Old Jan 31, 2016, 08:40 PM
JCfly04 is offline
Find More Posts by JCfly04
United States, VA, Herndon
Joined Mar 2015
Maiden LOS flight today with my fully complete Blackout Mini H. Betaflight 2.3.4 on the TBS Powercube and couldn't be happier with the results.
Betaflight 2 3 4 default PIDS Maiden ACRO (1 min 51 sec)
JCfly04 is offline Find More Posts by JCfly04
Old Feb 01, 2016, 08:22 PM
DRPROP is offline
Find More Posts by DRPROP
Drprop
DRPROP's Avatar
Australia, QLD, Brisbane
Joined Jul 2015
30a Blackout ARF Kits
We have added the Littlebee 30a to our ESC range.
http://www.icktrading.com/products/f...tlebee-30a-esc
Now all the ARF kits have the option of adding these or a Variety of other ESC options.
http://www.icktrading.com/collections/blackout-kits
Thanks to everyone for your support.
Loving the clips
DRPROP is offline Find More Posts by DRPROP
Latest blog entry: Tmotor F series
Old Feb 04, 2016, 09:43 AM
JaZzMaN251 is offline
Find More Posts by JaZzMaN251
FPV enthousiast
JaZzMaN251's Avatar
Belgium, Flanders, Beveren
Joined Jul 2013
Drone Racing Belgium did a demonstration race at Droneport (Sint-Truiden, Belgium)
Thanks to Sep Berghmans to create a great track for us to fly!
Drone Racing Belgium - Droneport Demonstration Race (3 min 17 sec)
JaZzMaN251 is offline Find More Posts by JaZzMaN251
Old Feb 05, 2016, 05:45 AM
DRPROP is offline
Drprop
DRPROP's Avatar
Joined Jul 2015
T-Motor F40
Blackout Mini H Quad Simplified ARF kit builder,
Blackout ARF's simplified
T Motor F40's have arrived!
T-MOTOR F-SERIES FPV RACING MOTORS F40 2 PER SET
Testing the F40 on a Blackout Mini Quad in this clip with 5s!!
BLACKOUT test avec Lipo 5S Esc Kiss racer 24A T-Motor F40 2300kv (7 min 1 sec)
Old Feb 06, 2016, 09:46 AM
Backdraft83 is offline
Find More Posts by Backdraft83
Finland
Joined Feb 2015
Trying to turn off the LEDs on my blackout. Is it supposed to be done by scoring a line between the LED pads to break the connection?
I've been carving away between the pads but they refuse to turn off. The are still dimly lit no matter how much I take off. Am I going about this the right way?
Backdraft83 is offline Find More Posts by Backdraft83
Old Feb 06, 2016, 11:31 AM
DRPROP is offline
Drprop
DRPROP's Avatar
Joined Jul 2015
Blackout PDB LED's Switch
Originally Posted by ZippCen View Post
There is a trace between the two +ve LED pads.
If you want to disable the LEDs you cut the trace.
Its not the pads you want to scratch, its the material between the pads you want to remove.
Though if you're thorough enough what you're doing will work (they dimmed your almost there )
I found that back in the thread a bit, there's bound to be more...
http://www.rcgroups.com/forums/searc...y=led%20switch
its like an encyclopedia of Blackout.
http://www.rcgroups.com/forums/showp...postcount=3245
I also read that you can solder pins on and just bridge them manually for a simple LED switch.
Hope this helps
Old Feb 06, 2016, 04:43 PM
Finland
Joined Feb 2015
Hope this helps
Yup, thats what I've done. Scratched between the pads, but I'm still getting some connection. I guess I'll just have to keep grinding away.
Some of my led's are broken and I thought it might be causing problems.
(flying in snowy conditions). My quads been falling out of the sky a lot lately and just trying to eliminate all possible causes.
Old Feb 06, 2016, 05:01 PM
OnBoardWithBlade is offline
Find More Posts by OnBoardWithBlade
United States, DE, Fenwick Island
Joined Jun 2014
I thought you only needed to bridge the pads marked LED on the PDB?
