Old Jan 17, 2016, 03:54 PM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Originally Posted by abjets View Post
Other question is... in the manual for Mix 1 it states: ELE UP- Flaps down 1mm and ELE Down- Flaps Up .5mm. In this Flaps Up scenario(ELE Down) is one actually setting the flaps into a spoiler position of up .5mm? This is what I would assume...
Thanks guys!! Cheers- Adam
Yes is the simple answer, but I'm only using the 'down flap-up elevator' mix on a switch to act as snap flap for tighter turns and loops when required (ie, showing off! )
With regard to measuring the control throws, I did measure mine in the centre of the control surfaces, but I don't think it makes much difference for general sport flying.
Ben D Wing is online now Find More Posts by Ben D Wing
Old Jan 17, 2016, 05:37 PM
abjets is offline
Find More Posts by abjets
What Goes Up...Must Come Down
abjets's Avatar
United States, NC, Oak Island
Joined Jan 2013
Thanks Ben- Yeah, I will be holding of on playing with the mixes until I get comfortable with her, but as I am currently setting up all of the throws, etc. figured I might as well program in the options and tweak as I go :-) Cheers!
abjets is offline Find More Posts by abjets
Old Jan 30, 2016, 06:13 PM
abjets is offline
abjets's Avatar
Joined Jan 2013
WHAT A FANTASTIC little bird! A great maiden...and loving the flexibility of the set up and mixes available with the dual AIL's (Love my first Gen Rifle...but limited with control surface movements) Certainly felt the need for more ELE authority on landing...but she did slow nicely with the flaps.
May try to mix in a little less down ELE for full flaps in the landing mode and see if that helps. Otherwise a BLAST! Knees were quivering the whole time :-)
Cheers and thanks for the help!
Old Jan 31, 2016, 01:27 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
Congrats on a good maiden flight, but what set up are you using?
This has to be the best pylon racer in its class and the Voodoo still gets my blood pressure up, even with many flights under my belt!
Old Jan 31, 2016, 07:48 PM
abjets is offline
abjets's Avatar
Joined Jan 2013
Thanks Ben! I guess I should have added the details...I was busy charging batts for another stelar day at the field :-)
Running a DX8...I set up my Flight Modes for...
Flight Mode 0: (T/O and LNDG)100% rates 40% Expo for AIL (UP 3.5mm and DN 2mm Differential measured at root) and ELE(3mm UP and 2.5mm DN)
Flight Mode 1: (LR Cruise) 80% rates on AIL and ELE, 30% Expo for AIL and ELE, with Mix 1 from the manual (Camber mix )
Flight Mode 2: (High speed) 65% rates on AIL and 65% rates on70% ELE. 30% Expo for AIL and ELE, with Mix 1 from the manual Camber mix ) plus a reflex mix of AIL's up 1/2mm max proportionally starting at THR from 80% to 100%.
Also set up my FLAP switch for...
0: no flaps
1: T/O Flaps 3mm Flaps and about .75mm DN on ELE
2: LNDG Flaps 4mm Flaps and just under 1mm DN on ELE
CG: @ 41
Aircraft weight: 302g BEW + 2S 1300 @ 78g = AUW of 380g
- Mega 16/15/2
- 5x5" CF folding propeller
- D-47s servos in the wing
- Futaba 3154 on elevator
- CC Phoenix 60a esc (relocated BEC)
Old Jan 31, 2016, 10:23 PM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
Can anyone share balance position and throws for the voodoo? I have an ESP mini coming and i understand they come without documentation. They are the same airframe, right?
Dave Campbell is offline Find More Posts by Dave Campbell
Old Jan 31, 2016, 11:30 PM
abjets is offline
abjets's Avatar
Joined Jan 2013
They are not the same airframe...maybe a knock off of the same design? Tread with caution if you are going to use the same set up info as the Voodoo...especially when it comes to CG.
If you look one post before yours I just added how I have my Voodoo set up...and if you search this thread there is a manual for the Voodoo...but again, I know the aircraft you are talking about and surprised that HK doesn't even supply a manual for the set up of it. Sort of silly as it is pretty critical with these style aircraft...fast, small throws and a small acceptable CG envelope. Otherwise a short lived bird...oh wait...maybe that is why HK doesn't have a manual for it :-)
Old Feb 01, 2016, 12:43 AM
Joined Dec 2000
I'll be converting this to glow power, it won't be heavy or have the power that a hot brushless will. I have flown a lot of airplanes of this type and not knowing the throws isn't that scary to me, but getting the CG wrong is a risk I don't want to gamble with. I test flew a voodoo with a Neu motor in it and about 3x the elevator it needed to make proper pylon turns, that was do-able, I hate to think what it would be like with and aft cg.
Old Feb 01, 2016, 10:58 AM
abjets is offline
abjets's Avatar
Joined Jan 2013
Agreed...the correct CG is the critical one to have...
Have you tried searching RCGroups for any threads on your bird?
Old Feb 01, 2016, 12:21 PM
Joined Dec 2000
Nothing out there at all. I'm getting mine used, IMO, HK is asking too much for them, the price is high enough that most guys would pay the extra to have the real deal. For me it was cheap enough used to justify putting a nasty 1/2a in to have a sub 8oz ball of hate that the Feds can choke on.
Discussion New Pylon Racer dalbert02 Electric Plane Talk 2 Sep 22, 2006 10:19 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 31, 2006 12:10 AM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 09:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 05:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 07:26 PM
