Feb 05, 2012, 10:57 AM
Joined Sep 2009
I am working on the electronic layout for the interior, I have decided to have the servos mounted upside down above the lower wing and just in front of the cockpit, this will provide access in the future and as you can see I have the servo mount constructed. I also made the plate to hold the motor batteries but I still need to cut the slots for the Velcro tie downs. I think at the moment I will have a hatch from the back of the cowl to the forward cabane struts for battery access, I am not sure where the fight battery will go yet (the 2 LiFe cells) and the UBEC. I think that the receiver will be directly in front of the servos, as the signal lead from the ESC will dictate that location. I may even put it forward of the bulkhead as i will be opening the hatch to install the batteries anyway. Oh the battery plate is 1/8" balsa with 1/64" plywood laminated on each side, very strong and lightweight. The final picture shows the gussets in place.
