Old Jul 11, 2015, 05:18 PM
n0irw is offline
Find More Posts by n0irw
LSF 6632 Level II
n0irw's Avatar
United States, OK, Perry
Joined Jun 2006
This is the same combination on the E-Flite Mystique which is also an 11' wing...albeit, the Mystique is probably about a pound heavier.....and after putting quite a bit of lead in the nose of the pure sailplane version....I wanted to make sure I had plenty of power.....You can always throttle down....but if you are underpowered, that can make for a bad day.....It should also make it good in higher winds than the hi-start version.
n0irw is offline Find More Posts by n0irw
Old Jul 12, 2015, 08:43 AM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Originally Posted by Tom.in.Maryland View Post
isnt that alot of motor for this model. I am wondering , i have a kit and have not started yet, wondering about power systems necessary, I just want to get it up to about 500 ft and sail, plus maybe a little help coming in on landing.
Oh, correction, I have the Oly 2. not the Oly 3. Any recommendations on the Oly 2, would be helpful at this point. I don't know how similar the build is to the Oly 3? Also not sure about Ailerons or spoilers how to configure. Or good folding prop choices. Planning on using a 2200 3s bat. As my experience is this type of model needs nose weight.
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old Jul 12, 2015, 09:03 AM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
The Oly II is a much simpler build...I would go with spoilers and not ailerons....put servos in the wing to drive the spoilers....I use Hitec HS-55's.....as far as a motor...you need something that approximates a .15 glow engine.
Old Jul 14, 2015, 10:49 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
The front and rear fuse sides with initial laminations curing. I'll join the front and rear with the interior lamination on Wednesday. With any luck, it should start looking like a fuse by Thursday.
Old Jul 17, 2015, 06:45 AM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
I got the top hatch braces glued in and the #4 former.....If I get finished with honey-do's tomorrow, I'll get formers #2 & 3 installed along with the stab saddle. Then bring the sides together. After that, I'll start working on the firewall install and the #1 former modification.
Old Jul 19, 2015, 10:59 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Well, it's starting to look like a fuse. All formers as well as the stab saddle are in. The firewall is also in....everything is straight. You will notice the gap in the #1 former. Instead of trying to cut a new former with the tabs and hole, I just decided to cut it in half, install one half on each side then glue pop sickle sticks across the gap...Worked great! The second pic shows the top of the #1 former with the sticks glued on. Now on to the pushrods!
Old Jul 20, 2015, 03:49 PM
Joined Mar 2012
so is this a scratch built 2nd fuse ?
Old Jul 20, 2015, 03:55 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Nope...I ordered a 2nd fuse kit from Ray to electrify.
Old Jul 20, 2015, 04:14 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Pushrod joint......moving right along....
Old Jul 20, 2015, 04:16 PM
Joined Mar 2012
nice
Old Jul 20, 2015, 04:48 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Cut down servo tray to fit HS-81MG servos and make more room in the main compartment.
Old Jul 21, 2015, 03:33 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Tail feathers ar glued together and the fuse top rear is on.....pics to come!
Old Jul 23, 2015, 08:58 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
the top and bottom of the tail boom are glued on and the rear top block is being fitted.
Old Jul 26, 2015, 05:58 PM
Joined Mar 2012
Oly 2 unboxing
Oly 2 unboxing
Old Jul 26, 2015, 08:48 PM
n0irw is offline
LSF 6632 Level II
n0irw's Avatar
Joined Jun 2006
Ray's Oly II is going to be a very fun kit to build. Ray has done a great job with his laser cutting which is going to be a touch better even than Airtronics. The original kit had all the parts machine cut and sanded for the best fit of any kits on the market at the time. Ray's kits go together eve easier than the original!
Enjoy the process and feel free to ask any questions. I've personally built 3 of the original Oly II's.
Have fun.
Build Log Skybench OLY III build k4to.dave Thermal 818 May 31, 2014 04:26 AM
Wanted Oly II OLY IIS OLY III Dinu Toadere Aircraft - Sailplanes (FS/W) 10 Nov 22, 2013 09:43 PM
Build Log Oly II S Build log? cn0rris Thermal 146 Sep 02, 2013 02:25 PM
Question Oly II, Oly III or Oly IIs nine2fitzpatrick Thermal 27 Oct 15, 2012 11:54 AM
Discussion Oly III build tips ozmo01 Thermal 5 Jan 20, 2008 07:44 PM
