Old Jun 06, 2013, 04:19 AM
China, Guangxi, Guilin
Joined May 2013
FY-41AP autopilot & OSD installation and debugging
Thank you for purchase FY-TECH produce.
At following, we will give some picture which include installation .
FY-41AP installation and debugging instruction
FY-41AP including the following modules
Ⅰ、GPS+FY-41AP modules
Figure 1 FY-41AP and GPS
Ⅱ、Power management module
Figure 2 Power management module
Ⅲ、Airspeed meter
Figure 3 Airspeed meter
We will take the “Surfers 2000” aircraft as an example to introduce how to install and debug the FY-41AP in the following document.
1、 Please prepare the equipments “Figure 4” shows before install.
Figure 4 “Surfers 2000” and all the equipments which need to install
2、 Please connect the servos control wires to FY-41AP S1-S5 corresponding channel.
Figure 4 FY-41AP servos wires connection
The wires connection sequency please refer to table 1
3、 Please weld the T plug to current sensor like the Figure 6 shows:
Figure 6 weld the T plug to current sensor
Interface of FY-41AP ---CS port
Fig7 power manager connect to interface of FY-41AP “CS” port
4. the lines of camera connect with interface of FY-41AP video in port.
Interface of FY-41AP ---video in port
Fig8 Camera connect with interface of FY-41AP
5. Video transmitter connect to interface of FY-41AP “Video out”
interface of FY-41AP -----video out port
Fig9. Video transmitter connect with FY-41AP
6. RC module connect to FY-41AP by 2*4P Receiver Connection wires
Interface of FY-41AP---Function port
Fig10. 2*4P Receiver Connection wires connect with FY-41AP
Attention the 2*4P wires put into FY-41AP which position and direction, black wire of 2*4P wires connect with “-”,and red wire connect with “+”
2*4P Receiver connection wires and the RC module connection table,follow table2.2
7. GPS module connect to interface of FY-41AP.
Interface of FY-41AP---GPS port
Fig11. GPS module connect with FY-41AP
8. place FY-41AP , power manager ,GPS module, airspeed meter, camera ,video transmitter, RC receiver and so on in space of airplane and layout all module.
Use four shock sticks attach four pointer of FY-41AP, for example 12
fig12 shock stick fig13 layout the wires
fig13,you can plan all wires in your space of airplane.
9.layout all wires, apart top paper from shock stick, then attach on the wooden frame in space of airplane.
fig14 place in space of airplane
10. power manager ,FY-41AP,video transmitter, RC receiver in the space of airplane
Fig15. power manager ,FY-41AP,video transmitter, RC receiver in the space of airplane
11.placement GPS ,airspeed meter,and camera at right place.
Placement GPS ,the antenna must be up at installation. Otherwise it can effect GPS receive of quality of signal. As possible as GPS module is far away some interfere source ,for example video transmitter, some module have Magnetism is more strong
Fig16 the position of GPS module, airspeed meter and camera
12. the airspeed installation and position.
Fig17 the location of airspeed meter
the whole real airplane which include FY-41AP and so on.
unfinished, continue.....
feiyu_tech is offline Find More Posts by feiyu_tech
Old Jun 14, 2013, 03:35 AM
Joined May 2013
feiyu-tech release a new firmware for FY-41AP OSD,
the link is :
http://www.feiyu-tech.com/download-en.php?id=71
On June 13, 2013 V1.12 update explanation:
1. Solved some video transmit system can not compatible with FY-41AP problems.
2. The low power alarm basic standard set to 3.6V.
Old Jun 17, 2013, 09:42 AM
ilipin's Avatar
Россия, Пермский край, город Пермь
Joined Jul 2011
Here is my FY41 installed on X8 test.
See not stable RTL function (see from 2:00), and well-known low-power indicator bug.
