Old Jun 08, 2015, 10:10 PM
julescrafter is offline
Find More Posts by julescrafter
Scale RC Plane Lover
julescrafter's Avatar
Indonesia, Jakarta
Joined Jul 2013
Build Log
OV-10A Bronco 1300mm Pusher Prop
This project is complete
specs :
1. Wingspan : 1300 mm ~ 52 inches
2. Flying Weight : 1186 gram ~ 2.6 lb
3. Brushless Motor : 3536-750kv 330 watt
4. Propeller : MA 3 blade - 10x4
5. 6 servos - 9 gram
6. Fixed landing gear
Video (flight II-VI)
OV-10 Bronco foam RC plane - first flight after painted (3 min 19 sec)
next is plans in PDF.
Build Log :
This is my latest plane (9th plane), a OV-10A Bronco. I only have 1 motor left so I will use it as a pusher motor on the back of the fuselage. I usually use mainly 5 mm depron, but now I only use 5 mm for the formers and ribs, for the skin I use 3 mm depron. I started with the 3D model, modelled from 3 view drawing using Gmax and unfold it into 2D patterns with Pepakura Designer.
julescrafter is offline Find More Posts by julescrafter
Old Jun 09, 2015, 02:16 AM
jonesymj is online now
Find More Posts by jonesymj
Slopeosapien
jonesymj's Avatar
Joined Jun 2006
Wow jules that looks fantastic so far!
Great work on what is definitely one of my favorite aircraft!
jonesymj is online now Find More Posts by jonesymj
Old Jun 09, 2015, 08:42 AM
Indonesia, Jakarta
Joined Jul 2013
Thanks Jones
more build pics
Old Jun 09, 2015, 10:08 PM
rajazo is offline
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
amazing model!
I'm a bronco fan and made a easybuild version a couple of year ago and the pusher version worked fantastic... your version will perform lot better thanks to the wing (mine was a KF2)and the lighter frame... and of course looks lot better too.
Do you plan post the plans? I really like to see the fuselage and cockpit pieces...
be carfull with elevator-rudder union.. it could be fragile and tendto flex on high speed recovers on dives...
good luck!
rajazo is offline Find More Posts by rajazo
Old Jun 09, 2015, 11:14 PM
Indonesia, Jakarta
Joined Jul 2013
Originally Posted by rajazo View Post
amazing model!
good luck!
Thanks Rajazo
Yes I will post the plans, eventually.
and thanks for the tips.
I put 2 dummy windmilling props in front to add the scale look. Yes they produce drag, but not much, I think.
I use styrofoam for the spinners and balsa for prop blades.
more pics and taxiing test video
OV-10 Bronco foam RC plane - taxiing test (2 min 50 sec)
Old Jun 11, 2015, 09:29 PM
Indonesia, Jakarta
Joined Jul 2013
Maiden flight
The dummy props were windmilling perfectly, just like I want but a little bit nose heavy.
I had to make an emergency landing because the motor was vibrating hard.
Pretty hard landing that cause the motor came off from the mounting.
OV-10 Bronco foam RC plane - maiden flight (0 min 48 sec)
Old Jun 12, 2015, 10:12 AM
ringo42 is online now
Find More Posts by ringo42
ringo42's Avatar
United States, GA, Lawrenceville
Joined Apr 2013
Sweet
ringo42 is online now Find More Posts by ringo42
Old Jun 12, 2015, 09:32 PM
Indonesia, Jakarta
Joined Jul 2013
Originally Posted by ringo42 View Post
Sweet
Thank you Ringo.
I just finish the plane yesterday with USMC color scheme.
Can't wait to get her in the air again, next is flying video.
Jules
Old Jun 13, 2015, 02:58 AM
balthazar420 is offline
Find More Posts by balthazar420
Crashing at 8600ft
balthazar420's Avatar
United States, CO, Conifer
Joined Sep 2009
WOw! That bird is BEAUTIFUL!
balthazar420 is offline Find More Posts by balthazar420
Old Jun 13, 2015, 10:26 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Superb!
foamdave is offline Find More Posts by foamdave
Old Jun 14, 2015, 03:48 AM
Indonesia, Jakarta
Joined Jul 2013
Originally Posted by foamdave View Post
Superb!
Thanks Balthazar and foamdave
yesterday I had it in the air again, I test it with and without the dummy prop. The result was surprised me, the dummy props drag is way bigger than I anticipated. Today I replace the motor with bigger one. 2826 1500 kv 250 watt motor with 8x6 propeller was replaced with 3536 750 kv 330 watt with 3 blade 10x6 prop (ex corsair's). I also trim the dummy prop a bit shorter, the result with more power the plane fly well and land well. I'll post video when I have my friend available to hold the camera.
Also add an extended fuel tank (accessories)
Jules
Old Jun 14, 2015, 12:34 PM
Indonesia, Jakarta
Joined Jul 2013
First video after painted
Old Jun 14, 2015, 02:50 PM
willhappy is offline
Find More Posts by willhappy
United Kingdom, Cnwll
Joined May 2008
wow that's great well done julescrafter, is it all made out of Styrofoam??
will
willhappy is offline Find More Posts by willhappy
Old Jun 14, 2015, 10:58 PM
Indonesia, Jakarta
Joined Jul 2013
will
Thanks will, yes it made entirely from foam, polyfoam for more specific or depron foam. I use 5 mm thick for formers and ribs and 3 mm for the skin. I use styrofoam only for tip of the nose, both dummy spinners and both pilot figures. 2mm balsa sheet for stabilizers spar and dummy propeller blades. PET plastic sheet for the canopy. Bicycle spokes for landing gear struts. 2 mm plywood for landing gear bases and motor mount. That's all
specs :
Jules
Old Jun 15, 2015, 01:28 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Very nice build. Did you make the canopy from scratch?
RCDad is offline Find More Posts by RCDad
Build Log OV-10A Bronco........... 96"ws J Morgan Giant Electric Planes 1211 May 23, 2015 12:00 PM
Help! ov 10a bronco scale size ? THESANDMAN Electric Warbirds 3 Oct 22, 2013 06:52 PM
Sold Bronco OV-10A rcnyc78 Aircraft - Electric - Airplanes (FS/W) 9 Mar 23, 2006 10:00 PM
Article The K&A Models OV-10A Bronco Terry McGill Electric Plane Talk 0 Feb 07, 2000 01:00 AM
