Old Sep 28, 2014, 08:13 PM
treefinder
springer's Avatar
SE MI
Build Log
OneSheeter #16 OSK - Kestrel (a Goldberg Falcon tribute)
caveeagle and I have been discussing a plane that he flew "back in the day" and wants to build a foamie version: Carl Goldberg's Sr. Falcon. While he was familiar with the plane, I wasn't, being out of the hobby, getting married, raising kids, etc, etc "the rest of life". When I did a bit of research on it, I found it was a really popular plane, and was done in several variations and sizes and there were a fair number of plan sheets out on the web. While he was pondering working right off the original plans and building one from scratch, I got thinking about doing it as a onesheeter, and one evening went into a fit of creative passion (well, maybe not a fit....) and came up with a foamie version. We are going to both build one and compare notes. Thanks to my favorite Laser Lady, we will be using laser cut parts from Model Plane Foam. Of course, these first go arounds will inevitably have mistakes, and missing parts (that I forgot) so be aware the templates aren't finalized. I used the Jr. Falcon plans to build the foamie version fyi.
I forgot to mention the Kestrel is a small falcon native to most of North America. It is one of the smaller ones that we see hovering above the freeway medians getting ready to pounce on those little mice! So, we are doing a little Falcon.....
edit 10/23, here's a second flight day video:
osk 10-23-14 (3 min 11 sec)
Here's a couple pix of the originals:
10/25/14 and a picture of the finished foamie:
springer is offline Find More Posts by springer
treefinder
springer's Avatar
SE MI
templates pdfs, etc
We are doing the MPF version with almost a 40" span, but I also created a Readiboard version with 36" span. I will upload the MPF version first. Again, remember these aren't built yet, so may be missing parts, etc.
templates for wire landing gear added 10-20-14
Old Sep 29, 2014, 09:35 AM
AKA Don
bz1mcr's Avatar
United States, MI, Houghton Lake
Joined Dec 2002
Looks like the start of another great One Sheet design.
I never had a Falcon but I did have a Carl Goldberg Ranger 42. It may have been the original foamie. At least it was the first foam plane I ever saw. Mine was rudder and elevator only. Power was a Cox Tee-Dee .049. It was my first really successful RC Plane. It had a used 3 channel Kraft single stick proportional radio. Third channel was a rotary knob on the end of the stick, normally used for throttle. The plane flew great. It traveled with me on military reserve camp outs and vacations around MI. One day I was flying and a young (8-10 yr. old) lad came to watch. He jumped at a chance to fly it, when I offered. He flew around for several minutes following my instructions and doing a nice job. Then for some reason he started to push the stick forward. A shallow dive kept getting steeper despite my instructions to pull back on the stick. I kept saying pull back, pull back! He finally did. Just as the near vertical dive was about to enter the top of a large tree. Wing folded and fluttered down as the fuse went right through the heart of the tree. Miraculously, the pieces all came down and were soon glued together and flying again a few days later.
Check out the Ranger 42. Photo of plans here. http://www.rcgroups.com/forums/showp...74&postcount=4
bz1mcr is offline Find More Posts by bz1mcr
Old Sep 29, 2014, 12:32 PM
treefinder
springer's Avatar
SE MI
Wow, Goldberg sure did a bunch of planes on that same basic set of specs! Ranger looks like the same plane with a cabin instead of canopy. While searching, I noticed his skylark a low wing plane on the same general plan. If it aint broke, don't fix it!
And a very early testimonial of foam's repair-ability, too!
Latest blog entry: OneSheeter#17 OSC140 debut
Old Sep 30, 2014, 01:22 AM
caveeagle's Avatar
United States, IL, St Charles
Joined Dec 2010
I am looking forward to this build. I have been thinking about adding ailerons to the OSF for a while, but decided I would rather leave that plane alone and work on another plane to serve as a good 4ch trainer. I am very pleased that to have Springers plans to work from!
Here is the gear list I am planning to use:
-Emaz CF2812 motor
-Hobbywing Slywalker 20amp ESC
-32 1300mAh battery
-Fixed trike gear
-9g Towerpro servos
Here are some vintage pics from 1986:
First pic was taken at Kuhberg Hill Army Rec Center field. Bad Kreuznach, Germany.
caveeagle is offline Find More Posts by caveeagle
Old Oct 07, 2014, 11:08 PM
treefinder
springer's Avatar
SE MI
Wow! You are gonna have yours done before i get mine started!
All looking good!
Old Oct 09, 2014, 06:32 PM
caveeagle's Avatar
Joined Dec 2010
Just got back in town and found a package full of RC gear arrived in the mail!!
...That never gets old.
Looks like the motor will fit great with a little foam clearancing. I will need to get creative with the bottom cover to make sure battery access is smooth and easy. I hope balance turns ou ok, because I don't have much option to move the battery.
Old Oct 10, 2014, 10:05 AM
caveeagle's Avatar
Joined Dec 2010
I am planning ailerons similar to the OS #12 Edge, using cofee straws to actuate the control surfaces.
I need to decide if I want to put the aileron linkage, and control horns above or below the wing. Below seem like the obvious choice, but in some models I have notices more travel on the same side as the control horn. (maybe I am doint it wrong)
In any case, I am planning on putting a small canopy on top of the wing, so I could easily hide/protect the servo and linkage.
I would rather not force the coffee-straw through the middle wing panel, so I think the servo 'top' should be on the same side as the ail control horns.
...I am probably over-thinking this.
Old Oct 10, 2014, 10:09 PM
caveeagle's Avatar
Joined Dec 2010
This is the first time I have used XT60 connectors. They are MUCH easier to solder that the Deans connectors i have used. They seem a little tough to pull apart, but maybe they will loosen up a bit.
Old Oct 10, 2014, 10:19 PM
Jim
North Alabama
Joined Mar 2004
Brings back memories of my old Falcon 56.......
Is that EPP ? Kinda looks like EPP when you enlarge the pics.
Jim
Jim_W is offline Find More Posts by Jim_W
Discussion OneSheeter #14: Rollason Beta springer Foamies (Scratchbuilt) 76 Apr 01, 2014 11:22 PM
Build Log QSW - Quarter Sheet Wing - in the onesheeter tradition springer Foamies (Scratchbuilt) 13 Oct 28, 2013 11:18 PM
Build Log Kestrel for MMMB Mikeofthenorth Scratchbuilt Indoor and Micro Models 22 Oct 23, 2013 02:27 PM
Wanted Carbon Falcon or Carbon Kestrel gkowen Aircraft - Electric - Airplanes (FS/W) 0 Sep 22, 2013 11:21 AM