Gains set to 30-1-80 (http://www.rcgroups.com/forums/showthread.php?t=1904883)
Maiden flight on X8 with FY41 (13 min 34 sec)
Help me to improve RTL stability (and NAV flight in the future).
ilipin is offline Find More Posts by ilipin
Old Jun 19, 2013, 03:40 PM
janpirate's Avatar
Malaysia, Selangor, Ampang District
Joined Jan 2013
FY-41AP Multirotor port
I’m using FY-41AP for multirotor. During setup Motor 1 stop rotation at 48%. Motor 1 connect to S1 port
I already change connection ESC also the same. I took Motor 2 ESC and connect to S1, now the Motor 2 also stop rotation at 48%.
I believe something wrong with the S1 port on FY-41AP. Any suggestion?
Here is the video
FY-41AP Problem with Port S1 (0 min 48 sec)
janpirate is offline Find More Posts by janpirate
Old Jun 19, 2013, 11:51 PM
Joined Dec 2010
http://www.youtube.com/watch?v=4JKeCTdV-J8
hello,
I am Aiden Yin, I look your video ,
I think you need adjust two parameters .
1. you can use "FY-DOS SETTING v1.1",set the roll gain : 65, because it help control your aileron more stability, then it can control your plane go straight to home.
2. you will recover "turn control " parameter : 60 20 60
hotfly163 is offline Find More Posts by hotfly163
Old Jun 20, 2013, 12:05 AM
Joined Dec 2010
Here is the video http://www.youtube.com/watch?v=sG4SpZ7NJfQ
hello,
I think you want to visit FEIYU TECH web , and download it , "FY-41AP multi-rotor firmware V2.21 (2013.5.3) [New] [download] " ,
http://www.feiyu-tech.com/download-en.php?id=69
and upload it .
the next method, you should Calibration of the ECS.
Old Jun 20, 2013, 05:45 AM
Joined May 2013
hello, ilipin
if you adjust roll gain , but the plane can't fly straightly at RTL mode, We think that have tow reasons.
1. you can adjust turn PID parameter ,like follow it
http://www.feiyu-tech.com/news-en.php?id=27&nav_num=5
2. I think the video recorder is too closed to GPS module, perhaps the video recorder have high frequence signal interrupt to GPS . so you should install GPS module is far away the Video Recorder.
Old Jun 20, 2013, 06:16 AM
Joined May 2013
FY-41AP Adjust parameter methods
There are two ways to set the FY-41AP
(1)One is via remote control and OSD overlay menu settings:
(2)Another solution is connected via USB cable to the computer by using the setting software to set up. Here we introduce the use of these two methods.
Description:
Now we will introduce the OSD overlay menu setting method:
① We will take FUTABA T8FG RC as a example, the 3-pistion-switch SE in FUTABA T8FG is corresponding RC receiver fifth channel(FY-41AP SW1 is connected to RC receiver fifth channel), the 3-pistion-switch SG in FUTABA T8FG is corresponding RC receiver sixth channel(FY-41AP SW1 is connected to RC receiver sixth channel).Power on and switch SW2 to NULL(control SG switch into middle position),switch SW1 to ABM mode(control SE switch into middle position).Then power on the FY-41AP and left tilt the aircraft and observe the ALI servos reaction .If the reaction is like picture below shows, then you should adjust the AIL auto control movement direction;
Description:
② Pitch the plane nose up and down to see the following elevator action:Incline the plane NOSE UP. You should see the elevator move down. And when you move the NOSE DOWN, the elevator should move up. If the servo movement is incorrect like the picture below show then you should adjust the ELE auto control movement direction.
Description:
③ Turn your plane clockwise or counter clockwise to see the rudder movement, If the servo movement is incorrect like the picture below show then you should adjust the RUD auto control movement direction
Description:
④ The purple LED flashes continuously even when the FY-41AP remains stationary and you never activate the motor.(When you in non navigation mode, which means SW2 is “NULL”).That’s means you need to do the gyro rest.
Gyro reset procedure:
1,power on and keep stationary.
2,switch to ABM.
3,On SW1,switch ABM to Deactivated Mode 6 times, time interval has to be less than 3 seconds as follows:
ABM→ Deactivated Mode → ABM → Deactivated Mode → ABM → Deactivated Mode → ABM → Deactivated Mode → ABM → Deactivated Mode → ABM → Deactivated Mode.
4,FY-41AP LED will flash white about one second.
