Old Jan 27, 2013, 03:16 PM
Russ40 is online now
Find More Posts by Russ40
Fort Smith Ar
Joined Oct 2005
Twin motor KFm4 flying wing
I have been thinking about this for awhile and finally got the work bench cleared off enough to give it a try.
I was wanting to build a twin flying wing and use differential thrust for yaw control. I was hoping to get some good flat spins and stuff with it. The wing is 52" span 14" cord at the center tapering to 8" cord at the tip. AUW is 19.25oz. I am running Emax 2812's with turnigy 18a esc's. The battery I used for the maiden is a Turnigy nano-tech 1600ma 25-50c 3s. I also have it setup to use two 1000ma 3s for longer flights. I may set it up for fpv later. It depends on if I can still get the cg correct with the fpv stuff on it. Here is the third flight/first successful flight. The first two it was tail heavy and didn't last to long.
Russ
twin wing1 2 (2 min 57 sec)
Russ40 is online now Find More Posts by Russ40
Old Jan 27, 2013, 04:38 PM
Dickeroo is online now
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Very nice. Very agile in the air.
Russ...
Love the look of this twin engine KFm4. She turns in a dime.
Did you once mention that you might try the KF on a copter?
~ Dick
Dickeroo is online now Find More Posts by Dickeroo
Old Jan 27, 2013, 07:11 PM
Fort Smith Ar
Joined Oct 2005
Thanks Dick.
Yea I still want to try KF on a gyro but havn't got a chance yet. I have been gearing up for the Uni Dome funfly in Iowa. After that I may get the gyro project back on the work bench.
Old Jan 27, 2013, 07:43 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
nice design!
rcrich is online now Find More Posts by rcrich
Latest blog entry: flying penguin
Old Jan 28, 2013, 09:09 AM
Fort Smith Ar
Joined Oct 2005
Got another flight today before the wind picked up. I like the way it flies but it still needs a bit of tweeking. The servos are not strong enough. At high speed the control goes away. The differential thrust works good though.
Twin wing 1 3 (3 min 17 sec)
Old Apr 08, 2015, 02:46 PM
einstein00 is offline
Find More Posts by einstein00
Joined May 2014
Iīm thinking to build my new X8 with twin motors, but i hesitate about any diferential thrust, because i canīt wire the motors to autopilot.
The other way is a Y plug from the motors to the autopilot throttle output.
any suggestion?
Thank you
einstein00 is offline Find More Posts by einstein00
Old May 28, 2015, 11:39 AM
stormizer is offline
Find More Posts by stormizer
Joined Sep 2010
Wow!! Almost exact same setup with what I am trying to build! What a coincidence. Almost exact same size too. Glad that the measurement I pulled out of my arse might actually working.
Been thinking about the autopilot too. Can't find diff-thrust in ardupilot.
But it seems like a V-tail mixer might work. The autopilot wouldn't know if its a diff-thrust.
Here's a reference I found on youtube:
Differential thrust on the cheap! (7 min 2 sec)
stormizer is offline Find More Posts by stormizer
Article MicroDAN 2505-2900Kv Delta/Flying Wing Outrunner Motor Review DismayingObservation Power Systems 22 Apr 04, 2013 06:23 PM
Sold Flying wing motor mounts DlgHucker Aircraft - General - Miscellaneous (FS/W) 1 Jan 09, 2013 07:00 PM
Discussion 20 to 24 inch kfm4 flying wing question himeros Foamies (Scratchbuilt) 1 Jan 10, 2011 12:27 PM
Discussion SpaFFFnutz 48" KFm4 Flying Wing - Electric FFF/Coroplast Hybrid jackerbes SPAD - Simple Plastic Airplane Designs 10 Nov 25, 2009 02:41 PM
