Old Aug 25, 2014, 01:28 PM
Joined May 2006
Slot Car motors
Has anyone ever used a slot car motor in their boat? What kind of batteries to you use? And will it overheat?
HomePort Models is offline Find More Posts by HomePort Models
Old Aug 25, 2014, 05:22 PM
Sometimes I am the weapon
Harquebus's Avatar
South Korea, Gyeonggi-do, Ansan-si
Joined Jan 2006
I've seen the motors in 1/32 and 1/24 slot cars used for everything including boats. This is typically a Mabuchi 130 size motor and some specify 3-12 volts depending on designation.
The smaller box style open motors I have seen used too, but I am not sure of the specs for those.
Harquebus is offline Find More Posts by Harquebus
Old Aug 26, 2014, 02:18 PM
Joined May 2006
I was using 7.4 Lipo with a similar motor, and they cooked.
Would a LIPO make a difference?
Eric
Old Aug 26, 2014, 10:30 PM
United States, IN, Greensburg
Joined Jun 2014
Eric
Yes, even some of the motors in rc cars can't handle 7.4v
Losi has a pretty nice 180 the size of a slot car motor that will handle 7.4v.The motors used in the Losi clones such as Hsp and Microx will not handle 7.4v.I'm not sure what the issue is, I'm guessing the better motors are just assembled with better glues, brushes, etc and handle the extra heat better.
micromodder is online now Find More Posts by micromodder
Old Aug 27, 2014, 01:04 PM
Joined May 2006
That is great information on the 180s.
I am ordering a couple today.
Old Aug 27, 2014, 01:27 PM
Joined Jun 2014
What are you putting them in?There's alot of nice small motors that will handle 7.4v, I think Miniq car 130's also handle 7.4v.There's a member on the crawler forums named Danally that offers high power custom wound Losi motors.
If you have enough room for a standard size 180 then there's a few cheaper options like the Redcat Sumo 180.I used a Redcat motor in my Litehawk Chase and is pretty fast.The Losi motor has more power but they run hot, Redcats 180 had alot of room to solder on a tube for water cooling and it stays nice and cool.Here's a thread showing a couple of 180 upgrades in 10" catamarans
http://www.rcgroups.com/forums/showthread.php?t=2217204
Old Aug 27, 2014, 02:03 PM
Joined May 2006
This is what i have in there now:
http://www.horizonhobby.com/products...FaVZ7AodliIAVw
Old Aug 28, 2014, 04:38 AM
Blackpool, Lancs
Joined Feb 2006
A motor in a slot car typically has cooling airflow around it and on any circuit will have varying power applied. A motor deep inside a hull doesn't, and you tend to use full power in long bursts. You do need to de-rate so that the motor can get rid of any heat it generates, or make other arrangements for getting the heat to the outside of the boat.
mfr02 is offline Find More Posts by mfr02
Old Aug 29, 2014, 05:58 AM
Auckland New Zealand
Joined Sep 2010
I made a 26cm mini cat using 2 HO slot car motors on 350mah 2s. Not brilliantly fast but it worked ok. No heating problems. 16mm props LH and RH. 3.5g servo and 5A ESC.
Built from 1/32 balsa and several coats of dope to finish.
KIWINB is offline Find More Posts by KIWINB
Old Aug 29, 2014, 06:06 AM
Joined Jun 2014
Originally Posted by KIWINB View Post
I made a 26cm mini cat using 2 HO motors on 350mah 2s. Not brilliantly fast but it worked ok. No heating problems. 16mm props LH and RH. 3.5g servo and 5A ESC.
Beautiful boat, thanks for sharing.Do you have any pics of the build?
Old Aug 29, 2014, 07:40 AM
Joined Sep 2010
Sorry, no. I just cut out the bits from 1/16th and stuck them together. Covered it with 1/32nd balsa, carved and hollowed the cockpit from light balsa, canopy from plastic used to package Easter eggs. Fitted the motors and the shafts (from 0.8mm rod and matching tube). Made the rudders and linkage, (very fiddly!!), mounted the servo, Rx and ESC. Found a place for the battery up front.
Didn't take to long to do.
Slot Car Motors??? gocamping Electric Plane Talk 20 Nov 29, 2013 12:17 AM
For Sale H.O. scale slot cars and accessories 1970IHTA Non R/C Items (FS/W) 0 Nov 11, 2013 08:26 PM
For Sale FT: H.O. Slot Car Track and Cars for Electric Oval or Touring Cars hrnts69 Cars - Cars and Parts (FS/W) 0 Mar 07, 2009 11:44 AM
1/24 scale Slot car motors buzzsaw 46 Parkflyers 2 Nov 09, 2001 12:44 PM
Slot Car Motors on Park Flyers jdoan Electric Plane Talk 5 Oct 04, 2001 12:23 AM