5,After white lamp lights off, the re-setting / initialization is complete.
Description:
⑤ How to use OSD overlay menu to adjust FY-41AP parameters:
Description:
⑥ FY-41APOSD OSD display interface:
Description:
⑦ On SW1 switch ABM to 3D mode 6 times, time interval has to be less than 3 seconds as follows:
ABM→3DMode→ABM→3DMode→ABM→3DMode→ABM→3DMode→ABM→ 3D Mode→ABM→3D Mode
Description:
Description:
Description:
(1) Through RC elevator stick to move the cursor to selection the project which you want to adjust (Like:sensitivity, servos surface reverse, 3-position-switch mode...) .
(2) Through RC aileron stick to adjust the specific parameter(Like: increase or decrease the gain,servo reverse or not,3-position-swich arrangement…)
Menu interface
Description:
Menu interface instructions:
Description:
Note: SW2 is priority than SW1, only when SW2 is in "Null" mode, then SW1 can work. so, we have to set a NULL, otherwise SW1 doesn’t work. We recommend SW2 middle position is set to Null, both sides can be set the navigation mode which you like.
Mix Setting
Description:
Ⅰ、Enter the OSD overlay menu, if you want to adjust the AIL control gain:Through the RC ELE stick to move the “→” to AIL Gain number point, like the picture below shows. Then through the RC AIL stick to increase or decrease the number as you wish.
Description:
Ⅱ、The ELE,THR,RUD control gain adjust method please reference AIL adjust method which shows in pointⅠ.
Ⅲ、Through the RC ELE stick to move the “→” to AIL REV point, like the picture below shows. Then through the RC AIL stick to choose reverse the AIL servo auto movement direction or not. If you want to reverse just through RC AIL stick switch NOR to REV.
Description:
Ⅳ、The ELE,THR,RUD control gain adjust method please reference AIL servo auto movement direction reverse method which shows in point Ⅲ.
Ⅴ、Through the RC ELE stick to move the “→” to Switch Mode point, like the picture below shows. Then through the RC AIL stick to choose the navigation mode as you like:
Description:
Description:
Ⅵ、Through the RC ELE stick to move the “→” to “INSTALL SETTING” point, like the picture below shows. Then through the RC AIL stick to choose the installation.
Description:
Description:
Ⅶ、Through the RC ELE stick to move the “→” to “SPEED ” point, like the picture below shows. Then through the RC AIL stick to increase or decrease the speed like you wish.
Description:
Ⅷ、You can adjust the circling radius trough “CIR RAD”and adjust the max distance from home point through “Max Dis”use the same way which point Ⅶ shows.
Ⅸ、Through the RC ELE stick to move the “→” to “LinkMod ” point, like the picture below shows. Then through the RC AIL stick to choose your control mode.
RC:RC receiver directly connect to FY-41AP.
RADIO:RC receiver connect to Remote Adaptor.
Description:
Ⅹ、Through the RC ELE stick to move the “→” to “MixSet” point, like the picture below shows. Then through the RC AIL stick to choose your aircraft type.
Description:
Ⅺ、Through the RC ELE stick to move the “→” to “Init GYRO-ASP” point, like the picture below shows. Through put RC AIL stick to right endpoint and then release it to realize gyro and airspeed reset. the “Init GYRO-ASP” item will flash two seconds, after that, gyro and airspeed reset success. We suggest you do the gyro and airspeed reset procedure before each flight.(Put your aircraft into level position and keep it static, and please use your hand to shelter the airspeed meter inlet from 10 cm in front of the airspeed meter inlet.
Description:
Through the RC ELE stick to move the “→” to “Record Attitude” point, like the picture below shows. Through put RC AIL stick to right endpoint and then release it to Record Attitude. the “Record Attitude” item will flash two seconds, after that, Record Attitude success.(You need to put your aircraft into level position on the ground(no tilt, no nose down or nose up),then switch to ABM mode and use your RC trims your aircraft into level position(Every servo surface is no tilt, no nose down or nose up).
