Old Apr 26, 2015, 11:59 AM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Balance ?
On a f3 V Tail or x Tail do you Balanece the plane right side UP or Upside Down, I noticed that when I balanced right side up on cg. When I turned plane over it needed a few grams of weight for the same angle. Ian
bluffman is offline Find More Posts by bluffman
Old Apr 26, 2015, 12:04 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Right way up on multiplex cg device.
It's hard to get an exact balance when the model is fully loaded (e.g f3b/f model). So upside down might work.
satinet is online now Find More Posts by satinet
Old Apr 26, 2015, 02:28 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
Old Apr 26, 2015, 03:29 PM
Avaldes is offline
Find More Posts by Avaldes
Avaldes's Avatar
United States, CA, San Luis Obispo
Joined Aug 2006
Technically it shouldn't matter. I measure my CG's upside down because I can balance them on a single point, establishing both longitudinal and lateral CG positions. The subtle point that might be impacting your measurements is vertical CG. Measuring Z-CG is very sensitive to pitch angle when you take the measurement. It can have an effect on the longitudinal (X-CG) if your model isn't perfectly level. I would guess that is probably why you are experiencing a difference in measured CG.
Avaldes is offline Find More Posts by Avaldes
Old Apr 29, 2015, 08:29 AM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
What it does in flight will be way more accurate than a millimeter one way or another in the shop.
Curtis
Curtis Suter is offline Find More Posts by Curtis Suter
Old May 03, 2015, 09:23 AM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
I like the idea of the balance point in the center, I would really like to see a picture of how you do it, this way I can replicate it. Thanks for the input. Ian
Old May 10, 2015, 03:24 PM
oakman7004 is offline
Find More Posts by oakman7004
Team WC2013 F3K
oakman7004's Avatar
Sweden
Joined Dec 2004
I have over the years experienced similar problems. I found out that I didn't have a good enough CG device...until recently. Very accurate and simple to use...should have gotten one 15 years ago!
/Jonas Ekman
oakman7004 is offline Find More Posts by oakman7004
Old May 11, 2015, 11:39 AM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Interesting looking CG measurement device. Who makes it?
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old May 11, 2015, 01:45 PM
Glauco is offline
Find More Posts by Glauco
Glauco's Avatar
United States, MO, Maryland Heights
Joined Jul 2002
Martin sells them.
http://www.weberschock-development.de/enfmb/
Glauco is offline Find More Posts by Glauco
Sold Sky trace GPS, GC balancer and prop balancer wakumann Aircraft - Sailplanes (FS/W) 2 Mar 23, 2015 04:25 PM
Discussion Balance Boards - Lots of Balance Boards Homer712 Batteries and Chargers 6 Mar 22, 2015 07:52 PM
Sold GC balancer prop balancer GPS modul wakumann Aircraft - General - Miscellaneous (FS/W) 0 Mar 22, 2015 05:37 PM
Question Charger balance output to balance board plug/cable types. Dialed_In Batteries and Chargers 2 Mar 04, 2015 04:35 PM
Question Charging a 2s lipo w/o a balance connector (Internal balance circuit??) finguz Batteries and Chargers 3 Dec 25, 2014 08:46 AM
