilotrob56 is online now Find More Posts by Pilotrob56
Old Jul 09, 2016, 06:40 PM
Liamm is offline
Joined Dec 2014
Hi,
Thank you for your reply, Unfortunately that is not my issue. When ever I go over 50% throttle my name 32 then puts its own input in of 100%.
Help! CleanFlight Naze 32 - Drone takes off only when it feels like it! darkdrgn2k Multirotor Electronics 6 Jun 15, 2016 08:10 AM
Discussion Dex 50 with naze 32 AlexF Multirotor Talk 0 May 30, 2016 02:07 AM
Help! Betaflight Throttle Value when TX is Off courtlandre Multirotor Beginner 6 Feb 15, 2016 03:27 PM
Discussion Naze 32 - When should it beep? quadtastico Multirotor Electronics 3 Oct 23, 2015 01:56 PM
Help! ER9x & Naze 32 Throttle Range eppson977 Multirotor Talk 3 Aug 15, 2014 11:45 PM