Ⅻ、Through the RC ELE stick to move the “→” to “Save” point, like the picture below shows
After complete the adjustment,please through the RC elevator stick to move the cursor to “Save” position and through the RC aileron stick to save the settings.
During the save procedure, the “save” item will flash two seconds, after that, save success.
Description:
Through the RC ELE stick to move the “→” to “EXIT” point, like the picture below shows. Through put RC AIL stick to right endpoint and then release it to realize EXIT.
Description:
The above point “Ⅰ”to “Ⅻ”is shows you the whole procedure about how to use OSD overlay manual to adjust the FY-41AP parameters.
Next, we will introduce the second way to adjust FY-41AP parameters:
The wires connection like picture below shows:
Description:
① 、 Connect the USB data cable to FY-41AP UART1 port and pay attention to the ground wire position, like picture below shows:
Description:
②、Connect the USB data cable to your PC, like picture below shows:
Description:
If you do not know which COM port number, do the following:
Description:
If your COM port is“COM1*”,please follow the next procedures to do the change;
Description:
Right button Click on, select "properties"
Description:
Select “Port Settings” “advanced”
Description:
In the pop-up "COM16 advanced Settings", Please choose unused port, after that, click "ok", the port number is set success.
Description:
③、First need install USB-TTL device driver, you can download it form our website
http://www.feiyu-tech.com/download-en.php?id=37
Second,FY-DOS&41AP-SETTING software download
http://www.feiyu-tech.com/download-en.php?id=61
WiN7 WIN8 system you should install and run our program "As an administrator".
Description:
Compatibility mode choose "Run this program in compatibility mode for Windows XP and closed your antivirus software.
④ Connect FY-41AP to your PC, from “my computer” –“device manager” –“Port” to find COM port , select corresponding COM port. Baud rate has to be “19200”, click “connect”button. Or just click “Auto Connect” button, it will search automatically, but it’s takes time. Note: only after this has been done, then you can set other settings.
Description:
⑤ “Gain”window:
Description:
It’s for servo control movement Gain, Set Range:0-100,if gain number is getting higher, FY-41AP will be getting more sensitivity.
⑥“Config” Configuration window :
Description:
Click “Init GRYO” to gyro reset. And our software status bar will prompt initial success. Don’t use it during flying!
“Link Mode”setting window:
Description:
“RC” (default) choose RC receiver control.
“RADIO” choose Data Radio and Remote Adaptor control(for details, please see Remote Adaptor and Data Radio instructions).
Also you can use our GCS software during the flight to record attitude.
⑦ “Install Setting”setting window:
Description:
●FY-41AP support four install direction. Front which has LOGO must be installed facing up.
●FY-41AP has an arrow printed on the top of it. Normally Orientate the arrow towards the front of the craft.
●If you adjust the installation direction, it has to be set in software, otherwise you couldn’t use FY-41AP to realize automatic pilot.
Setting procedure:
A. First, Read the current installation direction(default is arrow front).
B. Second, choose the installation direction which you use in your aircraft.
C. Third, after that, please click on “Set” button.
⑧ “Mix Setting”
Description:
Choose the correct mixing mode,otherwise it will cause aircraft doesn’t work normally.
Description:
Models selection table:
Description:
“Switch Mode”SW2 function settings window:
Description:
Usually, we need a 3-position switch (named as “SW2”) to switch the navigation mode, you can set different functions by software in sw2.
SW2 is a 2-position switch.
We recommend to set it as the right picture of above, the “middle” and the “down” position is set to null, the “up” position is used to select the navigation mode you like.
navigation mode:
Description:
⑨ “Reverse”-Automatic control servo surface reverse window:
Description:
⑩ “Circling Radius”settings window:
It is for adjusting the circling radius on Auto Circling Mode. Units is meters, the default setting is 80 meters.
Description:
“Max Distance Setting ” settings window :
Description:
If the plane distance from home point more than the “Max Distance Setting ”which you set, the FY-41AP will automatically into Auto Return To Launch Mode(RTH), in order to prevent aircraft fly away due to no“Fail-Safe”setting of the Remote Controller. FY-41AP default flight max distance is 4000 meters. Also at "RC remote control mode”, increased the judgment of RC receiver and FY-41AP connectivity, if they all disconnect , the FY-41AP will automatic into Auto Return To Launch Mode(RTH)
unfinished , it will continue...
