Old Sep 26, 2015, 01:18 PM
LRFitch is online now
Find More Posts by LRFitch
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Gasser for Cub
I have a smallish 82"ws Great Planes Cub arf. I have had electric motors in it for quite a while, and would like to repower it with a small gasoline engine. Not sure what is needed and what will fit inside the cowl. Does anyone have any successful experience with a gas powered Cub of this size?
Larry Fitch
LRFitch is online now Find More Posts by LRFitch
Old Sep 27, 2015, 06:03 AM
JeffinTD is offline
Find More Posts by JeffinTD
United States, OR, The Dalles
Joined Apr 2011
That's the clipped wing cub intended for .60 to .90 glow?
If so I would think something like a GT15 might work if you wanted gasoline.
Hopefully someone who actually has that plane with gasoline will chime in.
JeffinTD is offline Find More Posts by JeffinTD
Old Sep 27, 2015, 11:36 AM
Mikes145 is offline
Find More Posts by Mikes145
United States, MI, Westland
Joined Sep 2010
I have a DLE 20 in my Hangar 9 Taylorcraft. I believe the wingspan is 80". I bought the plane used with this engine but if I were to do it again, I would go a little larger. I bet your cub would be similar.
Mikes145 is offline Find More Posts by Mikes145
Old Sep 27, 2015, 04:29 PM
Joined Aug 2004
Mike, Jeffin, Thanks for the comments. The Cub isn't a clipped wing version, but I don't think that matters much, and it is intended for a 60-90 glow engine. I'll have to do some checking to see what size gasser will fit. I see the VVRC sells a 10, 15, and a few 20-21 cc engines. I'll see what I can dig up for dimensions on these small engines, and give one a go. Bigger is better--if it will fit. Thanks for the responses.
Larry
Old Sep 27, 2015, 08:32 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
if this is the one you have, http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLWH2
the a 10cc or 15cc is what ya want
whiskykid is offline Find More Posts by whiskykid
Old Oct 04, 2015, 11:16 AM
Joined Aug 2004
Whisky, Thanks for the advice. And YES that is the Cub I have.
Old Oct 04, 2015, 12:33 PM
mike3976 is online now
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
I'd have to say the 10cc would be the one you'd want, recommend either the Horizion Evolution or OS , stay away from the others in that size, there crap.
mike3976 is online now Find More Posts by mike3976
Discussion Gasser throttle curve setup for "linear feel" doublestroken Fuel Plane Talk 31 Jul 09, 2016 01:14 PM
Discussion Electronics For First Gasser WNCmotard Fuel Plane Talk 18 Apr 29, 2015 11:22 PM
Discussion 10 or 15 cc gasser for a 78" cub? MOUNTAINROAD Engines 7 May 19, 2014 01:45 AM
Discussion *4 Stroke Gasser For 1/4 Scale Cub* olezippi Engines 6 Jul 06, 2013 05:38 AM