OnBoardWithBlade is offline Find More Posts by OnBoardWithBlade
Old Feb 06, 2016, 07:21 PM
DRPROP is offline
Drprop
DRPROP's Avatar
Joined Jul 2015
I'm using a V3 because I started mine before the V4's were ready,
They shouldn't be any different.
There was no bridging required to get the LEDS running.
I Had power to my LEDs as soon as i applied volts to the power pads.
The 2 pads marked LED Switch are bridged by default. (V+)
Old Feb 06, 2016, 07:26 PM
Bj1 is offline
Bj1
Find More Posts by Bj1
Bj1
Joined Oct 2015
My quads been falling out of the sky a lot lately and just trying to eliminate all possible causes.[/QUOTE]
Mine was falling out of the sky lately and it turned out to be a hairline crack in the pdb just in front of number 3 arm which was losing contact briefly and the quad couldn't recover in time. I scratched it back and soldered it to confirm that was the problem then got a new pdb and problem solved
Bj1 is offline Find More Posts by Bj1
Old Feb 06, 2016, 09:35 PM
Joined Jun 2014
Mine's a V2.0, and the LED's are working correctly.
My understanding was if you drag a drop of solder between the 2 LED pads (near left rear of the PDB), then that would turn them OFF.
Lower right in this pic:
http://cdn.shopify.com/s/files/1/085...g?v=1450773649
Old Feb 07, 2016, 12:11 AM
DRPROP is offline
Drprop
DRPROP's Avatar
Joined Jul 2015
LED Switch Blackout Mini H Quad
LED Switch pads are interconnected out the packet.
They are also common to the (V+)
When i applied 12v the LEDS came on without any soldering.
Its a V4 this time.
If you wish to add an led controller, The switch is soldered across the pads.
You break the bridge and achieve open circuit before adding the switch.
Old Yesterday, 06:14 AM
GJL is offline
GJL
Find More Posts by GJL
GJL
Imperfect flyer
GJL's Avatar
United Kingdom
Joined Nov 2013
Crash Compilation!
OK so I've finally crashed enough to make a video about it. These crashes are 90% Blackouts, with all the serious hits taken by the Mini-H. Yeah I broke the odd arm (or two), but only from the hardest crashes.
This frame is still tough after all this time! .
The Price of Progress ▪ Crash Compilation (3 min 32 sec)
GJL is offline Find More Posts by GJL
Old Yesterday, 10:54 PM
Shufty is online now
Find More Posts by Shufty
Multirotor Bloodhound
Shufty's Avatar
Australia, WA, Perth
Joined Apr 2013
This is why I stopped using PDB's a while back. Got tired of intermittent issues and having to replace them.
Shufty is online now Find More Posts by Shufty
Discussion H-quad vs. Spider quad corsair2014 Multirotor Talk 13 Dec 20, 2015 08:28 PM
For Sale DJI 450 Quad, 550 Hexa, Phantom, TBS Disco Quad, & Turnigy H.A.L. LED light kits! macentyre Aircraft - Electric - Multirotor (FS/W) 0 May 15, 2013 11:31 PM
For Sale DJI 450 Quad, 550 Hexa, Phantom, TBS Disco Quad, & Turnigy H.A.L. LED light kits! macentyre Aircraft - Electric - Multirotor (FS/W) 0 May 10, 2013 10:02 PM
For Sale DJI 450 Quad, 550 Hexa, Phantom, TBS Disco Quad, & Turnigy H.A.L. LED light kits! macentyre Aircraft - Electric - Multirotor (FS/W) 0 May 09, 2013 12:54 PM
For Sale DJI 450 Quad, 550 Hexa, Phantom, TBS Disco Quad, & Turnigy H.A.L. LED light kits! macentyre Aircraft - Electric - Multirotor (FS/W) 0 May 08, 2013 12:43 AM