Old Jun 28, 2013, 04:33 AM
Joined Dec 2010
I reprint a video that has been published youtube , the author is : olegkasper1.
Полет на 41 25 июня 1,14 1,13 (8 min 11 sec)
Old Jun 28, 2013, 04:35 AM
Joined Dec 2010
Old Jul 02, 2013, 10:11 AM
rexblack's Avatar
Joined Jun 2013
FY-41AP : how can i Power supply my FLAP servos?
hi all,
I have one fy-41ap and have connected a separate BEC (7,4V-7A) to power supply the HV servos (view A connectors); as you know, in the view A connectors aren't the FLAP plugs, so i intend to use the remain channels on the radio (the original flaps ch connectors) But the radio rx are powered by the 5V FY-41AP power supply, not from the BEC's ESC.
So, I put here some question:
1) can i supply the RX with the same external BEC, at 7,4V? (obvious that my Rx must accept 5v-9V power supply).
2) If the answer to Q1 will be NOT, can I do it by a new other BEC (5V or 7,4V)?. fr example the ESC's BEC that I haven't yet used.
3) in the fy-41AP's cable that power up the RX there are 3 wires, black (-), red (+5v), white (?). Nobody knows what it is for, or signal leads, the white wire? preps are the ESC's throttle signal from Rx to the Autopilot?
4) finally ,... someone has a wiring diagram for the servos flaps, to be uploaded?
tank to all
by from ITA
rexblack is offline Find More Posts by rexblack
Old Jul 03, 2013, 03:57 AM
Joined Dec 2010
hello,ITA
1. if your RX accept 5V~9V, you don't supply BEC 7.4V to RC. because FY-41AP supply +5v to RC.
if you supply the RX with the same external BEC ,at 7.4v. you will change red wire . In the FY-41AP 's cable that power up the RX there are 3 wires, you must pull out the red wire , then plug into idle signal port (the middle of needles) . for example the follow pictures:
Description:
Description:
Description:
Description:
Description:
3. For connect FY-41AP to remote receiver. there are 3 wires(GND:black wire, +5v:red wire, AIL:white wire) ,the white wire is aileron channel. the panel of FY-41AP have been labeled it .
Old Jul 03, 2013, 08:05 AM
tj
uk
Joined Sep 2007
Altitude
Are you planning on adding a user setting for the RTH Altitude height.
Some electric pylons are around the height that it's set at.
I prefer to set my own RTH height, depending on the location I'm flying.
And would be an excellent update to the firmware
tj_UK is offline Find More Posts by tj_UK
Old Jul 03, 2013, 08:18 AM
United Kingdom, England, Nottingham
Joined Aug 2012
i too would love to see this setting in the osd menu, i think it can be set in the gcs4 software though under target altitude?
motofox is online now Find More Posts by motofox
Old Jul 03, 2013, 05:42 PM
rexblack's Avatar
Joined Jun 2013
Originally Posted by hotfly163 View Post
hello,ITA
Tk for your suggest.
Is it possible that also the black wire should be connected at the fy-41ap, toghether with the wire red one? I think so, otherwise, how the power circuit could be "closed"?.
Then, only the white wire mast will remain connected to the RX, that which in turn will be powered by an external BEC by 7,4V
what do you think about all this?
by procedeing in this way i will short te circuit A with the circuit B? what prohibited from the users manual?
....is it possible to convert the fy-41ap fixed airplane in a multirotor version? if yes, how?
New Product Fy-41AP OSD & autopilot system is coming RC4YFPV FPV Equipment 317 Sep 18, 2014 06:01 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 FPV Equipment 1 Sep 23, 2013 04:15 AM
Question Is fy-31ap and the Hornet OSD compatible with fy-90qpro? mgs0098 Power Systems 1 Jan 11, 2013 04:47 PM
Idea FY-21AP/FY-31AP and OSD FY Extender hefest FPV Talk 6 Nov 05, 2012 05:45 PM
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 02:30 PM
